Gauge R and R - Product - Conveyor belt with threads that goes on Sprocket
ShadowThe
Hello Everyone,
I have to find best way to measure pitch of the threads on the conveyor belt.( By using Variable Gauges or attribute gauges)
And also prepare plan for Gauge R and R for that Measurement method.
Could you please share your ideas.
It would be very helpful.
Thanks in advance.
I am not familiar with that product, but in general, a variable R&R study will require fewer measurements than an attribute study and provide more precise information identifying the source of any measurement problems. How do you currently measure it? If you find a better measurement method, do you intend to change to the new method?
ShadowThe
They are measuring pitch (39mm) of the threads on back of timing belt.
Currently they are using calipers with customized fixtures.
But they want to find a better measurement for consistency.
ShadowThe
Thanks Miner!!
This is my first task
I want to give them as many options as possible
1)
They have smaller ones too
Like belts with thread tolerances of 0.039+_0.04
Any other option?
2) And they are performing Gage R and R with only good parts(threads)
I am concerned that it will be biased
Will it be a problem?
John Predmore
Can you share a portion of the engineering drawing of the feature you want to measure? A drawing or sketch with dimensions would give people an idea of the scale and geometry you are working with. In your first post you said conveyor belt, in the second you said timing belt. I have a different mental picture of those two belts, and my advice might not be helpful if your belt is very different in size or configuration.
The selection of a method will depend on a lot of things, like how many of these you measure in a day or how much money you are willing to spend.
What exactly is the difficulty with the current method (calipers with custom fixturing)? Maybe the design locates the dimension on a virtual feature, like a pitch diameter, and finding a virtual point consistently with handheld tools may not be practical. Taking measurements on elastomer features can also be a challenge because contact forces deform the rubber. So perhaps you should consider non-contact methods. There are many optical technology methods, staring with a comparator. If the belt is molded you may be dealing with flash, parting lines or other molding variation which is a different complication.
You could improve the results by measuring the pitch across more threads and dividing by the number of threads.
Regarding using only good parts: It depends on whether you are interested in %Tolerance or %Process Variation. If you are measure to a specification to determine whether parts are good or bad, use % Tolerance, and don't worry about part selection. If you use the gage to control the process (i.e., SPC), use %process variation and select parts that represent the typical variation from the process.
ShadowThe
Thank you so much sir!
Sorry for the confusion
1) Attached image is one of the type. It is extruded ones.
2) They are measuring it with calipers with fixtures that goes on two threads which gives pitch distance
problem: Fixtures are not sitting on the teeth when they are measuring ( gap between teeth and fixture)
I have to redesign it or suggest new method which will be consistent.
If i have to redesign could you please suggest some material which can help.
or could you sugest some new methods
3) Gage R and R
How to plan Gage R and R on this type of product. How to take samples ( Teeth of belt).
They did Gage R and R with caliper with fixtures.
but they did not take bad parts.
If I am thinking wrong about this could you please let me know
John Predmore
I suggest an optical comparator. From the drawing it looks like you are able to lay the belt flat so the pitch dimension is horizontal and a linear length, not a curved distance (maybe using weights to hold the circular belt in a flat plane). I commented earlier that virtual features can be difficult to measure consistently with handheld tools. The center of the tooth (maybe you call it a thread), which is the start and stop of the dimension, has no physical feature on the part to align the caliper blade against. The centerline of the tooth can be located on a comparator with some arithmetic; if you have an optical measuring device with software the centerpoint of a edge can be identified automatically. If your customer or design team is willing to consider an print change, it is the outside surface of the tooth not the centerline which is the functional feature. If the teeth are symmetrical and uniform in shape, the distance from the corner of the first tooth to the same corner of the second tooth is equal to the distance on centers. Using an optical system you could also measure the distance along the pitch plane, which is truly the functional dimension of a spline or gear-form.
If you still want to use calipers, maybe you can measure the distance from fillet at the root of one tooth to the opposite fillet on the next tooth. That would be pitch distance plus one tooth width, but it would be easier to measure with calipers than a corner which is not a right angle, and therefore more consistent. Subtract the tooth width, measured the same way, if you must have the pitch dimension.
GRP
3) Gage R and R
The characteristic is 1.956 +/- 0.005 what? If the units you are using are mm, forget about it.
Kindly share if the units are mm for further comments.
C GR&R of a gauge to check a new feature of a new product Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Out Of Tolerance Gauge And Holding Back Quarantined Product Misc. Quality Assurance and Business Systems Related Topics 7
C Gauge R&R Question Using Minitab Software 1
J Gauge Suggestion: Specialty or Custom General Measurement Device and Calibration Topics 1
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
F Gauge R&R & Calibration Intervals Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Radius Gauge R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
S Pressure Gauge Calibration Uncertainty Calibration and Metrology Software and Hardware 5
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
Ron Rompen Gauge Design Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Gauge CAD certification to Part CAD vs. Gauge certification to Part CAD General Measurement Device and Calibration Topics 1
shimonv Feeler Gauge as a Medical Device Accessory EU Medical Device Regulations 3
C Proper Thickness Gauge for Foam/Felt and Soft Materials General Measurement Device and Calibration Topics 5
J What kind of Tool and Gauge in IATF 16949 Clause 8.5.1.6? IATF 16949 - Automotive Quality Systems Standard 1
alonFAI Gauge R&R for a Peel Tester (tensile tester) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
V Why Gauge R&R 10% is acceptable for variable instruments ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
C How to perform Gauge R & R on Automated Test & Measurement Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
V Inactive Gauge Retention Time - PPAP Section 6 Requirements APQP and PPAP 1
Q Pin Gauge Setup - Measuring the OD of a Catheter Manufacturing and Related Processes 1
kedarg6500 Availability of 5/8" 17.75 TPI Thread Ring Gauge & Die Nut Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Gauge R&R for Destructive Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J Thread Gauge Calibration Failure for Pitch Diameter being too large General Measurement Device and Calibration Topics 3
