Gage R&R studies with 5 appraisers and K constants
joakoa
:frust:Hello EVERYONE!
I'm new here, till today I just try to learn from you reading your posts and advices. Now I have to ask you for help.
This year we decided to conduct MSA with 5 appraisers, 20 parts and 3 trials.
I have problem with K1 constant. Does enyone have idea how to calculate it and extend d2 table.
Probably it is child's play but I stuck and can not go further to analyse results:frust:
I will appreciate any help
Kales Veggie
People: The Vital Few
Re: Gage R&R studies with 5 appriaisers and K constants
I would question why you would use 5 operators, 20 parts and 3 trials. The GR&R exercise is taking lots of resources and money. Is this necessary? What are your reasons?
Start with 3 ops, 10 parts and 3 trials..... That should be sufficient.
SteelMaiden
I would also be interested in why use 5 appraisers and 20 parts.
Refer to Post #3 in this thread. The d* values may be found in a table in the back of the MSA manual.
joakoa
Hello
Thank you for replys
Well, 3 operators, 10 parts and 3 trials we have done in the past.
Parts
Our MSA problem is that we take measurement using microscop, our products are rather small and the differences between them are even smaller (the result is often NOT ACCEPTABLE) Range of tolerance is quite small (i.e. +- 0,05mm) and parts are very similar from size point of view so we decide to take 20 parts to get bigger variation between them (is it good idea:confused:)
Appraisers
We wanted to see what is the difference between all qualified operators (how they measure)
Trials
As usual
Taking above into consideration I don't know how to get K1:(
The d2 table ("g" and "m") includes only 20 subgroups and sizes and I need more.
I case of 5 operators and 20 parts "g" is 5x20=100, how to get that?
I would use 30 parts and only 2 repeats. I've posted on why this is statistically more informative than 10 parts and 3 repeats but the same amount of 'work'.
I have no problem with more appraisers given the system you have. I would actually qualify each appraiser once you understand how to improve them.
if you go to this link there is an attachement titled "Measurement Systems Verification and Validation" that contains the formulas you need. This gets you away from the AIAG restricted constants of g and m....
http://elsmar.com/Forums/showthread.php?t=39528&highlight=Measurement+System+Validation
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Establishing a Gage R&R Studies Program in a Testing Laboratory Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J How to select pieces for GR&R (Gage R&R) Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
I Gage R&R Studies For Small Set of Data With Varied Known Value Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Gauge to Gauge (Gage) Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
J Nested Gage R&R - Studies on Crimp Fastener Tools Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Gage R&R Studies - Part that has 10-20 critical dimensions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
CalRich GR&R (Gage R&R) - How many studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
M Gage R&R Short Study vs. Long Study vs. Other Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 25
S p-Value(s) for Anova (Crossed) GRR (Gage R&R) Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J Attribute Gage Studies - What gages are required to have Measurement Systems Analysis IATF 16949 - Automotive Quality Systems Standard 4
K Complying with Ford customer requirement 4.35 Variable Gage Studies General Measurement Device and Calibration Topics 3
R Destructive Attribute Gage Studies - inserted/pressed in parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S Attribute GR&R (Gage R&R) Studies for Metal Stampers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
T Gage R&R studies for Destructive Test Devices (pull and push tests) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Pin Gage - Gage R&R Studies - One Pin or Entire Set? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P Long and Short (Variable Data) Gage Studies - Urgent Help needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Justification for not doing Gage R&R Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
S Gage R&R Studies - 1200 operators, 2000 measurement tapes and many characteristics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Gage R&R Studies Excel .xls spreadsheet Excel .xls Spreadsheet Templates and Tools 7
ScottK Gage R&R experts please review these studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Antonio Vieira Gage R&R Studies for Attribute Data? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R "Gauge (Gage) R&R Studies per MSA Manual" - Customer Audit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
R Minitab Gage R Studies Using Minitab Software 2
J Gage R&R study requirements - What dimensions are you doing studies on? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
L Identifying Common Pitfalls in GR&R (Gage R&R) Studies - Measurement System Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 29
C Gage R&R studies studies through the full range of the gage? General Measurement Device and Calibration Topics 8
T Gage R&R studies for Spectrophotometer & Gloss Meters General Measurement Device and Calibration Topics 32
T TS 16949 Requirements: Frequency of Gage R&R Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Gage R&R studies used in uncertainty calculations Measurement Uncertainty (MU) 2
D Measurement System Analysis (MSA) - Requirement to also do gage stability studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Gage R&R Studies - Goodness of fit, linearity and linearity percentage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Gage R&R Studies for Process Monitoring Instruments? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
P What gage studies are required for PPAP? APQP and PPAP 5
R Guardbands - Using Gage Studies to define a guardband Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Gage R&R studies and control plan for PPAP - Critical or Significant characteristics? APQP and PPAP 16
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
