alonFAI
Hello Guys,
I am thinking about performing a Gauge R&R for a tensile tester (peel tester).
to the best of my understanding I should perform a nested Gauge R&R for a destructive measurement system.
1. should I perform a variable Gauge R&R? the peel tester yields variable data.
2. what is the tolerance? (I mean for peel testing you usually have only LSL)
3. is a Gauge R&R is actually required? performing it will be beneficial?
why not just perform a process capability study and see whether the peel tester yields low results for known bad units and good results for known good units and compare CPKs
4. also, If I want to do an MSA BIAS Study, how is it done for a peel tester? I mean what I can consider as golden sample? force results has a range..
Thank you very much!
