Gage R&R with CMM 1X1X10
  • Thread starter Mary - QA Manager
  • Start date
Mary - QA Manager
My new assignment is to run a gage R&R on one part with one operator ten times (1X1x10) on CMM.
I found an excel sheet from this site not sure what all the figures mean.
That's for your help!
Mary
  • GRmaster1.xls
Englishman Abroad
Mary,
If you do not understand the sheet, I suggest you look at Miner's blog on MSA.
Look in blogs on the Menu bar at the top of the page and search for Miner.
Johnson
Dear Mary,
In fact, the calculation in the Excell sheet is not Gage R&R. It is another capability index of measuring equipment Cg=(Upper tolerance-Lower tolerance)/(5.15 *standard deviation). Cgk is another index. Here 5.15 can be defined differently based on the measuring equipment requirements. Both Cgk and Cg measure 1 part (or master sample) by one operator for a certain times, for example 10 times at your example.
For Gage R&R , it normally need 10 parts, 3 operators, each operators measuer 10 times.
I would suggest you should read AIAG's MSA manual, or VDA 5.
Johnson
Mary - QA Manager
Thanks for your reply. I went back to the customers requirements just to make sure I understand what it is they are looking for.
"CMM gage studies must be carried out on 1 part, inspected 10 times by I worker or inspector using the following calculation formula:
% of repetability=100%(maximum range/tolerance band)
I am not that well versed with excel to create such a sheet. I have asked my customer for a sheet but they do not have one.
Thanks!
Mary
Johnson
For example, the part tolerance is 10+/-0.5 mm, then the tolerance band =10.5-9.5=1.0
If the 10 measurements are:
9.6 9.8 10 10.2 10.4 9.6 10.1 10.2 9.7 10.2,
the the maximum range is (max -min)= 10.2-9.6=0.6
% of repetability=100%(maximum range/tolerance band)=100%(0.6/1.0)=60%.
Then questions again:
1) What the requirements of the measuring equipment capability, is <10%, or <50%, <80%?
2) The customer must tell if the above interpretion is correct or not.
Johnson
I tried the Excel sheet you attached.
The principle is correct, but the criteria is very high ! You should consider if it is suitable for your company.
I attached the example for your reference.
  • GRmaster example.xls
Mary - QA Manager
Please take a look at the newest spreadsheet...
Mary
  • Gage R Form 1-1-10.xls
Johnson
Looks good ! If the customer agree with it, you can use it. I mentioned customer for several times, because you see the calculation and the factor could be different. Here the 6 is a factor, but some customer may chosen to use 4, or 5.15>
Part % R = (Standard Deviation x 6 / Part Tol. Range) x 100
JAltmann
Mary
That is the typical formula/study sometimes referred to as a P/T Ratio. The 6 sigma follows the change with MSA 3rd (or 4th?) edition. This is a good test not just for CMM's but also for reference before performing a full GR&R as if you can't pass this test then the GR&R will be worse and the time wasted.
Most strive for a value outcome of under 10% for this test to be considered passing, but this should be discussed internally and with your customer (SQE typically).
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
F Comparison of 2 CMM machines using Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
K Gage R on a 10 Piece Sample with a CMM using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
V Gage R&R for Variables Data on a CMM (Coordinate Measurement Machine) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Does a CMM (Coordinate Measuring Machine) require Gage R & R study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
R MSA - GRR (Gage R&R) Requirement for CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
S GR&R (Gage R&R) on a CMM (Coordinate Measuring Machine) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
B Attribute GR&R (Gage R&R) using a CMM (Coordinate Measuring Machine)? General Measurement Device and Calibration Topics 3
R Calibration of a portable FARO gage portable CMM # F04L2 gauge General Measurement Device and Calibration Topics 6
A Gauging method comparison - Air Gage vs. CMM Measurement General Measurement Device and Calibration Topics 9
Q Certifying Gage Blocks on an In-House CMM (Coordinate Measuring Machine) General Measurement Device and Calibration Topics 19
A Qualifying a CMM Star Probe - Brown/Sharpe CMM Model Gage 2000 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
R How to Determine CMM Gage R&R - Accuracy, Repeatability, Reproducibility? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Questions About CMM (Coordinate Measuring Machine) Gauge (Gage) R & R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
A Gage R&R - Repeatability and Reproducibility of a newly bought CMM machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
G Gage Calibration - Using a CMM and Gage Blocks for In-House Calibration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Environmental standards for Gage and CMM laboratory General Measurement Device and Calibration Topics 1
T Seeking Spreadsheet for CMM (Coordinate Measuring Machine) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Gage R&R on a Manual CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T Gage R (Not Gage R&R) Formulas for CMM Layout Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Is it OK to do a Gage R&R With A CMM? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Measuring ID's: Which is the most accurate? CMM / Sunnen Gage / Plug Gage? General Measurement Device and Calibration Topics 3
rivariva Number of decimal places : Gage R and R Using Minitab Software 1
J What Device Should I use for Gage Study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G Minitab formulas regarding anova gage r&r Using Minitab Software 1
T Borescope Mentor Visual IQ Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Gage R&R IATF 16949 - Automotive Quality Systems Standard 2
D HELP gage card not popping up Using GAGEpack Software 2
F How often should Gage R&R's be updated? Is there a recommended time-frame? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
W What is dimensional layout of the gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Q Does a gage used for a visual verification need to be calibrated? Manufacturing and Related Processes 7
T Gage Numbering Using GAGEpack Software 6
S Gage R&R for inline measuring machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B Gage calibration Gonogo (calcul of cgk) General Measurement Device and Calibration Topics 0
PastorBee13 Attribute Gage R&R with no bad samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
H Air Pressure Gage Calibration General Measurement Device and Calibration Topics 6
M Spot Weld Nugget - MSA Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Gage type and data base maintainence Using GAGEpack Software 2
F Should I perform several Gage R&R for every caliper to cover all specs range of use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T Gage R&R study - Ordinal data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Q Gage Pin Sets? Calibrate/Verify them all or just a sample size? General Measurement Device and Calibration Topics 22
S If 4 operate to measure, what is the value of k2?(MSA gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Faro Arm, Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Gage Block Grade 1 - Calibration Measurement Uncertainty (MU) 15
R Gage Measuring 15 Parts at a Time Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Q Gage calibration in disarray ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Gage R&R automated test equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
PQ Systems Recipe for Success! 10 Ingredients for a Healthy Gage Management System Using GAGEpack Software 0
D Gage Repeatability for Faro Arm Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
