GD&T Help (Y14.5M-1994) - True position callout box on two dowel holes
Paul F. Jackson
#11
Is the other dowel referenced in the dual specification to |A|M-N| and |A| by (a "2X" preceeding the size) or by (two leader lines extending from the FCFs to both holes) or by (a note including both hole under the FCF) or by (some other non-standard method)?
If not then the bottom note is only a refinement of perpendicularity of diameter "B" to surface A as others have stated.
If the size is preceeded by 2X and the datum feature identifier "B" is underneath the FCF or on the leader line to that FCF then both dowels simultaneously are Datum feature "B" and all six degrees of freedom would be constrained for related features by designating just |A|B|.
If the designations "B" and "C" are applied individually to each dowel hole away from the FCF and the two holes are controlled as a pattern as questioned above then they are unique datum features. If other feature control frames reference them as |A|B|C| they are secondary and tertiary respectively but their spread is still controlled by the bottom note relative to A
It is difficult to comment without a drawing especially if it is non-standard and I don't have AutoCad. You would have to provide a sketch with all the relevant designations, leaderlines, identifiers, etc...
Bill Ryan - 2007
#12
Paul,
I'm trying to formulate an answer for Ginn68 also, but in the meantime here is the attachment in .pdf if it will help you out.
cbearden
#13
Plain and simple....(Perpendicularity back to -A-)...Thats what the second FCF means........I know, I know....If they wanted to see Perpendicularity, why didn't they just put Perpendicularity.......I know, I know........It took me forever to finally figure that out.
Frikkin Engineers......
ZeissUser
Paul F. Jackson
#14
I respectfully disagree Zeissuser since the FCFs are under the 2X size callout, that makes both holes a pattern. Since the lower spec is RFS, the spread is limited to 19.8884 +/- 0.025 and the 0.025 zones at each feature B and C are oriented perpendicular to datum feature A. It is a stretch to say that this sketch is definitive of the design because it lacks much of the definition. The two notes Axis of B-C and Axis of M-N are not Axis' because the pairs are shown parallel to each other.
Paul
Jim Howe
#15
I ran into difficulty with an outdated version of auto cad lt and could not open file. My thanks to Bill for supplying the .pdf
I am not an expert but my old version of ANSI Y14.5m-1982 references the following.
Please look up "FEATURE PATTERN LOCATION" and "COMPOSITE POSITIONAL TOLERANCING", then look up where a datum is established by two datum features-for example, an axis established by two datum diameters- "both datum reference letters, seperated by a dash", (A-B).
The upper entry is referred to as the "pattern locating control" and the bottom entry is the "feature-relating control".
From the looks of it Paul is on the right track! :applause:
Goodluck!
G
ginn68
#16
I think Paul is correct also! I have been reading up in Geo-Metrics III by Lowell W. Foster, and it is starting to make sense. The first callout is for "Pattern Locating - Position Tol. Zone", and the second callout is for "Feature Relating - Position Tol. Zone" . If I understand correctly then the second callout could be considered as a span (Hole to Hole). This info can be located in the ASME Y14.5M 1994 standard starting on page 93. Does this sound correct to everyone else? My only question still is why in the second callout it is not labeled as 0.025 l A l B l???
Ginn68
Paul F. Jackson
#17
The acronyms PLTZF (pattern locating tolerance zone framework) "upper segment" and FRTZF (feature relating...) "lower segment" explained in the standard pertain to composite FCFs (One symbol, Two segments) and composite tolerances differ from single segment FCFs. The lower segment in a composite callout constrains only orientation (not location) of the pattern to the datum features declared. The pattern itself is contrained for both orientation and location by the definition of itself no matter whether its tolerance is declared in single segment or composite FCFs.
The dowel hole specification that we have here is not a composite FCF because it consists of two single segment controls but in this case it wouldn't make any difference if it was since the lower segment cannot constrain location of the pattern to the datum feature A.
Think about this: If the lower segment repeated the entire datum reference used in the upper segment "|A|M-N|" it wouldn't make sense for the single segment controls because the lower segment would override the upper but if the FCF was a composite the lower segment would constrain the pattern itself for location and orientation, then that pattern of 0.025 diameter zones would have to be perpendicular to "A" and parallel to M-N. I wouldn't override the upper segments tolerance of 0.6M for the basic displacement of 10, it would just refine the orientation relative to M-N to 0.025.
I suppose that B wasn't used in the lower segment because it wasn't necessary although when dowels are both the same size and fit into holes that are both round and the same size and neither dowel has precedent in locating and aligning the assemblies then we would use a note like the one you have however both dowels would be declared as datum feature B.
J ANSI Y14.5M-1994 Interpretion Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Supplier Quality level category help - high level ISO 13485:2016 - Medical Device Quality Management Systems 6
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
T ISO/IEC 17065 certification scheme Help Other ISO and International Standards and European Regulations 7
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
MDD_QNA Medical Device Software - Is a Help Button required? IEC 62304 - Medical Device Software Life Cycle Processes 1
S Need help with analysing a survey on minitab Using Minitab Software 1
M Help me improve the definition for internal PPM Manufacturing and Related Processes 3
I Help: QFD House of Quality Quality Tools, Improvement and Analysis 1
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
A Class medical device (MDD) - Classification help EU Medical Device Regulations 1
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
M Thanks for the help Coffee Break and Water Cooler Discussions 0
Judy Abbott Can any one help me with an urgent BIOCOMPATIBILITY Impact assessment? Internal Auditing 9
A Help establishing regulatory requirements - Plastic dental cartridge syringe US Food and Drug Administration (FDA) 0
A Medical Device Contract Manufacturing Requirements and Information - Help wanted ISO 13485:2016 - Medical Device Quality Management Systems 5
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Burn out - Tips to help combat QC burnout Career and Occupation Discussions 9
S New to FAIR, need help in filling it out AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Informational From RAPS: Danish Regulators Seek to Help Smaller Companies With EU MDR Compliance Medical Device and FDA Regulations and Standards News 0
M Reliability Testing - Weibull Analysis Help Reliability Analysis - Predictions, Testing and Standards 4
L Help me to decide which test to use - If each proportion belongs to the same population Using Minitab Software 7
M Informational US FDA issued the first warning letter for UDI violations to help ensure compliance Medical Device and FDA Regulations and Standards News 0
T QMS Template Help - Small machine shop/job shop Manufacturing and Related Processes 1
R Pls help --- Need expert advice on Video Measurement Measurement Uncertainty (MU) 0
B Will you please help me with my academic project? Repair & calibration service for test equipment ISO 17025 related Discussions 0
B [Help] Customer Engagement Survey for MBA Project - due Apr19 Manufacturing and Related Processes 0
B Help with Customer Engagement Survey for MBA Project - due Apr19 General Measurement Device and Calibration Topics 0
Q ISO 3310 Clarification Help - Aperture sizes for sieves used for particle sorting Other ISO and International Standards and European Regulations 2
Ajit Basrur Need help to understand HIPAA requirements ISO 13485:2016 - Medical Device Quality Management Systems 17
JoshuaFroud FDA Form MDSAP AU F0029.1.004 - Help with Completion US Food and Drug Administration (FDA) 0
supadrai Aviation MRO Project facility coming to U-Tapao airport in Thailand - Help Career and Occupation Discussions 2
E Small one man shop with QMS (shoptech e2) | AS9100 cert help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 46
