Gage R&R without tolerance
Jafri
Can a GR&R study be done in something which does not have any tolerance associated, for example, number of leaks?
Thanks.
Can you provide additional detail about the test? Measurement of count (Poisson) data might require a different approach than usual. If the typical count measurement is > 10, the Poisson distribution closely approximates the normal distribution and you might be able to perform a standard R&R. However, the integer nature of the data could also cause a resolution problem.
In general, you can perform an R&R study and evaluate it as a percent of the study variation, or of the process variation. This would be typical if the measurement device were to be used for process control or any type of statistical study.
Jafri
In this leak test, water flows through passage ways in the part, and then number of leak points are (carefully) observed.
Leaks found are usually no more than 3, so I guess the Poisson approximation will not work.
But in this case, can I use 0 as tolerance (0 = no leak).
Are you referring to what Minitab calls "Total GR&R %SV"? Criteria being: >30% fail, <10% pass.
Thanks.
You may be over thinking this. Unless you are just looking. To the check the box for a Customer, think about what you really want to know about the leak testing process. There are two critical components to the effectiveness of the test: the inspector’s ability to ‘observe’ a leak, and the test method’s effectiveness of initiating a leak without creating a leak that wouldn’t happen naturally in use.
Leak testing is often not destructive but it is a ‘functional’ Test and so we must use different approaches than the standard AIAG approach. Just in general I would gather several pieces that leak and dont’ leak. Then test them TWICE with each of 2-3 inspectors. Then simply look at cross tabs for each inspector. Even a graph at this point is probably overkill. Things to look for: does the test method repeat leaks and non leaks. Does each inspector repeat within themselves and then are the results replicated across the inspectors? How many pieces you use are flexible. Try to get enough pieces and a good proportion of leakers to non leakers that the inspectors won’t remember what they saw. You can help this by testing the second round a couple of days after the first round...
You might find this paper on MSA for Functional Tests helpful. There is a section on water leak testing for cars :cool:
Thanks.
Yes, %SV = % Study Variation. You can also use a historical standard deviation to obtain %PV = % Process Variation.
In this particular scenario, I would agree with Bev's comments. If you wanted to stick with a more formal approach, you could perform an Attribute Agreement Analysis and use Kendall's coefficient for ordinal data.
stevegyro
What BEV says!
She nailed it.
Forget Poisson, Chebychev, and the fancy math [emoji854].
Looks like attribute testing. Follow what she says, IMHO.
Sent from my iPhone using Tapatalk
A Gage R&R without Operators (using Sensors) using Minitab Using Minitab Software 2
O Destructive Attribute Gage R&R without LSL/USL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Measuring Countersink Depth without the use of an expensive gage General Measurement Device and Calibration Topics 3
Rameshwar25 Gage R&R Anova - With Interaction or without Interaction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Determining Repeatability without Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 22
A GAGE R&R Binomial with master list (for method validation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Q Gage calibration / tracking software General Measurement Device and Calibration Topics 5
A R chart from ANOVA gage R&R test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Type 1 Gage r study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
