Gauge R&R of automeasuring machine for checking the crankshaft diameters
  • Thread starter prasadshirodkar1976
  • Start date
P
prasadshirodkar1976
We have auto measuring machine for checking the cranshaft diameters. the machine is PLC programmed & checking done by digitela micrometers by robots.
kindly tell me the procedure for checking gauge R&R.
as per my view--in above case Av will become zero. so the R&R =EV but is Pv is considered as measured parts varitaion then it is also coming very less(towards zero). so the TV value is almost getting equal to R&R. so when u are are calculating gauge %R&R/TV it tends to 100% which is not good.
but if the Pv is considered as full tolerance of the component dimension. then it satisfies the below 10% condition for %R&R/TV value.
pl tell me right procedure.
prasad
The answer to this is based on the purpose of the gage itself.
Case 1) If the purpose of the gage is solely to inspect the parts to tolerance, use the P/T Ratio, which is based on the tolerance.
Case 2) If the purpose of the gage is to measure the parts to collect data for SPC (or other statistical purposes), you must use the %GRR formula, which is based on PV where PV is the Process Variation as seen with a capability study of the process is a state of control.
In your application, does the equipment react to the measured results to automatically adjust the process? Use Case 2.
Does the equipment simply sort the product into Pass/Fail groups? Use Case 1.
If the application is more complex that this, please provide more information.
P
prasadshirodkar1976
miner thanks for reply.
but as i told u the Pv value calculated by formula by using j factor is very small. so the Tv is coming almost equal to R&R.
so if checked for %R&R/TV its very high value.
if u allow i can send u excell sheet of calculations
can u pl tell me. when %R&R on Tv ot Tt is checked.
what is P/T ratio
Please attach the data to your next post, including the tolerances used.
I do need to know whether the gage is used only for Pass/Fail inspection or if it is used for SPC. This will make a big difference in the analysis and conclusions about gage suitability.
P/T ratio compares the R&R variation to the tolerance instead of comparing it to the process variation. If is used to assess the gage for suitability for inspection. %GRR is used to assess the gage for suitability as a process control device.
C Gauge R&R Question Using Minitab Software 1
J Gauge Suggestion: Specialty or Custom General Measurement Device and Calibration Topics 1
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
F Gauge R&R & Calibration Intervals Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
S Gauge R and R - Product - Conveyor belt with threads that goes on Sprocket Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Radius Gauge R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
S Pressure Gauge Calibration Uncertainty Calibration and Metrology Software and Hardware 5
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
Ron Rompen Gauge Design Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Gauge CAD certification to Part CAD vs. Gauge certification to Part CAD General Measurement Device and Calibration Topics 1
shimonv Feeler Gauge as a Medical Device Accessory EU Medical Device Regulations 3
C Proper Thickness Gauge for Foam/Felt and Soft Materials General Measurement Device and Calibration Topics 5
J What kind of Tool and Gauge in IATF 16949 Clause 8.5.1.6? IATF 16949 - Automotive Quality Systems Standard 1
alonFAI Gauge R&R for a Peel Tester (tensile tester) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
V Why Gauge R&R 10% is acceptable for variable instruments ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
C How to perform Gauge R & R on Automated Test & Measurement Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
V Inactive Gauge Retention Time - PPAP Section 6 Requirements APQP and PPAP 1
Q Pin Gauge Setup - Measuring the OD of a Catheter Manufacturing and Related Processes 1
kedarg6500 Availability of 5/8" 17.75 TPI Thread Ring Gauge & Die Nut Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Gauge R&R for Destructive Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J Thread Gauge Calibration Failure for Pitch Diameter being too large General Measurement Device and Calibration Topics 3
N Procedure/calculation for determining the foot pressure of dial thickness gauge General Measurement Device and Calibration Topics 11
