Gauge Analysis with 2 Complimentary Measurements
DivingDoug
Hi all,
I am relatively new to the world of MSA (< 1 yr) and, with training options being stifled by the corporate monster, am having to learn as I go.
I am completing a gauge study on a piece of equipment that will ultimately measure only a single characteristic on a finished good and completing the MSA on that aspect of the equipment is pretty straight forward. In a one-time setup up the equipment however, there are two other characteristics that need to be confirmed to be consistent.
To set this up, I am essentially recording a pressure level and a vacuum level during a single sequence. I have completed a standard run of 15 parts, 3 operators and 3 repetitions for 135 sequences. For each sequence, I have two results, pressure & vacuum.
I need to determine if there is a method to incorporate both of the results into a single study as there is not necessarily a direct correlation between the two values but if one value is out of range, the entire sequence then is a fail regardless of the other value. I also have a fear that I will not achieve the desired number of categories but am not sure how to combat this as I have no access to a device to measure to a higher resolution.
Note that the study is being completed on the equipment creating the backloads, not the device making the measurements (A Beta calibration device that has a valid calibration)
I have attached the actual data for reference.
Any help is appreciated
Doug
Barbara B
Re: Gauge analysis w/ 2 complimentary measurements
The factor which affects the result (either in pressure or in vacuum) most, is the operator, so irrespective of the combination of both measurements, the measurement system is poor. (And you're right: The number of distinct categories is ndc=1 for both.)
To combine two uncorrelated measurements into one figure you can use a desirability function which gives a number between 0 (not desired at all) and 1 (jackpot) instead of two or more results like pressure and vacuum. You can find more details in the online engineering and statistics handbook (5.5.3.2.2. Multiple responses: The desirability approach). This method is used mainly with optimization in design of experiments, but could easility be adopted to your measurement analysis.
Best regards,
Barbara
M An Honest Gauge R&R Analysis - Proposed usage of Donald Wheeler Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
D Gage R&R On Pass Fail Gauge - Photograph Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B Destructive Gauge R&R Sample Sizes - Does ANOVA work better for the analysis? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Gauge R&R Question Using Minitab Software 1
J Gauge Suggestion: Specialty or Custom General Measurement Device and Calibration Topics 1
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
F Gauge R&R & Calibration Intervals Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
S Gauge R and R - Product - Conveyor belt with threads that goes on Sprocket Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Radius Gauge R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
S Pressure Gauge Calibration Uncertainty Calibration and Metrology Software and Hardware 5
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
Ron Rompen Gauge Design Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Gauge CAD certification to Part CAD vs. Gauge certification to Part CAD General Measurement Device and Calibration Topics 1
shimonv Feeler Gauge as a Medical Device Accessory EU Medical Device Regulations 3
C Proper Thickness Gauge for Foam/Felt and Soft Materials General Measurement Device and Calibration Topics 5
J What kind of Tool and Gauge in IATF 16949 Clause 8.5.1.6? IATF 16949 - Automotive Quality Systems Standard 1
alonFAI Gauge R&R for a Peel Tester (tensile tester) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
V Why Gauge R&R 10% is acceptable for variable instruments ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
C How to perform Gauge R & R on Automated Test & Measurement Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
V Inactive Gauge Retention Time - PPAP Section 6 Requirements APQP and PPAP 1
Q Pin Gauge Setup - Measuring the OD of a Catheter Manufacturing and Related Processes 1
kedarg6500 Availability of 5/8" 17.75 TPI Thread Ring Gauge & Die Nut Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
