GAMP CAT 5 Change Control
diogo19
I have a custom built ERP that requires a minor admin change to text heading,
This system is validated as GAMP CAT 5,
I've created a change control for the proposed change and modification but the change control doesn't have a risk assessment,
Can this change proceed without the system/software version number updating ?
Hi, Diogo,
You don`t need to do this change, because this is a general adjustment for the ERP software function. Therefore, My suggestion is that the ability of ERP software to satisfy the intended application shall be confirmed prior to initial use and reconfirmed as necessary.
diogo19
Hi, Diogo,
Thanks for the reply,
Just to confirm, the ERP software has been in use for many years,
Usually, major changes or a collection of changes (e.g minor) would be captured in a new validation which updates the software version number,
How can I justify that is a 'general adjustment' without it affecting the intended use of the system ?
I thought for CAT 5 systems anything that's modified would need to be processed through change control.
yodon
First, let me work over this statement:
All changes should be managed through some kind of change record (with risk assessment - which you indicated in the original post). The version number changes after one or more changes are implemented and the system is released. Validation confirms the system is still working after the changes.
I'm curious why a system that has been in use for many years now requires a change to the text heading? Why can't this wait until other changes are implemented?
And why can't you do a risk analysis on the change? Sounds like it should be pretty low risk!
I wouldn't release any change without some change to the version identifier. Most systems have a 2 or 3-tiered release identifier; e.g., "<major>.<minor>" or "<major>.<minor>.<patch>". If it's absolutely necessary to release this minor administrative change now, I would at least do something like "x.1" (where 'x' is your current version). You just never know. You could be using a new compiler version that compiles unchanged code differently, you could be pulling in changed runtime libraries when you build that could drive a different behavior, etc.
diogo19
Hi Yodon,
I should have been more clearer,
The change is to template wording that is stored in the ERP and no code changes are modified that would have impact,
Would I still need to update the version identifier because of this ?
The change control I work with is very basic and needs the introduction of a risk analysis.
yodon
Apologies, but I'm still not completely clear on what exactly is changing. Do you have to rebuild (compile) the software? If so then I suggest the version number be incremented. If this change is to a form that you store in the ERP system then I would think you would change the version of the form.
In fact, it is just a general change. because you only will modify its text heading. You should be processed by change control as per the CAT 5 system, and remain related change records would be ok.
diogo19
Hi, so I just found out the change is to the HTML of a pdf form stored in the ERP, no rebuilding of code was impacted, in your opinion would that warrant a version number increment ? or would you simply risk assess in the change control and specify it has no impact ?
diogo19
Thanks, what are your thoughts on updating HTML in the template , is that considered a general change ?
P Identifying GAMP Classification: GAMP 4 or GAMP 5 ISO 13485:2016 - Medical Device Quality Management Systems 1
R Only Commissioning Software? COTS, GAMP Category 3 Software Validation Requirements IEC 62304 - Medical Device Software Life Cycle Processes 7
C Software Program Development GAMP Requirements Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
R GAMP (Good Automated Manufacturing Practice) simplified please. Quality Manager and Management Related Issues 3
N Medical Device which is both Class I & CAT III PPE CE Marking (Conformité Européene) / CB Scheme 6
Marc Putting the Cat Out - Love Your Cat Funny Stuff - Jokes and Humour 8
Marc Cats - Egypt to Today - Scourge or 'Friend'? Pls - No More Cat recipes! Coffee Break and Water Cooler Discussions 100
S Change in material vendor - Medical device ISO 13485:2016 - Medical Device Quality Management Systems 2
JoCam Change of Legal Manufacturer EU Medical Device Regulations 2
Sidney Vianna Informational ISO/TS 10020:2022 Quality management systems — Organizational change management — Processes Other ISO and International Standards and European Regulations 0
0 Complaints time series significant change Customer Complaints 41
N Malaysia Shelf Life Change Other Medical Device Regulations World-Wide 2
P Self Certified Class 1 MDR 2017/745 Design Change CE Marking (Conformité Européene) / CB Scheme 2
O Article 120 - significant change interpretation EU Medical Device Regulations 4
V Would the customer drawing change necessitate re-PPAP of the Product? APQP and PPAP 3
S Do we have to create a new PPAP to our customer if our Sub Contractor had to change? APQP and PPAP 10
M PMA submission change Medical Device and FDA Regulations and Standards News 0
U Change to the manufacturing Date for a device in the field US Medical Device Regulations 0
F Change in address for critical supplier - does NB need to be informed? CE Marking (Conformité Européene) / CB Scheme 20
K Change in address on ERLM US FDA: Implications to import US Medical Device Regulations 0
N Change our Registrar? Pros and Cons ? Registrars and Notified Bodies 8
F Using non-randomized clinical study for change in existing 510(k) device? US Food and Drug Administration (FDA) 1
FuzzyD ISO 13485 change in process ISO 13485:2016 - Medical Device Quality Management Systems 3
R IVD Label Change China Medical Device Regulations 1
Judy Abbott Change of PVC stabilizer Japan Medical Device Regulations 6
R IVD Label Change Requirements Other Medical Device Regulations World-Wide 0
M EE's - Laptops/Printer Change and Emissions Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
D Document Change Approval ISO 13485:2016 - Medical Device Quality Management Systems 6
mtmt70a Change\ my MTBF Prediction SW Tool from the RELEX tool with yearly Lic. access Telecordia database to another solution. Recommendations? Reliability Analysis - Predictions, Testing and Standards 0
S Can a product option change the product class? CE Marking (Conformité Européene) / CB Scheme 2
M Regulatory Change assessment US Food and Drug Administration (FDA) 3
G Software change management Design and Development of Products and Processes 3
J Changes to OS - Significant change under MDR EU Medical Device Regulations 8
A If document coding is change will there be a revision Document Control Systems, Procedures, Forms and Templates 1
G Change Control for Test Samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Z Change color or shape of individual data point in control chart Using Minitab Software 6
J Medical Device Component Change - Testing, Sampling Criteria ISO 14971 - Medical Device Risk Management 3
S When to change the status of a GTIN from "Premarket" to "In Use" ? US Medical Device Regulations 2
Y Is there any EU Significant change guidance issued? EU Medical Device Regulations 5
B How to change hour format to text but not changing the number ? Excel .xls Spreadsheet Templates and Tools 1
N API Q1, Management of Change & Document Change Request Oil and Gas Industry Standards and Regulations 4
adir88 Substantial Change to QMS (Annex IX, Chapter I) EU Medical Device Regulations 0
A Eudamed actor registrations if you change AR for MDR product EU Medical Device Regulations 0
C Change Management Process ISO 14971 - Medical Device Risk Management 8
S ISO13485:2016 7.3.9 design and development change ISO 13485:2016 - Medical Device Quality Management Systems 3
N Change Control for processes & products Manufacturing and Related Processes 7
Quality Specialist Change Control Numbering system Document Control Systems, Procedures, Forms and Templates 7
D Laboratories listed in the Declaration of Conformity change Canada Medical Device Regulations 1
M Change control on Tracking Sheet ISO 13485:2016 - Medical Device Quality Management Systems 11
D EU MDR - Change of device name (legacy device) EU Medical Device Regulations 17
