Gage R&R Sheet Formula error?! NDC less than 4
terranceyu
Dear covers,
Can you check what is wrong with this GR&R sheet? When I plot to other formats, the R&R% is < 10%, and ndc is more than 4?
Please help.
Regards,
Terrance
Stijloor
Dear covers,
Please help.
Regards,
Terrance
Any MSA Friends who can help?
(See attachment in previous post.)
Thank you!!
Stijloor.
terranceyu
Dear covers,
Please help.
Regards,
Terrance
Can anyone help in this? it will be great help if can help to solve this problem.
I had been checking the formula, and found everything is okay.
What had been wrong?
debyang
It seems that your AV is much smaller than EV, and there is error in the formula for AV calculation. The formula should incorporate this condition as" =IF(((B47*Y64)^2-(B50^2)/(E43*G43))<0, 0,SQRT((B47*Y64)^2-(B50^2)/(E43*G43)))."
After revision to the spreadsheet ,your study TV is still too small(0.0009) when compared to the Spec TV(0.005); the GRR is still high. If use spec TV as computation basis, the PV must be recalculated(=sqrt(spec TV^2-GRR^2));both the GRR% (5.91%)and ndc(23) results come out pretty good.
However, your R data indicate that the EV is not stable, part #5 R(0.0020) is beyond the UCL(0.00129), and the resoluation is not sufficient (only 3 different values:0.0000, 0.0010, 0.0020), you might need to investigate such situations.
F Leak Tester Gage R&R Sheet Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
kedarg6500 Gage R&R - Is my sheet calculation wrong? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
A Excel Spread Sheet for Gage R&R wanted Excel .xls Spreadsheet Templates and Tools 1
S Gage R&R for Visual Inspection for Sheet Steel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
L Good Excel .xls sheet for Gage R&R that calculates both Anova and Range Excel .xls Spreadsheet Templates and Tools 9
N How to Validate a Gage R&R Spread Sheet General Measurement Device and Calibration Topics 3
K Gage R & R - How to enter appraiser results into an Excel .xls spread sheet Excel .xls Spreadsheet Templates and Tools 12
A Significance of X chart in AIAG MSA sheet for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
M Gage R sheet - Can someone make sense of this data? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Seeking: Gage Calibration Data Collection sheet example General Measurement Device and Calibration Topics 3
D Gage R&R / Inspection Sheet - Example Excel .xls Templates Attached Excel .xls Spreadsheet Templates and Tools 39
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
