Gage R&R Study- Measuring a flexible part (compressed part)
Thomas Dorner
Hi all,
I am not sure if I chose the right forum, but here is my question:
We need to conduct a Gage R&R study with a flexible part. The part is compressed natural fiber and its size is about 50"x60". Just telling a number for better understanding. The print of this part shows GD&T and therefore a Datum Reference frame.
We are now in a discussion how to create a fixture, implement the Datum Reference frame, that holds the part in place to measure it with a portable measuring system.
I hope somebody will have some experience with flexible parts. Every comment is very welcome and it will definitely help for better understanding. Maybe there is a book or script out there, which explains such a situation.
Thanks in advance,
Thomas
Golfman25
Good luck. Depends on how flexible the part is. Anything contact/mechanical may cause problems. If you can use something non-contact, I would go with that.
normzone
Free-state vs restrained-state is always a challenging problem. I've seen many a bent sheet metal part that when delivered could in no way be considered to meet print but worked just fine in the assembly. When the material has memory and that memory is not of the nominal state it was formed to you need to have flexible inspection criteria.
I would worry less about inspecting it to the print and more about developing a relationship with the customer/user that allows you to determine what the critical criteria for use are, and a clear understanding of what the ideal part characteristics are.
S Does a CMM (Coordinate Measuring Machine) require Gage R & R study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S Operating Range - Definition for Gage R&R Study - Micrometers measuring thickness Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Attribute Gage R&R study according to "Charbonneau" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
O Capability or Gage R&R Study for Leak Tester Reliability Analysis - Predictions, Testing and Standards 11
B Linearity study on a non-linear gage General Measurement Device and Calibration Topics 7
M Repeatability issue in Gage R&R study for inner diameter of a bushing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
V Minitab - Attribute Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Gage R&R Study (Crossed) - How to determine Process Tolerance Using Minitab Software 4
O Gage Study training explanation for Gage Users Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K MINITAB 16 - Attribute gage study (Analytic method) and Gage R&R Study (Expanded) Using Minitab Software 2
N When and which gages require a Gage R&R study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Excel spreadsheet for Gage R&R study with 9 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C P/T % of a gage R&R to 0 MMC Tolerance study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
P What is a Type 3 Gage Study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Reducing Within Part Variation during a Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 26
B "Historical std deviation" (Standard Deviation) in Gage R&R study Using Minitab Software 6
B Performing a Gage R&R Study with Minitab 13 Using Minitab Software 5
Z How many parts to measure in a Gage R&R study Quality Tools, Improvement and Analysis 5
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M Sample Selection for a Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
G What is the right sequence for a Gage R&R study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
H Type 1 Gage Study Interpretation Question Using Minitab Software 7
S Minitab: Type 1 Gage Study vs. Gage R&R Study Using Minitab Software 5
D AIAG 4th Edition Capability Study and Gage R&R Requirements Document Control Systems, Procedures, Forms and Templates 8
L Gage Linearity and Bias Study Analysis - Minitab help needed Using Minitab Software 4
J Ordinal Data Gage Study - Kappa scores vs. Kendell?s Coefficient Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Can the Variation on Data be too small in a Variables Data Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
7 Gage R&R Study (Nested) - Feedback and Comments appreciated Quality Tools, Improvement and Analysis 1
D Quality Digest article - "An Honest Gage R&R Study" - Where is he getting the d2*? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Repeatabilty + Reproducibility (Gage R&R) Study - Inter-Laboratory Study (ILS) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J Gage R&R Study by Attribute (ACCEPT-REJECT-INVESTIGATE) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
H GRR (Gage R&R) Study for Digital Temperature Gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Small Variation in Thickness Measurements in Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 23
S Gage R&R (GRR) Study - Please comment on the results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M Type 1 Gage Study - What's your opinion on this gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Minitab 15 Gage R&R Study Nested understanding Using Minitab Software 1
B Study Variation and Discrimination Ratio in Gage R&R ANOVA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M Gage R&R Short Study vs. Long Study vs. Other Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 25
T Gage R & R Study "Best Practices" - More than three operators? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
Miner Intro to MSA of Continuous Data – Part 7: R&R using Wheeler’s Honest Gage Study Imported Legacy Blogs 17
C Gage R&R Study - Better to use parts or gage blocks? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
