GD&T - True Position Callouts for Sections of Studs
mr_bridger
Hi.
I have been reading a lot on here, but finally found something I can't find an answer to. I hope someone could help me out please.
I'm trying to work out the correct way to dimension a pair of studs. I've attached an image of what we need to achieve. Hopefully it makes what I'm about to explain easier.
The left hand stud in the picture needs to be controlled from the intersection with the surface [A] up to 5mm from that surface with a tolerance of 0.5mm. Now in the past I've seen it done with a tolerance like:-
[TP][0.5][(P) 5.0][A]
IE a projected tolerance, but I believe this is only for checking "off" the part? Like past the studs end? Would it be prudent to just have a standard callout of [TP][0.5][A] and then a not saying "First 5mm from [A]" ?
This I'm unsure of.
The second one, (it is actually the same stud, needs 2 tolerances) it to be checked ONLY at 15mm from [A] to a tolerance of 1mm. I'm thinking it should be like:-
[TP][1.0][A] and a note "Measured at 15mm from [A]" or, put a boxed 15mm dimension line on the stud and TP pointing to the stud at that line?
Is this right? Are there other symbols or terminology that I am missing?
Hopefully I've explained it right, and any help is appreciated.
Thanks.
Ross.
David DeLong
Re: GD&T - True position callouts for sections of studs.
We have one stud that requires a positioning tolerance to be measured in heights of 5 and 15 mm. relative to primary datum A.
Do not use a projected tolerane zone. This is applicable to blind threaded holes and not in your situation.
Also, positioning tolerance is not applicable since you do not have a pattern of features or do not have any other datums than primary datum A. The onlyi relationship from datum A is perpendicularity. Your feature control frame should show a perpendicular requirement from datum A with a diametrical tolerance zone (checks the tilt in any direction) of value of 0.5 mm. The location should be shown with a chain line (like a center line but thicker) at a basic dimension of 5 mm from datum surface A. The basic dimension (rectangular box around it) and is a theoretical dimension. A leader line should be shown from the feature control frame to its location reflected by the chain line.
The second feature control frame would be a perpendicularity with a diametrical tolerance zone of 1 mm relative to datum A with an leader line showing that the location that is 15 mm above datum A. The 15 mm also should be shown in a basic dimension (box around it).
With perpendiularity, the 0.5 or 1 mm tolerance is the maximum tilt in any direction. If one reflected position with the center shown from datums A, B and C, the diametrical toelrance zone of 0.5 is really a radial tolerance of 0.25 maximum off location.
Again, positional is not appropriate if there is not pattern of holes or studs or the location (center) is not shown with datums B and C.
I hope this helps rather than confuses.
mr_bridger
Hi, Thanks for the help so far. I'm pretty sure I should have explained better though! lol. I did mention there were a pair of studs, but not about the pitch.
Here is a new picture, explaining in a little more detail and wondered if what is in blue would work.
I'm only interested in the pitch, not position in the other axis.
Prefer to use GD&T rather than +/- dimensions as this works better on CMM reports.
Ross.
David DeLong
Ross.
This is a bit better explanation.
The area in red should be shown as a hatched area with the upper line at 5 mm as a chain line (per ASME Y14.5M-94 and also 2009). You don't even need the hatched area as long as the 5 mm dimension is shown as a leader line or one could use a phantom line. .
The positional tolerance at both the bottom and top should be shown with a diametrical tolerance zone since the feature of size is round or cylindrical. The top feature control frame used MMC which is great and conducive to a checking fixture. You also have MMC in the bottom feature control frame but that is tough to make a checking fixture. I would probably suggest taking the MMC out of the more restrictive positional tolerance taken at 5 mm above datum A.
You don't have to any note below the feature control frame as long as the leader line is directed to the hatched area or the leader/phantom line on the cylindrical stud located 5 mm above datum A.
CycleMike Positional callouts on this print - GD&T true position question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
was named killer AS9100 FAIR - True Position hole out by .0011" on 50 parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B True Position Measurement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P True Position vs X and Y Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
M True Position / GD&T - I'm staring at this drawing and I'm lost Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N True Position of slot Boundary with MMC Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Measuring the True Position of a Cylinder's Pierce Point Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M True Position and MMC (Dilemma Between Engineers) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Tab to circle True Position? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S GD&T Callout for Diametrical True Position Manufacturing and Related Processes 6
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Surface Profile and True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D True Position with 1 hole (Datum B) at the Radius Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
L GD&T Bonus Tolerance - Checking True Position of a Pierced Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Using a Pin Gage to check True Position of Inline Holes, Design, Tolerance. Etc Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Checking True Position with Pin Gage Measurement Uncertainty (MU) 3
F How could this Hole Diameter and True Position problem have been Detected & Prevented Nonconformance and Corrective Action 27
J Multiplane True Position Calculations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Y Using PC-DMIS to measure True Position of the teeth of a Spline Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L Calculation of True Position of Slots (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J How to measure the True Position on an Optical Comparator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Using True Position to Control Symmetry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K True Position Checking such as Bolt Hole Position w.r.t Center Bore on Wheels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
J GDT True Position Secondary Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
J True Position with only 1 Datum - Referenced datum is the plane the hole is on Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
M True Position of a Hole Capabilty - Appropriate parameters to use Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Understanding True position - Drawing Feature Control Frames - ANSI Y14.5 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J True Position of slots that have angles as basic dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
Q GD&T True Position interpretation - True Position FCF on a B/P Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
B Calibration of Home Made Gages - Simple go/no-go gages to true position gages General Measurement Device and Calibration Topics 8
C True Position Question - What does this print callout mean? IATF 16949 - Automotive Quality Systems Standard 12
Q GD&T True Position structure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N How to Calculate a True Position on a Square Slot - GD&T Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
H History of True position formula Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
B True Position without tertiary datum? Establishing a proper rotation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
E Capability study on true position callout. What would be the upper and lower spec? Statistical Analysis Tools, Techniques and SPC 7
A Bidirectional True Position Tolerance Call-Out for Holes for Process Capability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Ppk/Cpk for geometrical true position of hole with MMC Capability, Accuracy and Stability - Processes, Machines, etc. 17
G GD&T Help (Y14.5M-1994) - True position callout box on two dowel holes Various Other Specifications, Standards, and related Requirements 16
J GD&T - True Position - "Boundary" under the feature control frame General Measurement Device and Calibration Topics 10
D Procedure for Fixture Gages that check True Position of holes General Measurement Device and Calibration Topics 4
M How to calculate a True Position toleranced at MMC - Capability of True Position Statistical Analysis Tools, Techniques and SPC 12
D Cpk for one sided dimension - GD&T true position Capability, Accuracy and Stability - Processes, Machines, etc. 15
F Calibration certificate content - Average Value and True Value ISO 17025 related Discussions 6
A True purpose of doing EST (Electrical Safety Test) on medical device Other Medical Device Related Standards 3
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Marc The Strange & Curious Tale of the Last True Hermit Coffee Break and Water Cooler Discussions 0
