GD&T Question, True Position Confusion
Bobyochen
I need some help with the true position call outs on the flats of this drawing. Based on how the dimensions are called out I am unsure if I would take the true position of the individual flats or use a constructed line between the opposed flats and take the true position of that. Any input is appreciated.
Thank you,
Bobyochen.
View media item 4591
I understand your confusion. Using a Profile callout would have been more clear. However, consider the use of Position on a bolt hole. A functional gage checks the outside of the hole, not the center point. Same for a slot feature. Given that, I would interpret it to mean check the flats themselves.
Bobyochen
Thank you for the reply.
I have been checking the positions of the individual flats relative to the two datums but I was a bit confused by the call out.
