GD&T (ANSI Y14.5) Perpendicularity Callouts
mattm1958
We have a number of parts that have a short bore (1-1.5") bored thru a large face (10-15"diameter). The perpendicularity callout is typically about .002.
Here's the problem; parts have checked OK for years, but they are always written up as non-conforming because the CMM area insists on checking it both ways; 1) short bore as the major alignment and then 2) large plane as the major alignment. Reported results are typically .0040 and .0005 respectively, so they always fail one way or the other.
So the question is; Does ANSI Y14.5 perpendicularity really call out a precedence depending on where the symbol (on bore or face) is placed, or can we use common sense here and discard the highly variable reading?
Seems we're spinning wheels and spending time for nothing. Thanks in advance.
Kales Veggie
People: The Vital Few
The feature block should show what the datum is, usually the large plane
Stijloor
The precedence is determined by where the datum feature symbol is placed.
First of all. What GD&T Standard is referred to? ASME Y14.5M-1994? ASME Y14.5-2009? An older GD&T standard perhaps?
Next. Look at where the datum feature symbol has been placed. Most likely the large surface. That will be your datum feature from which the datum will be simulated..
Next, look at the feature control frame. The axis of the bore will then be perpendicular within .XXX" relative to the datum feature. The tolerance zone will likely be cylindrical (look for the diameter symbol).
Checking the perpendicularity of the large surface relative to the bore is "bass ackwards.." :nope:
mattm1958
So, if I'm reading you correctly, if the feature control frame is on the BORE and references as its primary datum, the FACE, then that would tell you that you have to establish the FACE datum then check the BORE.
I agree that using two features, like 1) the center of the bore at the top and 2) the center of the bore at the bottom, so close together to set up an alignment, is setting us up for problems, but its not specific (to the level of CMM feature selection order) in Y14.5. That conclusion is reached by interpretation.
So when looking at a print, when the FCF is on the bore centerline, it means establish the face first. Are there any words in Y14.5 that speak to this more clearly? I can't find any.
Thanks for the replies.
Stijloor
First of all, do you have ASME Y14.5 available?
Secondly, without an actual sketch or drawing, it remains guesswork for me. ;)
When the Feature Control Frame is applied/attached to the bore, the bore is the controlled feature. The feature control frame should show the datum (sequence). So, if the large surface is identified with a datum feature symbol, let's say "X", and the feature control frame shows "X" as well, than the large surface is your (primary) datum.
Show us a picture!! :agree1:
True Position
A drawing would help, but if the FCF has the small bore as the datum then you need to measure it that way unless the design responsible engineer can update the print.
B FAI and ANSI Y14.5 Trailing Zeros and Print Tolerances Manufacturing and Related Processes 3
M What Preceded ANSI/ASME Y14.5? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J ANSI Y14.5M-1994 Interpretion Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
K Understanding True position - Drawing Feature Control Frames - ANSI Y14.5 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M ANSI-Y14.5M vs. ASME-Y14.5M - Does an ANSI-Y14.5M-1994 document actually exist? Various Other Specifications, Standards, and related Requirements 9
9 ANSI Y14.5M Absolute Limits and Measurement question Various Other Specifications, Standards, and related Requirements 6
R ANSI/ASQ Z1.4. for CQE Exam Professional Certifications and Degrees 8
N Database that lists labs accredited to ASTM / ANSI standards Various Other Specifications, Standards, and related Requirements 6
A ANSI/AAMI versions of 60601-1-2 and related testing requirements Other Medical Device Related Standards 3
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
Q ASQ/ANSI Z1.4–2003 (R2018) Change Log? Various Other Specifications, Standards, and related Requirements 2
S Medical Device Endotoxin Testing for ANSI/AAMI ST72:2011/2016 Other Medical Device Related Standards 1
Sidney Vianna ANSI acquires full ownership of ANAB - December 2018 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
C AS9100 rev D 8.5.1 c 2 - Defining the Machine in-process frequency per ANSI/ASQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
Proud Liberal Surface finish measurement (roughness) - Rz under the ISO standard vs ANSI standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
M Which Version of 60601-1 to Purchase (IEC, EN, ANSI...)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
L AQL ANSI z1.4 & z1.9 - What are the differences between these 2 standards? AQL - Acceptable Quality Level 5
J Can ANSI Z1.4 sampling plan be used for sampling alone without the Acc/Rej criteria? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M AAMI/ANSI 11135-1:2007, EO Sterilization Other US Medical Device Regulations 8
N Database (Like ASSIST) to subscribe to & have access to new SAE-AS & ANSI standards Various Other Specifications, Standards, and related Requirements 2
E Cleaning Validations for Reusable Products - ANSI/AAMI TIR30:2011 Requirements Other Medical Device Related Standards 3
V Locking in a Standards Version (ANSI Z1.4) Statistical Analysis Tools, Techniques and SPC 1
K Can I use ANSI/AQL for the Total Number of Containers for the entire Lot? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Where to find the ANSI Z1.9 Rosetta Stone Capability, Accuracy and Stability - Processes, Machines, etc. 9
F ANSI ASQ Z1.4 - Is the following process acceptable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Calibration system must meet ISO 10012, ISO 17025 or ANSI/NCSL Z540? ISO 17025 related Discussions 38
M ANSI/ASME B1.2 Revision Changes from the 2001 version Various Other Specifications, Standards, and related Requirements 1
WCHorn AS9100 and Sampling - ANSI ASQ Z1.4 C=0 Conflict AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S Using ANSI/ASQ Z1.4 to Reduce Impact of Field Service Campaign AQL - Acceptable Quality Level 17
L Steam Sterilization Validation per ANSI ST 79 Other Medical Device Related Standards 2
G Dial Indicator Calibration Frequency - ASME/ANSI B89.1.10M-1987 Calibration Frequency (Interval) 4
E Does anyone have a good understanding of the application of ANSI/AAMI AT6? Various Other Specifications, Standards, and related Requirements 3
A Where to obtain ANSI/ASQ Z1.9 C-1 and D-1 tables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Summary / Checklist for ANSI Z80.1 and ANSI Z80.3 Other Medical Device Related Standards 2
R ISO 10012, ANSI/NCSL Z540, ISO 17025 reference meet ISO 9001 7.4.2 (a) intent? ISO 17025 related Discussions 13
S ISO 2859-1 or Ansi ASQ Z1.4 in using AQL or AOQL - Need Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A ANSI/ASQ Z1.4 tables for C=0 - Setting up a robust Sampling Inspection Scheme Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
P Use of ANSI Standard for Metric Thread Plug Gage? General Measurement Device and Calibration Topics 1
R ANSI Z1.9 AQL 0.4 - What are the starting equipment expectations? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D ANSI Z540-3 Risk Analysis - How to do the math for risk analysis General Measurement Device and Calibration Topics 2
P Inspection Level Interpretation - ANSI Z1.4-2008 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
G ANSI & ASME regardless of Maximum Material Condition when none is specified Various Other Specifications, Standards, and related Requirements 3
D ANSI IPC A-610 Maximum Jumper Wires Allowed on Boards by the IPC Standard Various Other Specifications, Standards, and related Requirements 1
W ANSI Z1.4 Switching Rule Applications Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Q What are the differences between ANSI Z1.4, ANSI Z1.9, and ISO 2859-2? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Monitoring changes in ANSI standards - Control of External Documents Document Control Systems, Procedures, Forms and Templates 6
H Which OHSMS standard to choose? ILO? ANSI? CSA? BS? OHSAS? Occupational Health & Safety Management Standards 15
T Special Inspection Level 3 (S-3) per ANSI Z 1.4 & its relationship with ISO 2859-1 AQL - Acceptable Quality Level 1
triathlonx13 ISO vs. ANSI Thread Standard (Dimensions) and Luer Taper for Medical Devices Various Other Specifications, Standards, and related Requirements 4
