Gauge R&R on multiple dimensions using 3D measurement system
Hello all,
This is my first post here, so please be kind :D
I am trying to analyze my data on minitab, and was hoping to get some insight.
Background:
We have a 3D measurement system, that can scan a whole part. We have setup an "inspection program" that measures 18 different dimension.
As part of the Test Method Validation protocol, we will be doing gauge r&r on this inspection program.
Once the part is loaded in the system, the system takes automated measurement without operator intervention.
10 parts being measured 5 times each by one operator, one gauge.
each part will have 18 individually identified dimensions.
I can perform gauge r&r on each dimension, but i dont want to do it 18 times for each dimensions.
I was wondering if any of you here have come across a similar situation or have suggestion on how you would approach this.
Ronen E
Problem Solver
Moderator
If you don't, it implies an assumption of uniform variability among the measurement of these 18 different dimensions.
Are you okay with this assumption?
I would have gone through the full exercise at least once (if it's a new CMM) to get an idea whether that would be a reasonable assumption going forward (i.e. for future studies on other parts etc.). But even then, such assumption would have to be made explicit on each and every study.
A Guage R&R is not intended to be a ‘check the box’ exercise. You might save a little time with your approach but if you miss something you’ll spend a lot more time and money trying to correct it. There are so many things that can go wrong even with (and maybe especially with) a CMM. Approach angles, size of the ruby, basic errors in programming, poor fixtures, etc. I’ve experienced this desire to cut corners too many times with catastrophic results. (The worst was with a CMM on an engine part that caused mid air shutdowns of the engine) It’s like running a red light - you won’t always get T-boned but when you do...
I am sorry I was not clear with my request.
I want to do gauge r&r on all 18 measurements. The system automatically measures those dimensions.
I was wondering, if minitab could process all 18 of them. I know how to do one at a time. I am fairly new to minitab.
Thanks.
optomist1
A Sea of Statistics
Gamma, what version of MT are you using? To confirm you have parts to be measured via CMM, on each part you wish measure 18 different features or part dimensions? Also with the CMM are there any fixtures or gages to be used?
Thanks.
The easiest way would be to put all your data into a single worksheet in Minitab. Part numbers and Operators in the first columns followed by 18 columns of data (one for each dimension). You can then run the study 18 times, or create a macro using the following command 18 times total.
GageRR;
Parts 'Part';
Opers 'Operator';
Response 'Measurement 1';
Studyvar 6;
Tolerance 5.
GageRR;
Parts 'Part';
Opers 'Operator';
Response 'Measurement 2';
Studyvar 6;
Tolerance 8.
You will need to change the values shown in red to match the column names for your 18 measurements and the corresponding tolerances.
Miner, thanks for the tip. I did that manually for my first inspection program.
I will try the macro for the second inspection program.
J Gauge Management - with ambiguous requirements & no support ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Gauge R&R Question Using Minitab Software 1
J Gauge Suggestion: Specialty or Custom General Measurement Device and Calibration Topics 1
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
F Gauge R&R & Calibration Intervals Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
S Gauge R and R - Product - Conveyor belt with threads that goes on Sprocket Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Radius Gauge R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
S Pressure Gauge Calibration Uncertainty Calibration and Metrology Software and Hardware 5
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
Ron Rompen Gauge Design Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Gauge CAD certification to Part CAD vs. Gauge certification to Part CAD General Measurement Device and Calibration Topics 1
shimonv Feeler Gauge as a Medical Device Accessory EU Medical Device Regulations 3
C Proper Thickness Gauge for Foam/Felt and Soft Materials General Measurement Device and Calibration Topics 5
J What kind of Tool and Gauge in IATF 16949 Clause 8.5.1.6? IATF 16949 - Automotive Quality Systems Standard 1
alonFAI Gauge R&R for a Peel Tester (tensile tester) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
V Why Gauge R&R 10% is acceptable for variable instruments ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
C How to perform Gauge R & R on Automated Test & Measurement Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
V Inactive Gauge Retention Time - PPAP Section 6 Requirements APQP and PPAP 1
Q Pin Gauge Setup - Measuring the OD of a Catheter Manufacturing and Related Processes 1
kedarg6500 Availability of 5/8" 17.75 TPI Thread Ring Gauge & Die Nut Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Gauge R&R for Destructive Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J Thread Gauge Calibration Failure for Pitch Diameter being too large General Measurement Device and Calibration Topics 3
N Procedure/calculation for determining the foot pressure of dial thickness gauge General Measurement Device and Calibration Topics 11
