Gage Tolerance vs. Process Parameter Tolerance - Process qualification
rstaz
Hello! This is my first post, I hope I am doing this right :)
I am running a process qualification. We will be looking at the best and worst case processing parameters. So, let's say I will be testing temperature at 180 and 190. One team member said that if the calibration tolerance of the controller is +/- 2, then after qualification, I must run production at 182 - 188. That's to ensure we are in the qualified window. Has anyone else taken this approach? I would be concerned about this if the calibration tolerance were large.
I am thinking about suggesting that we try to keep the calibration tolerance 30% or less of the process parameter tolerance--similar to a GR&R.
Any suggestions??
Thank you,
Renea
G
Graeme
Accounting for measurement uncertainty
Renea,
Welcome to the Elsmar Cove! Dive in and enjoy!
I'm making an assumption that what you are calling the "calibration tolerance" of the controller is its performance or acuracy specification - what I would use to determine if it passed or failed the calibration performance test. If that is correct, then ...
If the controller indicates 180, accounting for the accuracy means that all you can sure of is that the temperature is somewhere between 178 and 182. Likewise, a reading of 190 means that you are sure the temperature is somewhere betweeb 188 and 192. That would be the reason for keeping the controller somewhere between 182 and 188. If it is within that range you can be sure the temperature is within your limits of 180 to 190 even if the controller is off by + or -2.
This type of thing is actually fairly common. The 2 degrees you are eliminating on either end is called a guardband. In the calibration business we deal with that and other areas of measurement uncertainty all the time. For example, that controller would need to be calibrated using a temperature simulator with an accuracy of +/- 0.5 degree or better, and the test limits for us to say it is good would actually be +/- 1.5 degrees.
As for improving the performance of the controller - it is most likely that the temperature sensor attached to the controller is a thermocouple. If that is correct, then the thermocouple is probably the source of about 75% of that +/- 2 uncertainty, and there is very little you can do about that. That's just the way thermocouples are. Replacing the controller with a "better" one will only increase the cost of getting it calibrated.
rstaz
Thanks, Graeme. I guess my problem was the fact that by accounting for the calibration uncertainty by narrowing the process window in production, you are increasing the ratio of calibration error to process tolerance. It makes me think it is similar to increasing the error in a "Gage R&R". I certainly see the logic, however. Thanks for your reply!
Renea
Renea
You will not change your ratios because you do not change your tolerance.
If you have access to the AIAG MSA manual, it has a discussion on gage performance curves. These curves have three zones: 1) A good part will ALWAYS be called good; 2) A bad part will ALWAYS be called bad; and, 3) where good may be called bad and bad may be called good.
Graeme's guard banding is established around the first zone. This does not change the tolerance, but will ensure that you do not ship bad product due to measurement error (maybe for other reasons, but not this one).
J Gage R&R Study (Crossed) - How to determine Process Tolerance Using Minitab Software 4
0 Gage R&R Total Tolerance question - Use the full process tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
J Gage R&R - Tolerance vs. Total Variation - Process Variation vs. Gage Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Gage R&R without tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
N Straightness Gage Tolerance General Measurement Device and Calibration Topics 0
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
P Strange Gage R&R results for a Caliper (Tolerance Method) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C P/T % of a gage R&R to 0 MMC Tolerance study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
W Gage R&R for gage pins used to inspect a hole ID called a Statistical Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Roundness Tester Gage R and R Frustration - Tolerance range of 20 microns Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
C Using a Pin Gage to check True Position of Inline Holes, Design, Tolerance. Etc Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Gage R&R - Percent of Tolerance or Percent of Variation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Accepting/Rejecting Threads WITHIN Gage Tolerance General Measurement Device and Calibration Topics 2
P Out of Tolerance Gage - Justification for not Recalling Product Misc. Quality Assurance and Business Systems Related Topics 7
M Honest GR&R (Gage R&R) Tolerance Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A %Total Variation & %Tolerance - Differences in Gage R&R Forms and Templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Gage Resolution vs. Tolerance Manufacturing and Related Processes 5
B Addressing Lots that were measured with Out of Tolerance Gage Pins Nonconformance and Corrective Action 5
D Gage R&R %Tolerance NDC Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R % Gage R&R Based on Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
C Gage R&R 10:1 Tolerance to Gage Discrimination Rule Explanation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Jerry Eldred Downgrading Tolerance on Gage Block Set General Measurement Device and Calibration Topics 5
D Part Variation, Unilateral Tolerance, Destructive Testing - Gage R&R Experts pls help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
N Gage R&R - Tolerance - APQP Forms Disk from the AIAG - Formulas IATF 16949 - Automotive Quality Systems Standard 3
smryan Gage R&R Tolerance - Manufacturer's stated tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q Part Tolerance and Equipment Accuracy of thickness gage General Measurement Device and Calibration Topics 1
I Gage Error vs. Dimensional Tolerance - Accuracy needed for measurement equipment Measurement Uncertainty (MU) 10
Q Tolerance Set Plugs to Calibrate Thread Ring Gage - Question General Measurement Device and Calibration Topics 4
C Gage R&R @ 10% - Does that mean you should cut your tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D Gage Out of Tolerance Procedure Document Control Systems, Procedures, Forms and Templates 3
B Calibration Accuracy vs. Gage/Part Tolerance General Measurement Device and Calibration Topics 4
P Calculating Gage R&R with Part Tolerance instead of Total Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
N Gage R&R - Using Tolerance method, or part to part variation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O Gage R&R when using Tolerance - Really bad Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
D One-Sided Tolerance Gage R&R Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Y Gage R&R - Calculating by Specification Tolerance vs. Study Variation - Differences Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R Setting Calibration Tolerance on Gauges - Oven Calibration and Stepped Plug Gage General Measurement Device and Calibration Topics 10
M Gauge (Gage) R&R study - Samples required from full tolerance spread? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Destructive test, gage R&R with one sided tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G How to complete gage R&R when you have only a single sided tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
D Best Gage R&R (GR&R - GRR) Method for Product Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
U How do part tolerance and gage tolerance interact? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S Gage pin clearance on close tolerance - Hole size is ?.8746 ? .0001 General Measurement Device and Calibration Topics 9
P Gage R&R - What does the % tolerance says about my Gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R What does the P/t ratio (Precision/Tolerance) =RR/(USL-LSL) say about my gage study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
G Tolerance vs Total Variation in Gage R&R report - MSA 3rd edition pg. 116 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
B ANOVA Gage R&R % Tolerance and Preference Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
