Gage R&R Sample Size Considerations
ugurkavi
Registered Visitor
Hi. I have been dealing with Measurement Systems Analysis for almost over a year now. There is a question bugging me for sometime now. It is the sample size we use for analysis. In most sources it says to take mostly 10 parts, however, what would be the reason behind this? Also, is there a way to calculate the required sample size for more accurate measurement systems analysis results? If any of you direct me to a source where I could find examples and explanation it would be greatly appreciated. Thanks :)
The sample size of 10 comes from a single root source. The sources you have read are simply repeating the original source...
There are other sources that recommend that your sample size by 30 parts measured twice.
You can construct confidence intervals for your estimates: you are essentially estimating the standard deviation of your measurement error and your observed variation. HOWEVER, since gage R&Rs are not an exact tool, this excercise is fairly nonvalue add.
I have found that 30 parts measured twice gives the most useful information. Others will have different experiences. Try some different sample sizes for yourself and see what they tell you.
S Low Sample Size for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Correct Sample Size for Attribute Gage R&R (Good / Bad parts) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
C Gage R&R Study - Appropriate sample collection and size for a Gage R&R Study IATF 16949 - Automotive Quality Systems Standard 10
C Sample Size of GR&R (Gage R&R) on Nested Anova Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Gage R&R Sample Size - Sample Range for gage R&R - What is the requirement? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
WEAVER Gage R&R Sample Selection - Can we include NG Samples? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
K Gage R on a 10 Piece Sample with a CMM using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Sample Selection for a Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J GR&R (Gage R&R) Sample Setup for Attribute Inspection Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Basic Gage R&R Sample Questions APQP and PPAP 22
I Gage R&R - Can GR&R be done on a representative sample from my tools fleet? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K Alternatives to GR&R (Gage R&R) - Only 4 sample parts and one operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 22
C Gage R&R Sample Selection Methodologies - Capturing "normal process variation" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
B For GR&R (Gage R&R), is multiple testing of the same sample necessary? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G Gage R&R Procedures: Selecting parts (sample) to measure Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Creation of Sample Parts to perform Gage R&R - Go/NoGo to Check Threading Operation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
B How to get a sample that covers Process Variation for GRR (Gage R&R) study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
A Sample preparation for Gage R&R study - Heterogeneous data or Homogeneous data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
Ron Rompen Need help with MSA/Gage R&R - Seeking Minitab template file/sample GR&R study Using Minitab Software 7
Z MSA - Gage R&R Study Analysis - SAMPLE - Case Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
A Gage R&R analysis - Do I have to consider the sample specifications? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
I Gage R&R confidence limits - Bootstrap methods or MLS (modified large-sample) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
