Gauge R & R and stability, linearity and bias
I am in the process of putting together flow charts and work instructions for MSA. The reason for this is that we intend to go for TS16949 at the end of the year and I need a procedure in place. Now then, I could use the AIAG reference manual and have done for most of it. However, management has decided not to implement MSA for our non automotive gauges. A shortsighted approach in my humble opinion, but there it is. Now the question. Do I have to do stability, linearity and bias studies if just using the Range and Average and Range method?
Atul Khandekar
Well, they all address different issues in a measurement system. You may have a very good GRR and still have bias or stability issues.
While it may be prudent to do all the studies, the arguments (for and) against it are well known: one of them being, if the customers or auditors don't care or mandate it, don't do it.
I guess it boils down to what kind of risk you and your customer are willing to accept about the quality of the product that you ship, and what the measurement system is being used for.
That's about as vague as I can get! :(
Recently, I found this question about GRR on Quality Magazine message board:
This may be a dumb question, but knowing quality professionals, nothing is really dumb. I am trying to justify doing gauge R&R studies and we have had some of our plant quality managers attend a UT course where they were taught that R&R studies are essentially useless since the data is only valuable for that instant. I disagree but am having a hard time justifying myself.
Q
Qaware
Hello
I'm a novice in this field and not familiar with the requirements of TS16949 but maybe this can be of use to you.
When calibration of the measurement equipment is performed some of the studies regarding bias, stability and linearity should already have been taken care of. Check the procedures on how calibration is done, to find out which of them. Off course there might still be differences in results between calibration and when the equipment is used for inspection of products. As Atul stated above, it comes down to the risk you and your customer is willing to accept.
C Gauge R&R Question Using Minitab Software 1
J Gauge Suggestion: Specialty or Custom General Measurement Device and Calibration Topics 1
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
F Gauge R&R & Calibration Intervals Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
S Gauge R and R - Product - Conveyor belt with threads that goes on Sprocket Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Radius Gauge R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
S Pressure Gauge Calibration Uncertainty Calibration and Metrology Software and Hardware 5
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
Ron Rompen Gauge Design Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Gauge CAD certification to Part CAD vs. Gauge certification to Part CAD General Measurement Device and Calibration Topics 1
shimonv Feeler Gauge as a Medical Device Accessory EU Medical Device Regulations 3
C Proper Thickness Gauge for Foam/Felt and Soft Materials General Measurement Device and Calibration Topics 5
J What kind of Tool and Gauge in IATF 16949 Clause 8.5.1.6? IATF 16949 - Automotive Quality Systems Standard 1
alonFAI Gauge R&R for a Peel Tester (tensile tester) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
V Why Gauge R&R 10% is acceptable for variable instruments ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
C How to perform Gauge R & R on Automated Test & Measurement Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
V Inactive Gauge Retention Time - PPAP Section 6 Requirements APQP and PPAP 1
Q Pin Gauge Setup - Measuring the OD of a Catheter Manufacturing and Related Processes 1
kedarg6500 Availability of 5/8" 17.75 TPI Thread Ring Gauge & Die Nut Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Gauge R&R for Destructive Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J Thread Gauge Calibration Failure for Pitch Diameter being too large General Measurement Device and Calibration Topics 3
N Procedure/calculation for determining the foot pressure of dial thickness gauge General Measurement Device and Calibration Topics 11
