Informational Gage R&R: Swapping operators
John H
Variable Gage R&R question:
I have 3 good operators where each operator has been at the company five or more years and have been making the same part and use calipers to measure a particular feature on the widget.
Each operator has been trained on how to measure the feature.
Question 1
One of the operators cannot pass repeatability and reproducibility (trained several times) - is it allowable to remove that operator from the Gage R&R and replace with another operator? Is there any set of circumstances that allow this? This seems to violate the very nature of Gage R&R's.​
Does the swapping of operators violate anything in the AIAG, ITAF, or ISO 9001?​
Question 2
Same situation but all 3 operators fail the Gage R&R - is it allowable to swap all three good operators for anther three operators?​
Any particular standards that this violates?
Responses from IATF 16949 auditors will be helpful.
Both the intent behind an R&R study and the type of ANOVA used to analyze the results assumes that all operators were randomly selected and are representative of all the operators that might use the gage. Therefore, if reproducibility is identified as a problem (as you have indicated), a corrective action, or improvement of the system should be taken and the study repeated to validate the effectiveness of the action. Simply swapping operators under either scenario is not sufficient unless the intent was that none of these operators are allowed to use the gage and make decisions regarding the acceptability of the product. Even then, you would need to ensure that the remaining operators were acceptable.
Doing so violates the intent of the R&R study as well as good practice.
Ninja
Looking for Reality
As Miner said, the intent is that the test method is repeatable and reproducible REGARDLESS of which operator allowed to perform it is doing so.
Cherry picking operators is like cherry picking the individual data points and keeping only the ones that help you pass, defeating the whole purpose of the GRR. You still end up with a test method that is unreliable to tell good from bad.
Don't swap operators, fix the test method.
Golfman25
My $.02. If you're really using a caliper for measurement, you may want to change the device. Getting a good gage R&R with a caliper can be very difficult.
optomist1
A Sea of Statistics
Well said, and in some circles, doing so is akin to "stacking the deck" for purposes of hopefully passing GRR, I have witnessed and stopped the same actions, when suppliers prepare to pass a customer witnessed PDR or Production Demonstration Run...aka Run At Rate
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
J Ignoring a Failed Gage R&R and upcoming external audit IATF 16949 - Automotive Quality Systems Standard 22
R Scaling a Gage R&R - 2 holding fixtures each with 10 nests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
apestate Inexpensive Gage Blocks for small aerospace startup shop General Measurement Device and Calibration Topics 1
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
