Gage R&R %Tolerance NDC
dsagario
Using %Tolerance on one of my GR&R study, I was getting a value of below 5 computation of NDC. My %GR&R was almost equal to one. Is the result of my study unacceptable overall or not? What is the significant of my NDC with respect to %tolerance computation?
ndc is closely associated with % Study Variation, but has no association whatsoever with % Tolerance.
Acceptability of the gauge depends on the use:
  • Process control: ndc, % Study Variation (or % Process in Minitab)
  • Inspection: % Tolerance
  • Dual Purpose (Inspection and Process Control): ndc, % Study Variation (or % Process in Minitab) and % Tolerance
If you have not found them , I recommend reading my blog on MSA.
bobdoering
Stop X-bar/R Madness!!
This is a great overview, however I will also add that 5<ndc<10 is only good for inspection, and that is should be greater than 10 for SPC (assuming the specimens statistically represent your process distribution.)
dsagario
Thanks Miner,
I am using the instrument only for inspection that's why I utilized the %Tolerance for my R&R study.
What would be the best reference or documents to show our auditors that NDC is insignificant on %Tolerance study. I can't see this on the MSA Manual. Can you please clarify what's the rationale behind the insignificance of NDC on %Tolerance?
Second, does the acceptance criteria for %total variation applies also to %tolerance like the %GR&R(<10%, 10-30%, >30%) ? what would be the difference?
Please enlighten.
The MSA manual is pretty clear that ndc is used as a measure of the adequacy of the gauge for process control. However, another approach would be to show the structure of the metric itself. ndc is simply a ratio between the process variation and the measurement variation. Tolerance is not part of the equation. While % Tolerance is a ratio between the measurement variation and the tolerance. Process variation is not part of the equation. The only time both would be used would be for a dual purpose gauge (inspection AND process control).
% Total Variation = % Study Variation. The criteria is the same (<10%, 10-30%, >30%).
bobdoering
This is why it is important when performing a gage R&R to present a true representation of the process variation to the study for the results of the study to be accurate. If you can not do this, and choose to use % Tolerance instead, your ndc will not be accurate.
The point of ndc is to give you an idea of the statistical (not readable) resolution over the range it will be used (supposedly the variation you supplied). ndc of 4, for example, means you are using a gage with a much resolution as a typical fuel gage in a car. AIAG is trying to say that it is not enough - although it is more than an attribute gage.
dsagario
You're correct Bob, but another problem that we encountered with the %Total variation GR&R, is the difficulty to obtain samples that would represent the whole spread of the tolerance. Since the gauge was merely used to inspect the incoming leadframes for the hole dimension with respect to the tolerance, we decided to use the %Tolerance.
Can anyone tell me why, in the AIAG manual/4th ed. page 129, it shows an example of ANOVA with ndc=4 and states "Measurement System is acceptable for process control analysis."?
I thought this was a clear distinction that anything less than 5 ndc was basis for NOT approving a system for process control.
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Gage R&R without tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
N Straightness Gage Tolerance General Measurement Device and Calibration Topics 0
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
J Gage R&R Study (Crossed) - How to determine Process Tolerance Using Minitab Software 4
P Strange Gage R&R results for a Caliper (Tolerance Method) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C P/T % of a gage R&R to 0 MMC Tolerance study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
W Gage R&R for gage pins used to inspect a hole ID called a Statistical Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Roundness Tester Gage R and R Frustration - Tolerance range of 20 microns Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
C Using a Pin Gage to check True Position of Inline Holes, Design, Tolerance. Etc Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Gage R&R - Percent of Tolerance or Percent of Variation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Accepting/Rejecting Threads WITHIN Gage Tolerance General Measurement Device and Calibration Topics 2
P Out of Tolerance Gage - Justification for not Recalling Product Misc. Quality Assurance and Business Systems Related Topics 7
M Honest GR&R (Gage R&R) Tolerance Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A %Total Variation & %Tolerance - Differences in Gage R&R Forms and Templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Gage Resolution vs. Tolerance Manufacturing and Related Processes 5
B Addressing Lots that were measured with Out of Tolerance Gage Pins Nonconformance and Corrective Action 5
R % Gage R&R Based on Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
C Gage R&R 10:1 Tolerance to Gage Discrimination Rule Explanation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Jerry Eldred Downgrading Tolerance on Gage Block Set General Measurement Device and Calibration Topics 5
D Part Variation, Unilateral Tolerance, Destructive Testing - Gage R&R Experts pls help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
N Gage R&R - Tolerance - APQP Forms Disk from the AIAG - Formulas IATF 16949 - Automotive Quality Systems Standard 3
smryan Gage R&R Tolerance - Manufacturer's stated tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q Part Tolerance and Equipment Accuracy of thickness gage General Measurement Device and Calibration Topics 1
I Gage Error vs. Dimensional Tolerance - Accuracy needed for measurement equipment Measurement Uncertainty (MU) 10
Q Tolerance Set Plugs to Calibrate Thread Ring Gage - Question General Measurement Device and Calibration Topics 4
C Gage R&R @ 10% - Does that mean you should cut your tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
0 Gage R&R Total Tolerance question - Use the full process tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
D Gage Out of Tolerance Procedure Document Control Systems, Procedures, Forms and Templates 3
B Calibration Accuracy vs. Gage/Part Tolerance General Measurement Device and Calibration Topics 4
P Calculating Gage R&R with Part Tolerance instead of Total Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
N Gage R&R - Using Tolerance method, or part to part variation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O Gage R&R when using Tolerance - Really bad Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
D One-Sided Tolerance Gage R&R Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Y Gage R&R - Calculating by Specification Tolerance vs. Study Variation - Differences Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R Setting Calibration Tolerance on Gauges - Oven Calibration and Stepped Plug Gage General Measurement Device and Calibration Topics 10
M Gauge (Gage) R&R study - Samples required from full tolerance spread? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Destructive test, gage R&R with one sided tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G How to complete gage R&R when you have only a single sided tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
D Best Gage R&R (GR&R - GRR) Method for Product Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
U How do part tolerance and gage tolerance interact? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
R Gage Tolerance vs. Process Parameter Tolerance - Process qualification Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Gage pin clearance on close tolerance - Hole size is ?.8746 ? .0001 General Measurement Device and Calibration Topics 9
P Gage R&R - What does the % tolerance says about my Gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R What does the P/t ratio (Precision/Tolerance) =RR/(USL-LSL) say about my gage study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
G Tolerance vs Total Variation in Gage R&R report - MSA 3rd edition pg. 116 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
B ANOVA Gage R&R % Tolerance and Preference Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E Full Scale Tolerance - How to apply full-scale accuracy specification to a gage? General Measurement Device and Calibration Topics 4
