Gauge R&R for Destructive Test
jdm2008
I am looking to complete a Gauge R&R, on a test that can only be completed once per part(it is not destructive per say, for the purposes of the test it is).
The point of the test is to measure a charactersitic on a device that we suspect may be varying.
Tradional suggestions may be to to use a subgroup and approximate the tradional Gauge R&R method by assuming by making a subgroup of parts identically.
However the whole point of the test is to determine whether the characteristic is consistent from device, and the process may not be capable of making an identical devices in a so this would defeat the purpose.
How would you do Gauge R&R or test validation on this test?
Is the device itself a measurement device?
I know you are probably trying to maintain some type of proprietary information but the more information you can give us the more useful - and more specific - advice we can give you...
for example: if the characteristic of the device itself is a function (a dymanic event) rather than a dimension or property (a relatively static thing) and the device can do this function more than once, then we can devise a test that holds the test conditions constant.
jdm2008
The device being evaluated is not a measurement device. It's something that is activated(and can only be activated once, while keeping the same properties.
The measurement device I will build, will take a measurement on the device being evaluated(the finished device being evaluated and currently being sold).
Once activated, for how long does the device retain its properties?
A) Properties are demonstrated for a very short time (e.g., AED)
B) Properties are demonstrated for an extended period of time but immediately begin decaying (e.g., battery)
C) Properties are demonstrated for an extended period of time at a consistent level.
G
gstewart
Rest assured that if you go to a commercial laboratory to get something tensile tested, they don't do a new MSA based on your item.
The car companies a sort of losing touch with reality with a lot of their requirements.
We have developed a whole Engineering system over the last couple of years to predict whether things will work or not. That's why we can do stuff like build bridges without having to build 50 other bridges and knock them down to see if they are strong enough.
But science obviously isn't good enough if we have something vitally important like a cup holder in a car.
B Destructive Gauge R&R Sample Sizes - Does ANOVA work better for the analysis? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
sonflowerinwales Quick question M3 screw plug gauge AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
J Gas Sterilization of a Force gauge, to be used in orthopedic surgery..?? Other Medical Device and Orthopedic Related Topics 14
V Opinion on gauge control graphic General Measurement Device and Calibration Topics 5
Nihls Capability of a roughness gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Full Scale for Pressure and Vacuum Gauge General Measurement Device and Calibration Topics 1
A Thread after coating fail Go gauge. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
M Bourdon gauge calibration procedure failure ISO 17025 related Discussions 3
M Faro Gauge General Measurement Device and Calibration Topics 1
M Why do we call it "Gauge" R&R Quality Tools, Improvement and Analysis 1
CaliperJim Double Ended Thread Plug Gauge Calibration General Measurement Device and Calibration Topics 9
C Pressure Gauge Calibration General Measurement Device and Calibration Topics 3
J Gauge Management - with ambiguous requirements & no support ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Gauge R&R Question Using Minitab Software 1
J Gauge Suggestion: Specialty or Custom General Measurement Device and Calibration Topics 1
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
F Gauge R&R & Calibration Intervals Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
S Gauge R and R - Product - Conveyor belt with threads that goes on Sprocket Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Radius Gauge R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
S Pressure Gauge Calibration Uncertainty Calibration and Metrology Software and Hardware 5
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
Ron Rompen Gauge Design Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Gauge CAD certification to Part CAD vs. Gauge certification to Part CAD General Measurement Device and Calibration Topics 1
shimonv Feeler Gauge as a Medical Device Accessory EU Medical Device Regulations 3
C Proper Thickness Gauge for Foam/Felt and Soft Materials General Measurement Device and Calibration Topics 5
