According to GD&T Rule 1, "size controls form".
If we have a cylindrical pin with dimension range 17.490 mm to 17.495 mm then according to tec-ease.com, following is the way we should inspect it.
1. We will need the pin to pass through a full form gage of size 17.495 mm (that is, at MMC),
2. and a mic to inspect the 17.490 mm (LMC) dimension.
(ww.tec-ease.com/tips/june-02.htm)
We use a mic to inspect size of such pin at both MMC and LMC, which is wrong as per Rule 1.
When I asked our Receiving Inspection guy to start using ring gage of size 17.495 mm to inspect for size at MMC, he told me that it is unlikely that a ring gage at 17.495 mm will allow a pin of the same size to pass through. In other words, the ring gage should be a bit oversize.
Now tec-ease.com did not say anything about using somewhat oversize ring gage, and yet what our Receiving guy is saying also makes sense to me.
Can anyone please explain if the gage should be oversize? If yes, then how much?
Thanks.
Thanks.
