GDT Question - is this even correct?
Ron Rompen
I am attaching a file with part of a drawing on it. My question relates to the callout on the LEFT side of the drawing.
This calls the position of the 71.5 diameter (tolerance 0.25 diametrical) when restrained to A and B (B is on the right side of the drawing)
My interpretation of this is that the diameter (which is also identified as datum A) can NEVER have a position error greater than zero (when called out the way it is). Since it is a datum feature, and is used to create the alignment, it can only be at the 'perfect' position.
Am I interpreting this correctly?
Thanks for any feedback.
John Predmore
Ron, you should have this conversation with the design-responsible engineer. FWIW, my interpretation is the 71.5 diameter is located with a tolerance of position related to the centerline connecting the A feature and the B feature, which is not the same as A datum. In the feature control frame, both A and B and the 0.25 tolerance use the MMC modifier, which is done to enable fixed gage tooling. I don't know how the tube was made, but the centerline A on the physical part might not be perfectly aligned with the centerline of B, so the position of 71.5 is measured with respect to the combination of A-B, plus bonus tolerance from the MMC modifier. BTW, the datum of a cylindrical feature is the centerline, not the diameter.
Sebastian
Positional Tolerance - an overview | ScienceDirect Topics
"Common datums"
1. Position of cylinder with diameter 71,5, height 22 shall not exceed 0,25 MMC against common datum consisting of cylinder with diameter 71,5, height 22 MMC and cylinder with diameter 70, height 27,5 MMC
2. Position of cylinder with diameter 70, height 27,5 shall not exceed 0,25 MMCagainst common datum consisting of cylinder with diameter 71,5, height 22 MMC and cylinder with diameter 70, height 27,5 MMC
Correct me, if I am wrong.
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
Ron Rompen Clarification of GDT callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
2 GDT of datums - Putting Datum C on a drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T GDT Callout - How to call out a note that requires some clamp load Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
P Capability & GDT Features - Surface Profiles, Line Profiles & Symmetries Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Reporting GDT (Geometric Dimensioning and Tolerancing) Bonus Tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J GDT True Position Secondary Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S Question about granite surface plates out of spec AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Ed Panek MDR question - Meaning of Stability CE Marking (Conformité Européene) / CB Scheme 6
B GD&T Question, True Position Confusion Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Initial Importer question Other US Medical Device Regulations 0
Ed Panek Calibration question Manufacturing and Related Processes 4
M Class Exempt Medical Device Recall Question US Food and Drug Administration (FDA) 3
sonflowerinwales Metric or Imperial; that is the question... After Work and Weekend Discussion Topics 6
M Can someone help me with this CMM programming question? Manufacturing and Related Processes 2
A A strange question about predicate device selected in 510(k) submission Medical Device and FDA Regulations and Standards News 8
S Question regarding AQL - ISO 3951 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
D Document Control Question involving DocuSign US Food and Drug Administration (FDA) 6
JoeRandom11 Question about Customer Supplied Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M ISO 13485: 2016 Lot numbering question ISO 13485:2016 - Medical Device Quality Management Systems 4
S Nadcap - Heat Treatment Proof of Verification question for Digital results AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
JoeRandom11 Question of Calibration Cycles AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
D Software Validation Question ISO 13485:2016 - Medical Device Quality Management Systems 10
B 8.5.1.1 Control Plan - question audit NC IATF 16949 - Automotive Quality Systems Standard 5
C Document Identification Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D Question regarding PCR workstation Fume Hood upon first use ISO 13485:2016 - Medical Device Quality Management Systems 0
Moncia ISO 9001 calibration question please ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Quality Specialist Quick question on the sequence of ISO 17025 external audits ISO 17025 related Discussions 14
D ISO 13485--Question regarding performing calibrations in house. ISO 13485:2016 - Medical Device Quality Management Systems 13
S Document numbering question? ISO 13485:2016 - Medical Device Quality Management Systems 7
J Has the facility been inspected? question in Certificate to Foreign Government application Other US Medical Device Regulations 0
M ESTAR 510(k) submission question Medical Device and FDA Regulations and Standards News 0
J Question on clause 5.2.2 IEC 62304 - Medical Device Software Life Cycle Processes 2
Ed Panek ISO 15223 Question EU Medical Device Regulations 2
R Question: Cg/Cgk formula Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Quick question on responsible person's experience requirements UK Medical Device Regulations 3
J PFMEA/control plan question- PLEASE HELP ! IATF 16949 - Automotive Quality Systems Standard 8
3 Scope question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Question regarding "Customer Property" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
T Noob question regarding sample size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
K 510(k) Manufacturer question (private label and manufacture under another persons 510(k)) US Food and Drug Administration (FDA) 1
M Question About Rolled Throughput Yield Manufacturing and Related Processes 5
M Quick Gage R&R Question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S Question: Best alternatives to audits for ensuring compliance Quality Tools, Improvement and Analysis 5
Ed Panek Question from 13485 Auditor ISO 13485:2016 - Medical Device Quality Management Systems 2
C Question on KAFO (Knee Ankle Foot Orthosis device) classification CE Marking (Conformité Européene) / CB Scheme 0
T BMW GS 93010-2 Question Various Other Specifications, Standards, and related Requirements 1
S FDA 510(K) submission question US Food and Drug Administration (FDA) 4
Ron Rompen Question regarding CMM probe damage General Measurement Device and Calibration Topics 4
T FDA UDI Question - Class II Medical Device Other US Medical Device Regulations 2
