Gauge R&R & Calibration Intervals
#11
When you refer to "...a requirement in MSA..." are you referring to the AIAG MSA manual? Have you asked the QM to show you where it says that gage studies must be done annually?
Yes, I am referring to the AIAG MSA manual. He gets very defensive about any policies that he has established. We have several customers and only two of them actually require them annually. If I can get the others removed from the schedule, it would free up a lot of time. And thank you for all the input.
Johnnymo62
Haste Makes Waste
#12
If your customer is automotive, you are usually required to do Annual PPAPs. If there are special characteristics, you will have to do GR&Rs for these every year.
That was my experience at a Tier 1 to Ford.
#13
That may be more related to your supplier quality person than to the company. I worked for several tier 1's also, and we never had to repeat an MSA study.
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
S Pressure Gauge Calibration Uncertainty Calibration and Metrology Software and Hardware 5
J Thread Gauge Calibration Failure for Pitch Diameter being too large General Measurement Device and Calibration Topics 3
B Can I use a Laboratory CMM for Gauge Calibration General Measurement Device and Calibration Topics 11
L Calibration of Dial Thickness Gauge - What reference standard need I follow? General Measurement Device and Calibration Topics 5
A Label Printer for Gauge Calibration Purposes - Looking for Recommendations Calibration and Metrology Software and Hardware 6
R Calibration of a portable FARO gage portable CMM # F04L2 gauge General Measurement Device and Calibration Topics 6
V Analog Pressure Gauge Calibration - smallest resolution practice General Measurement Device and Calibration Topics 12
E Gauge Block Grade recommended use for in house calibration General Measurement Device and Calibration Topics 1
T Calibration of Gauge Pins Manufacturing and Related Processes 10
L Calibration of ring thread gauge with master gauge: How to calculate Uncertainty? General Measurement Device and Calibration Topics 1
S Claim caused by Gauge Out of Calibration General Measurement Device and Calibration Topics 2
C Norm for Acceptance Calibration Results Torque Gauge and /or Dynamometers General Measurement Device and Calibration Topics 5
B Difference between Calibration & Verification and How to calibrate Go/No Go gauge? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Ultrasonic Thickness Gauge / Step block - Calibration - help General Measurement Device and Calibration Topics 3
H In-house Calibration - Verniers using gauge blocks General Measurement Device and Calibration Topics 5
C Pin Gauge Calibration using a Micrometer - Accuracy & Calibration Level Question General Measurement Device and Calibration Topics 10
S What is the best way to calibrate a Go NoGo Gauge Calibration General Measurement Device and Calibration Topics 2
J Pressure Gauge Tolerances after Calibration General Measurement Device and Calibration Topics 5
M Wrong Calibration / Verification Result - Height gauge IATF 16949 - Automotive Quality Systems Standard 6
J Confused about Calibration Tolerances of Plug Gauge, Ring Gauge & Snap Gauge General Measurement Device and Calibration Topics 4
N Calibration of micrometer by gauge block General Measurement Device and Calibration Topics 5
L Gage Pin Gauge R&R - Our calibration guy said he doesn't know how to do one Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
W Pressure Gauge Calibration Procedure needed General Measurement Device and Calibration Topics 3
P Thread plug gauge failed calibration - Must I remeasure everything measured with it? General Measurement Device and Calibration Topics 23
P Dial Gauge (gage) Calibration Software Calibration and Metrology Software and Hardware 2
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
S Gauge R and R - Product - Conveyor belt with threads that goes on Sprocket Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Radius Gauge R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
