GD&T applied to reference dimension.
We do wire forming and I have a part that is basically a horseshoe, but the ends are swaged to a radius for welding to a pipe. The customer has the thickness of the swage called out, but the width is a ref. dimension. Can they apply the GD&T to the centerline of the swage?
So, they don't care about size (width), but location (centerline) is still important?
Correct, they care about thickness, but width is a reference. The A datum is also the one centerline, but I'm arguing it doesn't apply in the swaged area, only on the raw wire area.
John Predmore
Often times, "reference dimension" is used to indicate a dimension shown in one view is also shown in a different place, sometimes on a different drawing. In those cases, being a reference dimension doesn't mean the dimension is not important, it doesn't mean it can't be checked, doesn't mean there are no instructions how to measure it. Your questions about interpretation of design should go to the design-responsible engineer.
"It's not what you know that gets you in trouble, it's what you know that ain't so" -- Mark Twain
Sebastian
Reference means "Maybe someone wants to know, how much it is from this point to that point without Catia, or Cad, so here it is".
Usage of it, sometimes results in huge waste of time, as it requires explanations to less dimensional advanced people and in many cases might end in nothing, because e.g. "I am customer and it is on drawing, so it must be measured".
Same I see in case of theoretically exact dimensions.
When something is important do not mark it as "reference".
Next, give individual tolerance.
Next, mark with special characteristic symbol on drawing or show its significance in other product design documents, e.g. DFMEA if you are afraid to use SC symbols.
From my experience.
There was a warranty case.
Disassembled part was returned with counter part attached.
Counter part was made by other supplier.
We have seen in plant for a first time, how our part really works.
We recognized what dimension is related and reviewed our control plan.
It wasn't there.
We looked on drawing and found why.
It had general tolerance applied, while other ones had individual.
As other product design documents were missing, no, DFMEA was available in fact, but there was no "know how", so we were using policy of selecting dimensions to control, by checking what tolerance type was applied.
Individual were important and monitored.
General, some were subject of inspection during process development trials.
So our policy failed this time, but in fact someone else did not do his homework during design stage.
Conclusion - if you find it necessary, ask your customer to revise drawing and remove "reference".
Alternatively, ignore it even it may result in claim.
Then, drawing will be revised, for sure.
Keep one approach regarding dimensioning and remain consistent.
In my experience, a Ref dimension on OEM drawing means this: it needs to be checked at lower level drawing, a lower level drawing is sub component drawing , or it can be supplier owned drawing, or it can be a purchased part drawing if that sub component is being purcahsed from tier 2 supplier( supplier of the supplier)
bottom line, the dimension still needs to be checked but on a different drawing.
Ref dimensions are also used by OEM, if that dimension cannot be checked at the assembly level, perhaps because at the assembly level you cant access that dimension to check , you would need to disassemble the entire assembly to check that dimension, which is not possible. so OEM will just mark the tolerances and make it a reference.
That's the way it should be, but all too frequently even OEMs don't understand it and will mark something as a reference dimension when there is no antecedent to be found.
R Flammability requirements for applied parts as per 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Dielectric withstand of applied part IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Defibrillator Protection applicability When using Multiple applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
A 60601-1 : Integrated Dry ECG Electrodes = 2 Patient connections inside 1 applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
D Separation of F-type applied part and remaining parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
N BF-type applied part MOPP vs secondary IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Identifying Applied Parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Q Do you classify applied parts? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Defib-proof applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
B ISO 14971 Applied to Software ISO 14971 - Medical Device Risk Management 2
M 2xMOPP insulation for Applied Part B. IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A Technical File - Updating Applied Standards EU Medical Device Regulations 4
K Question on whether IEC 60601-2-62 standard is applied IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J ISO 14971 applied to ISO 13485? Low risk class 1 devices ISO 13485:2016 - Medical Device Quality Management Systems 5
T Overvoltages consideration in Applied Part for RMS Calculation. IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
B F-type applied part - Separation from ALL(?) other parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
G ISO 9001 8.4 applied to 7.1.3 - Suppliers of infrastructure requirements - IT and Print solutions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
K F-TYPE APPLIED PART IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J ISO 9001 8.4.1 - Determining controls applied to externally provided processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T IEC60601-1: Isolation for an applied part with working voltage of 1500Vp. IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
L PC in patient environment - BF applied part that uses USB to connect to PC IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
N Applied Parts Classification Clarification - Breast Pump IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E Are EEG electrodes considered as one applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
H Defib Protected Applied Parts: 4mm clearance/creepage? IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
S Number of MOPP for Type BF Applied Part (Medical Device Electronics) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Tagin Can/should SPC be applied to Computer Assembly and Software Imaging? Statistical Analysis Tools, Techniques and SPC 8
A EFQM applied on the ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L No entanglement hazard of applied parts cables? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
D NQA-1 Standard Applied to Services rather than Items for Nuclear Power Various Other Specifications, Standards, and related Requirements 3
S Internally powered ME with non-conductive applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Can a Surface of a profile be applied to a feature of size? GD&T questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Oxygen mask and nebilzer mask Applied standards EU Medical Device Regulations 2
E Requirements for primary battery powered ME with BF-applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
P Identifying Medical Device Class and Applied Part IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T Electrical Surgical Tool with Big Metal Applied Part IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
E What does "other APPLIED PARTS" mean in IEC 60601-1 ed 3.0 8.7.4.7 b) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
kedarg6500 How much test force to be applied for Vickers hardness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Classification of Applied Parts - Blood Measurement Sensors IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
R Is protective earth connection regarded as a part of the applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Is insulation between F type applied part and other parts a must? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
K Definition of ME Equipment/Applied part according to IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
L The definition of B, BF (Body Floated) and CF - BF applied to parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Reason a plane would have a runout applied and not a flatness callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
optomist1 Feature Control Frame is applied to the end of a Cylinder - Datum Dilemma Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
W Insulation requirements between F-type applied part and enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D Lean Management applied to Rework Zones Lean in Manufacturing and Service Industries 8
P Internet Medical Device Distribution applied to Internet/Catalog Shops Japan Medical Device Regulations 1
