Gauge R&R on a torque measurement
John Predmore
#11
I have not seen your parts so I can only speak in generalities. Let's assume you are screwing a fastener into a threaded hole. I assume your test parts are assembled in random order, and later sorted in the spreadsheet for convenience of analysis, but what you label measurement #1 always precedes what is labeled #2. I notice a trend in your data where most of the sample parts have higher torque on 2nd install and higher yet on 3rd. Tightening the parts may be changing the micro-geometry or surfaces of the parts the first few times you install them. Since a GR&R is a study of the measurement system and not of the particular parts, for analysis you want parts that do not change from one trial to the next.
What I would try is "pre-condition" your samples with repeated installations until the torque measurements plateau and are no longer increasing. I would think 10 install/remove cycles on each fastener would be enough to see parts become more repeatable. Then run your GR&R on the 11th 12th and 13th install and check the repeatability and reproducibility.
#12
I knew that the parts had variation because we had our Engineer stake them from low to high to try and help us pass the ANOVA study. It was to my understand (and maybe I'm wrong) that for the ANOVA study, you need to have parts across the entire range of your tolerance. What I meant by climbing is that it was climbing between trials but it seemed to climb the same between operators. Trial 1 was low across all 3 operators, trial 2 climbed a little bit across all 3, and trial 3 climbed more across all 3. My big question is....with the measurement we are trying to achieve, is a Gauge R&R the right study we should be doing? Its a shaft that's about 8 feet long with a U-Joint in the middle with a 0.4Nm tolerance. When we ran this gauge off at the gauge maker, it was at 10% and 11%. Obviously when paying a lot of money for a gauge, you want to make sure it is under or as close to 10% as possible.
@John Predmore We did this by exercising the U-joint (swinging back and forth) for about a minute each to make sure the joints were "relaxed". However we may have to try and repeat this by doing it just before we measure because we are thinking that if they sit for a little while, they may "settle" again.
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
I Should we immediately have recalibrated our Digital Torque Gauge? IATF 16949 - Automotive Quality Systems Standard 5
C Norm for Acceptance Calibration Results Torque Gauge and /or Dynamometers General Measurement Device and Calibration Topics 5
K Torque Gauge R&R - Non-Replicable GRR Case Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
F Gauge R&R & Calibration Intervals Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
S Gauge R and R - Product - Conveyor belt with threads that goes on Sprocket Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Radius Gauge R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
S Pressure Gauge Calibration Uncertainty Calibration and Metrology Software and Hardware 5
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
Ron Rompen Gauge Design Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Gauge CAD certification to Part CAD vs. Gauge certification to Part CAD General Measurement Device and Calibration Topics 1
shimonv Feeler Gauge as a Medical Device Accessory EU Medical Device Regulations 3
C Proper Thickness Gauge for Foam/Felt and Soft Materials General Measurement Device and Calibration Topics 5
J What kind of Tool and Gauge in IATF 16949 Clause 8.5.1.6? IATF 16949 - Automotive Quality Systems Standard 1
alonFAI Gauge R&R for a Peel Tester (tensile tester) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
V Why Gauge R&R 10% is acceptable for variable instruments ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
C How to perform Gauge R & R on Automated Test & Measurement Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
V Inactive Gauge Retention Time - PPAP Section 6 Requirements APQP and PPAP 1
Q Pin Gauge Setup - Measuring the OD of a Catheter Manufacturing and Related Processes 1
kedarg6500 Availability of 5/8" 17.75 TPI Thread Ring Gauge & Die Nut Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Gauge R&R for Destructive Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J Thread Gauge Calibration Failure for Pitch Diameter being too large General Measurement Device and Calibration Topics 3
N Procedure/calculation for determining the foot pressure of dial thickness gauge General Measurement Device and Calibration Topics 10
J JMP Gauge R&R with FORD MSA Data Quality Tools, Improvement and Analysis 2
V Pharmaceutical Analytical Method Validation and Gauge R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Screw Thread Go and No Go Gauge Standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
