Gauge Study for Small Lots
AerospaceAimee
I work for a company with a manufacturing/assembly facility that more often than not runs lots of about 5 pieces or less. We were issued a CAR from our customer, and engineering's corrective action was to design a tool/gauge that they claim can be used for creating the dimension and measuring it. We are now in the process of trying to validate that the tool/gauge, but have a problem in that there is only one part to validate with.
I'm pretty positive we can't do any kind of capability study for the creation function of the tool, but I'm wondering if there's a way to validate the measuring function with only one part to validate with, and no knowledge of if there will be another run in the future. I'm fairly knowledgeable in Gauge R&Rs, but the smallest study I've performed is 5 parts with 2 operators (and am very aware that was sketchy data); is it possible to go smaller? If so, how would you calculate it without minitab or any other study program?
Thank you!
Ron Rompen
In theory, you can do a GRR study with only one part, but the results would be meaningless. To do any gauge study, you need a selection of parts which represent the anticipated process spread, AND of course you want to have at least one part which exceeds the tolerance.
Proud Liberal
Since the purpose of the R&R is to determine if the gaging solution is adequate to the task, can you group similar parts into a single study.
Ron Rompen
I have done this in the past, with the provisio that the part features are similar, and the GRR is done to the tightest tolerance. It is similar in concept to doing the MSA study on a 'family' of gauges.
I don't know if this is specifically permitted (or excluded) in any documentation, but I have never had it written up as an audit finding, by either 3rd party auditors or customer auditors.
bobdoering
Stop X-bar/R Madness!!
In order to have a valid gage R&R, you need to have samples that are sufficiently different enough that the gage can tell the samples apart. It is far easier to correct a gage study with too much variation than one with too little - and one part is certainly too little. Can you simulate the feature, as in make stand-in parts where the feature exists - but not entire parts -made with significant variation between the parts?
bobdoering
When you have any of the samples that exceed the expected variation of the process of the life of the process (such as the one part that exceeds the tolerance) you do NOT want to include them in the calculation. You need to plug in the historical standard deviation for the PV to calculate a correct GR&R value.
R Radius Gauge R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Cross Tab Attribute Gauge Study form Excel .xls Spreadsheet Templates and Tools 3
Manix MSA - How to Approach a Gauge R&R Go/NoGo Attribute Study Statistical Analysis Tools, Techniques and SPC 2
L Is a Gauge R&R Study needed for ISO 9001 Stage 1 Audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H GRR (Gage R&R) Study for Digital Temperature Gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Ford MSA - Ford TYPE 1 study on a Marposs post process gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P MSA Study Types - How to make an informed decision about a gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
S How to do a Go / No Go Gauge R&R Study Statistical Analysis Tools, Techniques and SPC 2
S Separate attribute MSA study required for each Go/No Go gauge? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P Is it possible to do a Gage R&R Study for a Pressure Gauge? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Gauge (Gage) R&R study - Samples required from full tolerance spread? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Ron Rompen Attribute Gage Study Assistance - Drop gauge - 2 gauges, used by 4 operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D Gauge R & R - What is the requirement for number of operators in study? IATF 16949 - Automotive Quality Systems Standard 4
S Performing first Gauge R&R study tomorrow Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Torque Gauge R&R - Non-Replicable GRR Case Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gauge R&R for Profilometer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Using current gauge to verify masters General Measurement Device and Calibration Topics 1
H Digital Bore Gauge vs Pin Gauge General Measurement Device and Calibration Topics 6
N Bowers XT xtreme ratchet style digital bore gauge General Measurement Device and Calibration Topics 1
M Thread plug gauge validation/certification ASME vs Asian JJF standard Manufacturing and Related Processes 0
2tall Multiple Frequencies within 1 Gauge Number file?? Using GAGEpack Software 0
J Which gauge R&R to use per AIAG Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
sonflowerinwales Quick question M3 screw plug gauge AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
J Gas Sterilization of a Force gauge, to be used in orthopedic surgery..?? Other Medical Device and Orthopedic Related Topics 14
V Opinion on gauge control graphic General Measurement Device and Calibration Topics 5
Nihls Capability of a roughness gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Full Scale for Pressure and Vacuum Gauge General Measurement Device and Calibration Topics 1
A Thread after coating fail Go gauge. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
M Bourdon gauge calibration procedure failure ISO 17025 related Discussions 3
M Faro Gauge General Measurement Device and Calibration Topics 1
M Why do we call it "Gauge" R&R Quality Tools, Improvement and Analysis 1
CaliperJim Double Ended Thread Plug Gauge Calibration General Measurement Device and Calibration Topics 9
C Pressure Gauge Calibration General Measurement Device and Calibration Topics 3
J Gauge Management - with ambiguous requirements & no support ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Gauge R&R Question Using Minitab Software 1
J Gauge Suggestion: Specialty or Custom General Measurement Device and Calibration Topics 1
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
