Gauge to Gauge (Gage) Studies
Good morning all,
Looking through the threads for testing the viabilty of a replacement measuring system has proved very helpful to a point.
I have concluded that a Youden plot and a Bland Altman plot seem to be the best tools for the job.
Was wondering if I might get some confirmation on my analysis of the two methods.
Please reference the attachments below
On the Bland Altman, there is only 1 point outside the limits of agreement, yet the dispersion of the data is wider than I would like to see.
Is the fact that is is somewhat equally distributed between upper and lower an indication that this would be a decent replacement?
Have done research on interpreting this method and still feel that I'm missing something in the analysis.
On the Youden plot, how much deviation from the 45 degree line is acceptable? I do understand that the interpretation for these are clinical more than a black and white statistical inference so I would like some second opinions / any advice that might help draw conclusions.
Same as above, I have researched this and still feel like I have not come to the concrete determinations that I would like.
Find the cove to be an invaluable resource, spend alot of time on here finding answers, any help on this particular issue would be greatly appreciated. Bland Altman Dext-CMM.jpg
Re: Gauge to gauge studies
Overall, you have made a correct assessment. Regarding the point outside the limits of the Bland-Altman plot, these limits are 95% confidence (+/- 2sigma), so a single point is of little concern.
You did not specify what you are measuring, so I do not know whether the range of parts is sufficiently wide. It should be as wide as the anticipated measurement range. I would definitely try to find additional samples at each end of the range.
For the sake of this particular sample set, the spec range would be 3.610 +/- .010.
So the samples do emcompass the complete range.
Is the fact that the data in the Blandalt show a range of +/- .005 disconcerting?
On to the Youden plot;
How does one determine how far from the thoretical 45 degree line your data can be dispersed and still be deemed acceptable?
Thanks for your time and help, very much appreciated.:agree1:
" No trend or “CV” effect can be observed over this range of sample results. The differences between measurement methods appears to be random, and so the calculated 2 σd limits can be considered a good estimation for future results. "
The above quote is from the MSA doc from the link.This statement fits my data when plotted also. I guess I'm still confused as to whether the "estimation for future results" refers to the fact that the gauge may be that far off in it's accuracy (in my plot that would mean a +/- .005" range)?
Thanks again for the reply, Had not seen the MSA sheet. very well written, there just seems to be one small part that I am not grasping.:bonk:
MEthod comparison is lookign for two things: bias and repeatability.
Both the Youden and the B-A plot show that the difference between your two systems is random: there is no bias. That's a good thing.
However, there is some repeatability error that is concernign to you.
YES, if you don't change anything then you can reasonably expect to see roughly a MAXIMUM of + .005 measurement error between the two systems.
Only YOU know if this is acceptable.
Remember you've only looked at the two systems in relationship to each other - you have not presented any data on the repeatability of the two systems themselves...If you feel that this is too much you will need to go back and perform the repeatability study on each individual system: this may tell you that one is more repeatable than the other.
If we may ask: what feature are you measureing? this may enable us to give better guidance on the acceptability of the measurement error.
YES, if you don't change anything then you can reasonably expect to see roughly a MAXIMUM of + .005 measurement error :mybad:between the two systems. :applause:
That was Exactly what I was looking for!
One gauge is definitely more repeatable than the other with a total R&R of about 4.9%.
Thanks to you and Miner, I find both of you to be very helpful in your postings.
A diameter of a plastic part.
Yes, there was training and observation of methods involved pre-study.
1 of the methods involve multi-point meas. with average being used as end result.
W Type 1 Gauge (Gage) R&R Excel Template anyone? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
H GRR (Gage R&R) Study for Digital Temperature Gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Plug Gauge (Gage) Design Design and Development of Products and Processes 7
U Gauge repeatability and reproducibility (Gage R&R) worksheets Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
R Calibration of a portable FARO gage portable CMM # F04L2 gauge General Measurement Device and Calibration Topics 6
D Gage R&R Repeatability - How do I know my gauge is in specification Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
automoto Gage R&R Form in Excel for Calculating Gauge R&R - Attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 73
K Gauge (gage) R&R for production equipment/fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Guidance on Gauge R&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
K Gauge R&R (Gage R&R) on Leica Laser Tracker Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P Is it possible to do a Gage R&R Study for a Pressure Gauge? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Definition GAGE vs. GAUGE - Difference between Gage and Gauge Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
E Digital Height Gauge Gage R&R - Need Advise and Help Quick Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R "Gauge (Gage) R&R Studies per MSA Manual" - Customer Audit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
D Gage R&R On Pass Fail Gauge - Photograph Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
I What is Gauge Capability? Dial Thickness Gage and Digital Vernier Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
M Gauge (Gage) R&R study - Samples required from full tolerance spread? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Gauge (Gage) R&R for interferometer test used to measure scanners Z range in microns Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Questions About CMM (Coordinate Measuring Machine) Gauge (Gage) R & R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
Howard Atkins Values and results to check Validation of Gauge (Gage) R&R program Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
Ron Rompen Attribute Gage Study Assistance - Drop gauge - 2 gauges, used by 4 operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Gage R&R for every gauge? Or is it only every type of gauge? MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
L Ford Requirements for Gauge Families - What is a 'Gage Family'? IATF 16949 - Automotive Quality Systems Standard 3
L Gage Pin Gauge R&R - Our calibration guy said he doesn't know how to do one Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
B Definition Gage and Gauge - Difference between the terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 45
P Dial Gauge (gage) Calibration Software Calibration and Metrology Software and Hardware 2
D Simplified Attribute MSA Gauge (Gage) R&R for Plug Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
D Gage R & R - Do we specifically have to do Gage R&R on every gauge? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
R Gauge Repeatability and Reproducibility (Gage R&R) on all shop floor gages? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
C Gauge R&R Question Using Minitab Software 1
J Gauge Suggestion: Specialty or Custom General Measurement Device and Calibration Topics 1
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
F Gauge R&R & Calibration Intervals Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
