GDT Callout Question
I am looking for some guidance on how to call out a note that requires some clamp load in order to measure the thickness at the bolt hole on an assembly print. One idea:
The OEM facility will completely compress the gasket joint upon installation to the mating interface in the vehicle. Does this callout make sense? Is there a better call out option for clarity? Any help would be appreciated! Thank you!
Proud Liberal
Is datum A defined with separate datum targets with location and size or is the inspection requirement to clamp over the entire area opposite the datum?
Another option is for all parties to agree on a inspection fixture that meets the requirement and reference that approved fixture in the notes. This totally controls how much of each surface (part, fixture, and clamps) is contacted and under what pressures. But depending on how much the 9-12 Nm clamps effects results, this might be overkill.
Ron Rompen
The note appears to be clear and I don't see any problem with it. The only codicil I would add is that the mounting surface (the 'flat surface' mentioned in the note) needs to be more clearly defined. How flat is flat? As Proud Liberal mentioned, an agreed-on fixture might be the most appropriate solution.
I am looking for some guidance on how to call out a note that requires some clamp load in order to measure the thickness at the bolt hole on an assembly print. One idea: View attachment 26813
I think you've done well. GD&T doesn't have a facility to tell us how to apply gages other than datum order. You're instructional note serves the purpose well. Just like in doing a Gage R & R though, I would test the instruction with three different people - make sure your understanding of what you are telling them is what they get out of it. To the degree you can use a photo in the instruction set, all the better.
Who is design responsible? You shouldn't be adding notes to a drawing that belongs to a customer, and you also shouldn't be deciding on your own how the part is to be inspected. You should be inspecting the part the same way that the customer does.
Jim Wynne is correct. When I read your note, I thought it was OK and you were the design responsible party. The instruction is fine if you prove it out, but certainly get agreement with the customer/designer. There are many times when agreement about how to measure goes far past launch and it is something that should be worked out in advance of start of production.
One great method to alleviate these sort of issues in a gage design meeting BEFORE the design of the gage is started. It should include design, production, quality and process engineering - but certainly, the gage company that is chosen to create the gage. You throw a print of the part on the table and discuss what the design intent is and how conformance will be measured. It takes about 4 hours and saves days of time.
I should point out that it's not unusual for job shops to create "shop" drawings that are derived from the customer print. These will usually show dimensions to be checked in-process, and might include notes that don't appear on the original. This can become a control problem, however, if it's not managed properly. In any event, using instructions that don't take into account the customer's methods for measuring a feature or features is not a good idea. A shop drawing should not include specifications or instructions that don't appear on the original.
J GDT True Position Secondary Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Capability & GDT Features - Surface Profiles, Line Profiles & Symmetries Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Reporting GDT (Geometric Dimensioning and Tolerancing) Bonus Tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
8 Surface Finish - Callout as 8 - 16 Rq Manufacturing and Related Processes 1
E Question on GD&T added to print - Positional callout for the small holes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
GoKats78 Callout on Surface Finish General Measurement Device and Calibration Topics 11
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
E Position of a milled hex - Print Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K Thread callout - M22 x 1.0-6H 0.100R Thread Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Drawing Callout - Arrow pointing to an inner edge where there is a radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Taper Callout - Allowance in terms I've not seen before Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
6 Print Callout for a Special Thread - 1.173-18 UNS-3A Major Dia. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
E Callout of a length dimension and then P.I at the end - What does that mean? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Help with a Metric Drawing Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
T How to interprete .600/.625 depth in the drawing callout ? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S GD&T Callout for Diametrical True Position Manufacturing and Related Processes 6
N The right method to Measure and Evaluate a Flatness Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
F Reason a plane would have a runout applied and not a flatness callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Drawing Callout: "Holes must be in line" No Tolerance specified Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
J Perpendicularity Callout on a Print - GD&T Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Need help with Japanese Specification - Wire callout of "SWIC-F-SW-C" Customer and Company Specific Requirements 4
A Capability Studies for Profile (GD&T Callout) Capability, Accuracy and Stability - Processes, Machines, etc. 6
QMMike MS-DC28, Type B, CPN 2647 - anybody have any information on this callout? Various Other Specifications, Standards, and related Requirements 1
B Pointless GD&T Position Callout? Feature is labeled as a Key Characteristic Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
T GD&T: Boundary - Callout for an Oblong Hole (Slot) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
Frank T. ASTM F104 Callout Interpretation - .xls Excel Spreadsheet Various Other Specifications, Standards, and related Requirements 0
CycleMike Profile of datum planes - Profile callout back to datum A (itself) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Angularity or Composite profile - Angularity callout on a recent print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B Dimensions and Tolerance Callout - Straightness of shaft - Concentricity Manufacturing and Related Processes 1
C True Position Question - What does this print callout mean? IATF 16949 - Automotive Quality Systems Standard 12
C Definition GD&T Clarification - Callout for Profile of a Surface Reference to the Datum Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 34
Ron Rompen Unusual GD&T Callout similar to the MMC or LMC symbol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
E Capability study on true position callout. What would be the upper and lower spec? Statistical Analysis Tools, Techniques and SPC 7
Ron Rompen Does this print callout meet ASME Y14.5 1994 General Measurement Device and Calibration Topics 25
G GD&T Help (Y14.5M-1994) - True position callout box on two dowel holes Various Other Specifications, Standards, and related Requirements 16
K Honda Surface Roughness Callout (ex. 12.5S) Customer and Company Specific Requirements 5
dinaroxentool Question about FDA Classification of a Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Another DFAR question 252.225-7009 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
F Conflict Mineral Smelter Question RoHS, REACH, ELV, IMDS and Restricted Substances 8
R NRTL - Scope Question - Off-the-Shelf Plug In IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D API 6A Certification Question Oil and Gas Industry Standards and Regulations 4
dinaroxentool Question about qualification as a medical device or accessory in Europe EU Medical Device Regulations 2
R DHR question: Traceability of components ISO 13485:2016 - Medical Device Quality Management Systems 2
C MDR - Question around software accesories EU Medical Device Regulations 2
Watchcat Authoritative References about the Research Question? Quality Tools, Improvement and Analysis 0
T Question about Quality Department employee position titles Quality Manager and Management Related Issues 7
N Question on creepage/clearance requirements for HF Active Accessories for 2nd edition 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
I Question 1 - Nitpicking on Document Approval - can a document approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Question: How to create an IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
K Question on whether IEC 60601-2-62 standard is applied IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
