Gage R & R to different Specifications on Departmental Measuring Equipment
#21
I see where we went wrong. I misinterpreted your use of %PV as measurement variation as a % of Part Variation. The PV of 320% means that the variation of the parts in this study vary more than three times the tolerance. If this reflects your process, then it is not capable. %PV is not typically used to assess adequacy of the gauge. That is normally done using %Tolerance for an inspection gauge or %SV / ndc for a process control gauge.
SPC_Newbie
#22
Thanks Miner.
So what does %PV (for product control) mean to us? It is definately a common output that I need to understand and explain when reporting GR&R results.
Part of why I ask is that the %PV (for product control) seems to be at least a little counter intuitive. If I take my Rp and edit my tolerance such that it is equal to Rp/.75, assuming this gives me Cpk of 1.33, I get %PV = 188.7. I guess this makes sense as we multiply Rp x 1.887 (K3 for 10 parts).
So is 188.7 % a good value to have here??
I think I still understand that this number does not really determine if my gauge is adequate or not but yet it is commonly reported and is shown on the Components of Variation chart so I do need to put it in it's proper context - whatever that may be :)
SPC_Newbie
#23
I keep thinking on this one so I'll share my thoughts. I'm still of the mindset that 188.7 % is a decent number so that notion, if wrong, needs to be corrected.
Moving along - A common scenario I've seen in my data and data for GR&R's others have shared is that all of the graphs (typical minitab output) look very good. The only indicator of something gone awry is a %PV (product) that is very high (I'll consider anything above 200% high per my above above assertions).
Near as I can tell the main impact of a high %PV will be our %GR&R values appearing to be better than they really are (part variation being a significant contributor to TV which is used in denominator of our % Study calculations).
I'd say we could then use NDC to guide us towards considering how decent our results REALLY are (we do each of our GR$R's to assess both product and process control)
Do these things sound right? Would anyone use %PV for any other assessments of a GR&R?
#24
%PV is not really used when assessing gauge adequacy. I am not certain why it is even calculated at all. I can speculate that when they started calculating the percentages for Repeatability, Reproducibility and R&R, they got on a roll and kept on going.
The only thing you can really glean from it is when %PV is 75% of the tolerance or less, you MAY have a capable process, and if it is greater than 75%, you PROBABLY do not have a capable process.
SPC_Newbie
#25
So my math in #23 and approach to evaluating GR&R results above in #24 flawed or simply misses the mark?
#26
%PV = 6s/Tol and Cp = Tol/6s
Therefore; %PV = 1/Cp
If Cp = 1.33, %PV = 1/1.33 = 0.75
If Cp = 1.67, %PV = 1/1.67 = 0.60
If Cp = 2.00, %PV = 1/2.00 = 0.50
However, %PV is based on the variation of only 10 parts, whereas Cp should be based on 100 parts.
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
V Different gage values for assessment on as-is data and % data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
F GRR (Gage R&R) with Different Scales Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
C Functional Gages give different results - Thread Plug Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
Z How to handle MSA's (Gage R&R) for different parts? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J Conducting Gage R&R - 300 plug gauges - Different diameters - One for each plug gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
Geoff Cotton Minitab GR&R (Gage R&R) - Minitab is giving different results for distinct categories Using Minitab Software 4
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
