Gage R&R study definition - Results for GRR is .0005 - What does this number tell me?
CREED
I am trying to find out if anybody nose where i can find the answer to this question. on a gage R&R study the results for GRR is .0005. My Questions is What does this number tell me. I think it says that .00025 from the low limt of the tolerance is suspect and .00025 from the high limit is suspect. Let's say the %GRR is 15.0, My customer wants me to reduce the tolerance by .0005 on each side and i think this is wrong, but i can not find it in balck and white.
Any help would be greatly appreciated.
F
fireonce
Re: Gage R&R study definition - Results for GRR is .0005 - What does this number tell
The number tells you that your result of Gr&r is very very excellent.
Atul Khandekar
I think the customer is asking you to do what's known as "guardbanding" the specs. While you take steps to improve the measurement system, this is one way of protecting the customer from the risk of shipping bad products.
CREED
Thats's exactly what the customer want us to do, but my problem is he wants us to cut our tolerance by .0005 on each side of the tolerance. And i think we should cut the tolerance by only .00025 on each side but i can not find this in writing any place. That is really what i'm looking for some place that this is written down in black and white, so i can argue the point, at least internally.
Atul Khandekar
If you have a GRR error of 15% (of tolerance), you would be expected to reduce your spec by 15% on either side: total reduction of 30% !!
I remember there was a paper submitted to the Reading Room forum here that discussed this concept.
Not having seen your data or analysis, the 0.0005 is either one standard deviation or a multiple of it, such as 3 or 6. Standard deviations are not additive (or subtractive), so you cannot simply subtract it or a multiple/fraction of it from the tolerance.
I recommend that you consult the MSA manual and create a gage performance curve. This will plot the probability of accepting the part at various dimensions compared to the tolerance. You would then establish the guardbands at the dimensions where the Probability of Acceptance drops below your established criteria (such as 95 or 99% or even 100%).
Post your data and tolerance, and I can plot the curve for you.
S Operating Range - Definition for Gage R&R Study - Micrometers measuring thickness Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Attribute Gage R&R study according to "Charbonneau" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
O Capability or Gage R&R Study for Leak Tester Reliability Analysis - Predictions, Testing and Standards 11
B Linearity study on a non-linear gage General Measurement Device and Calibration Topics 7
M Repeatability issue in Gage R&R study for inner diameter of a bushing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
T Gage R&R Study- Measuring a flexible part (compressed part) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
V Minitab - Attribute Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Gage R&R Study (Crossed) - How to determine Process Tolerance Using Minitab Software 4
O Gage Study training explanation for Gage Users Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K MINITAB 16 - Attribute gage study (Analytic method) and Gage R&R Study (Expanded) Using Minitab Software 2
N When and which gages require a Gage R&R study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Excel spreadsheet for Gage R&R study with 9 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C P/T % of a gage R&R to 0 MMC Tolerance study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
P What is a Type 3 Gage Study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Reducing Within Part Variation during a Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 26
B "Historical std deviation" (Standard Deviation) in Gage R&R study Using Minitab Software 6
B Performing a Gage R&R Study with Minitab 13 Using Minitab Software 5
Z How many parts to measure in a Gage R&R study Quality Tools, Improvement and Analysis 5
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M Sample Selection for a Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
G What is the right sequence for a Gage R&R study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
H Type 1 Gage Study Interpretation Question Using Minitab Software 7
S Minitab: Type 1 Gage Study vs. Gage R&R Study Using Minitab Software 5
S Does a CMM (Coordinate Measuring Machine) require Gage R & R study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D AIAG 4th Edition Capability Study and Gage R&R Requirements Document Control Systems, Procedures, Forms and Templates 8
L Gage Linearity and Bias Study Analysis - Minitab help needed Using Minitab Software 4
J Ordinal Data Gage Study - Kappa scores vs. Kendell?s Coefficient Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Can the Variation on Data be too small in a Variables Data Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
7 Gage R&R Study (Nested) - Feedback and Comments appreciated Quality Tools, Improvement and Analysis 1
D Quality Digest article - "An Honest Gage R&R Study" - Where is he getting the d2*? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Repeatabilty + Reproducibility (Gage R&R) Study - Inter-Laboratory Study (ILS) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J Gage R&R Study by Attribute (ACCEPT-REJECT-INVESTIGATE) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
H GRR (Gage R&R) Study for Digital Temperature Gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Small Variation in Thickness Measurements in Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 23
S Gage R&R (GRR) Study - Please comment on the results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M Type 1 Gage Study - What's your opinion on this gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Minitab 15 Gage R&R Study Nested understanding Using Minitab Software 1
B Study Variation and Discrimination Ratio in Gage R&R ANOVA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M Gage R&R Short Study vs. Long Study vs. Other Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 25
T Gage R & R Study "Best Practices" - More than three operators? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
Miner Intro to MSA of Continuous Data – Part 7: R&R using Wheeler’s Honest Gage Study Imported Legacy Blogs 17
