Gage R&R with 3 people 10 parts 12 positions on each part
biker6977
Can I do a guage R&R with 3 people, 10 parts, checking 12 positions on each part?
Seems all the gauge R&R sheets I find use up to 10 pieces but one position on each piece.
These are simple round flat parts. We check, OD, ID and thickness. We check thickness in 12 locaions as required by the customer.
1. can I do a R&R this way?
2. if not, what do I need to do to show that how we measure is a good method?
Thanks,
Caroline
Hershal
Metrologist-Auditor
Re: 3 people 10 parts 12 positions on each part
To me it seems that would not be a limiting issue, but others here will contribute also.
biker6977
Do you happen to have or know where I might find a gauge R&R sheet that would allow this?
bobdoering
Stop X-bar/R Madness!!
What you are really doing is 3 persons 120 parts (You have to look at each position as a different part. They are NOT repetitions.) Then, you need to determine the number of repetitions. SPC XL can do this.
This is not a standard MSA, and I doubt that you will find a file with which to analyze it. However, it can be analyzed using ANOVA. Location would be WithIn part Variation (WIV), and can be evaluated separate from R&R.
If you have already run this, please attach your data and I will analyze it for you.
biker6977
THANK YOU!:applause:
You'll see off to the side I was comparing the operators.
I have 2 more people I'd like to add to this to compare all the people in QC. would this be done the same?
bobdoering
Attached is the data that was calculated as 3 operators 120 parts (10 parts 12 positions) and 1 repetition. This is only accurate if the 12 locations on each part were accurately marked so that each operator hit the same spot as the other operators. Otherwise the variation you detect is from measurement error and not from the gage error itself.
biker6977
All parts were marked with location 1,2,3 etc.
Thanks so much!
Attached is my analysis. Since you have no repeats, I analyzed it using Minitabs Gage R&R routine. However, there is no Repeatability. Instead you have within part variation (WIV), which does have a repeatability component within it.
To separate Repeatability from (WIV), you would have to repeat the same study on the same parts in the same locations with the same operators. Then an ANOVA would be able to separate Repeatability, Reproducibility and (WIV).
Miner is correct. if you don't have each operator repeat each measurement (randommly without knowing what value they got the first time they measured that part and location) we cannot determine measurement error. Nor can we adequately assess within piece variation vs. simple error.
Repeatability (can the same operator get the same result on the same part/feature/location) twice) is the first R in R&R.
Without knowing that repeatability is small, reproducibility (the difference between operators) is a relatively meaningless calculation - unless the difference is really large.
S Gage R&R on Potentially Changing Parts - Guidance Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D 5 vs. 10 Parts for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Minimum number of parts to do an attribute gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
L Correct Sample Size for Attribute Gage R&R (Good / Bad parts) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
H Gage R&R Data Collection Form w/ Appraisers Names, Number of Parts, Number of Trials Document Control Systems, Procedures, Forms and Templates 2
Z How many parts to measure in a Gage R&R study Quality Tools, Improvement and Analysis 5
H Gage R&R - No Repeats - Parts measured by my company and an outside supplier Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Gage R&R for Big Parts - Approving a Variable Gage using only 1 Part Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
C Interpreting Gage R&R Results - 3 operators, 3 iterations and 10 parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
N Correlation of Gage R&R Value with the Measured Value of Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K Alternatives to GR&R (Gage R&R) - Only 4 sample parts and one operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 22
C Gage R&R Study - Better to use parts or gage blocks? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
G Gage R&R Procedures: Selecting parts (sample) to measure Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
I Measurement Systems Analysis (Gage R&R) - # of Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Z How to handle MSA's (Gage R&R) for different parts? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R Destructive Attribute Gage Studies - inserted/pressed in parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Gage R&R form for 2 operators 10 parts and 3 trials needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K Difference a gage can detect - Similar Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
G Gage R&R: Selecting Number of Trials and Appraisers and Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
L Creation of Sample Parts to perform Gage R&R - Go/NoGo to Check Threading Operation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
J What kappa value to use for Gage R+R (Gage R&R) study with > 10 parts? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Calibration required? We buy part of our machined parts - Supplier gage calibration? General Measurement Device and Calibration Topics 6
A GR&R - Gage R&R for 1 test Stand, 10 locations, 10 parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q Gage R&R lite? This form only uses two operators measuring five parts one time Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
T Parts used for Gage R&R's Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Z Gage R&R for sorting gage - Leaktester to inspect for leakrates on parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B Stability study- Plastic injection molded parts with fixture gage & digital indicator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Gage R&R Study - Marking Parts, Number of Parts and Number of Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
