GD&T - How to measure these Positional Tolerances on a CMM
H
hamstar89
Need help with how to measure these positional tolerances on a CMM. Our quality department are a bit new to this and the customer requires a capability study on the major features. Any help on how to do this would be appreciated.
Ive had a quick look on the forums but couldn't couldn't find any thing similar to this.
Pos Ø0.51 M A B
Pos Ø0.25 M A B
See attached PDF
James
True Position
Pos Ø0.51 M A B
Pos Ø0.25 M A B
See attached PDF
James
What problems specifically are you having? Those are fairly straightforward position tolerances that any CMM should have no trouble working on. The only notable issues are applying MMC to a thread. Also per ANSI standards the position is that of the PD.
To accurately locate the PD a number of companies make threaded locators, for example:
http://www.flexbar.com/shop/pc/Hole-Location-Gages-c37.htm
Calculating capability for position tolerances is complicated, similar to the problems of any one sided tolerance.
David DeLong
James:
I think that you need to take a seminar or too in GD&T and then you could probably answer the questions yourself. Both of your examples, the positional tolerance is in MMC (M with a circle around it) and in the ASME Y14.5 -2009, it means the virtual condition diameter. In the 94 standard, you could calculate the actual tolerance and then use your CMM to find the center and figure out how far it is off true position (theoretical center). I have listed below three of my web sites that, hopefully, might answer your question.
http://www.qmsi.ca/positional.html
http://www.qmsi.ca/reportingpositional.html
http://www.qmsi.ca/capabilityindex.html
Good luck!
Mr.Happy
Hi James,
If you can switch on MMC in your CMM then you will get a bonus on your position tolerance. :D
The biggest problem :( is to make an accurate measurement on the thread holes, you should take enough measuring points (depends on the pitch) and also use the biggest probe possible.
To make sure you have reliable results you should do an MSA study on these thread holes.
Good luck,
Mr.Happy
Danny Hoover
Capability on a True position
lets say the deviations are:
x=1 y=1
x=-1 y=1
x=1 y=-1
x=-1 y=-1
These values will return the same positional deviation, but the center is in 4 different locations.
In turn, you could use the x and y deviation themselves to evaluate the center, but what tolerance do you use? Remember the true position formula is based on a mathematical formula that is much less than ±1/2 of the tolerance.
Is that a meaningful study? Yes.
Is this a capability study. No.
This information has been discussed many times in this forum:
http://cmmguys.com/forum/
I hope this helps you on your quest for useful data.
DH
V
vimalm
I have the same doubt in CMM in MMC. I got reading from CMM with MMC condition.
So the bonus points are added automatically. Then how to find the actual deviation in the reading?
True position nominal value - 0.15mm
For Diameter-10mm (+/- 0.1mm)
This is i got reading:
upper tolerance- 0.2627mm
Deviation - 0.2153mm
How to i calculate for 0.15mm?
V
vimalm
No,its not possible. You just say what is the actual calculation for the true position of 0.15mm.
True Position
The calculation using 0.15mm is the same thing but with MMC turned off. The MMC modifier changes the 0.15mm tolerance, that's what MMC bonus tolerance is.
C First Article Inspections - 'how to measure' General Measurement Device and Calibration Topics 11
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
P How to measure DPPM in Chemical batch manufacturing Quality Tools, Improvement and Analysis 1
silentmonkey How to measure severity if my product is designed for emergency use and failure would result in death? ISO 14971 - Medical Device Risk Management 9
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
J Validity / outcomes measure for custom made medical device ISO 13485:2016 - Medical Device Quality Management Systems 2
D Performance specification as a Risk Control Measure, EN 14971 ISO 14971 - Medical Device Risk Management 7
J KPIs or Metrics to Measure a New Complaint Handling Process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
D Torque fractional unit of measure; cN-m or N-cm? General Measurement Device and Calibration Topics 2
qualprod ISO 9001 5.1.1 - How to measure System effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J How to measure a Critical Characteristic that is a Basic Dimension Misc. Quality Assurance and Business Systems Related Topics 6
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
1 How to measure straightness on a HEX Long Bar Manufacturing and Related Processes 7
Ron Rompen Measurement Method Challenge - Measure feature #91 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
G Measure 3 times, for calibration report? Customer Owned Reference Standard General Measurement Device and Calibration Topics 4
M Informational The ANSM decides, as a precautionary measure, to withdraw from the market macrotextured breast implants and breast implants with polyurethane-coated s Medical Device and FDA Regulations and Standards News 0
M Informational Health Canada advises Allergan of its intent to suspend its licences for Biocell breast implants as a precautionary measure Medical Device and FDA Regulations and Standards News 0
U SI 13 - Not Every Process Requires an Efficiency Measure IATF 16949 - Automotive Quality Systems Standard 1
P NPR Metric - What if Customer has relaxed measure? TL 9000 Telecommunications Standard and QuEST 1
T Tape Measure, the right device for 2 or 3 decimals accuracy on prints General Measurement Device and Calibration Topics 8
M How do we document and measure a service we do not provide? IATF 16949 - Automotive Quality Systems Standard 1
M For a Type 1 Gage R&R I want to use 1 unit and measure it 30 times Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M How to Measure Paper considering Variation and Humidity General Measurement Device and Calibration Topics 10
rob73 Advice/recommendations for equipment to measure a soft pvc tube - Optical Measuring? General Measurement Device and Calibration Topics 4
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
D Proper Tool to Measure Wall Thickness (ISO 3611 - Micrometers) Manufacturing and Related Processes 7
S Quality Measure for Engineering Services Misc. Quality Assurance and Business Systems Related Topics 1
A What are methods and tools to measure Workload analysis ? Human Factors and Ergonomics in Engineering 1
M How do I measure variation in my process ? Capability, Accuracy and Stability - Processes, Machines, etc. 3
J How to measure process quality? Is DPPM the correct metric? Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Micrometer Anvil Placement to measure the diameter of Steel Wires Measurement Uncertainty (MU) 6
S Where to Get SPC Training to Measure our Processes? Training - Internal, External, Online and Distance Learning 12
M A question on Measurement System Analysis - Stability to measure got Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Jim Wynne Measure Twice, Cut Once: The French Railroad Snafu World News 18
S Measure water activity for fresh raw chicken meat and giblets Food Safety - ISO 22000, HACCP (21 CFR 120) 1
O Metrology Devices to Measure the Basic Dimensions of Plastic Specimens General Measurement Device and Calibration Topics 6
L How to Measure Paint Thickness for an Enclosure Manufacturing and Related Processes 5
C Chamfer Measurements - Do you measure the height and width or the hypotenuse? Manufacturing and Related Processes 15
R Repeatability in MSA - Is repeatability a measure of Location Error Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E How can I measure three true positions? GD&T basic question General Measurement Device and Calibration Topics 5
V How to use a Calibration Certificate in Uncertainty Calculation for a Test Measure Measurement Uncertainty (MU) 13
R How do companies measure QC Productivity? Quality Manager and Management Related Issues 3
V How to measure radius without radius gages APQP and PPAP 4
A Device to measure "Straightness & Deformation" of a metal that's under water Manufacturing and Related Processes 4
M How to measure effectiveness and efficiency of the established QMS as Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
F Specification for how to measure lengths of hose assemblies Various Other Specifications, Standards, and related Requirements 1
P MSA requirements for Systems that Measure Process Parameters Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
