Gearing up GMP based systems for continual improvement.
v9991
long story cut short :
currently compliance scenario in pharma/medical device seems to be driven by 'evidence-based' and 'control-based' verifications!
what steps needs to be taken [by both industry and regulatory] to move the pharma/Device-'systems-implementations' towards continual improvement?
Background :
GMPs traditionally lay emphasis on procedures-controls-validations-and-documentation.
The most famous adage in pharma industry is that..."If its not documented its probably not done!!.."
By and large, the whole emphasis of 'compliance' for both product-quality and quality-systems revolves around 'documentation!' and adopted by every regulatory agency! If there is any digression then its there for some extent on 'controls' !...
Moving away from the above scenario...although agencies started to talk about the aspects such as:
1. Quality systems - approach to GMPs;
2. Risk based approach to GMPs;
3. PAT etc
The momentum is yet to pick up. [I might be corrected here if there are better informed persons of the industry trends in adopting the above approaches!]
And my following query is about one of the bottle-neck/problem/ambiguity which I feel is hampering the progress towards the "evolution of GMPs" which will certainly benefit agency & industry alike.
Of the aspects mentioned above,
point 2 and 3 are probably understandable for me! And more of concept/technology oriented;
when it comes to point 1; quality systems approach to GMPs, can anybody help me outline the changes required and how to measure/follow-up them.
Queries:!:
1. What changes are required to be made [to SOPs] in order to take make it aligned with “quality systems approach to GMP.”
2. How do we measure them for compliance; do we follow the same procedure through documentation!.
3. Apart from the compliance how do we focus continuous improvement...
You can also share your thoughts on the sequence of steps; challenges; bottle-necks; and the way forward. etc.,
Thanks in advance.
valiveti
MIREGMGR
Perhaps I don't understand the intended point, but I don't see a fundamental disconnect between the FDA's GMPs and a "continual improvement" approach...assuming that the latter is applied with a sufficiently rigorous expectation of substantial compliance before sales/deliveries are permitted.
I must say that my experience with 13485/MDD to date in the medical device world has been that those auditors with whom we have dealt have sometimes been overly willing to accept evidence of continual improvement in areas of marginal adequacy. I've seen a couple of instances so far in which they have postponed judgment on marginal issues until the next regular inspection, instead of requiring that the system be fully effective in order for shipments to be permitted. In that regard, my perspective is that a goal=continual-improvement system may at times be less effective than a goal=compliance-now system...with the degree of difference being dependent on auditor judgment calls.
Assuming, though, that the audit process is sufficient rigorous, I don't see why adding a continual-improvement expectation to an existing requirement for GMP compliance would be complicated or disruptive.
v9991
obviously, one has to ask right:eek: question to get an apt answer! let me try to refine my query
quick response to the thoughts from 'Miregmgr'
1. "...Perhaps I don't understand the intended point,..."..i hope the revised query clarifies!...
2. "...disconnect between the FDA's GMPs and a "continual improvement" approach...assuming that the latter is applied with a sufficiently rigorous expectation of substantial compliance before sales/deliveries are permitted...."; how would you qualify the words "sufficient...rigorous... and 'substantial" compliance... and thats exactly is my query. my impression is that there are little references/case-studies available to the end-users which could help them get on track.
3. "...In that regard, my perspective is that a goal=continual-improvement system may at times be less effective than a goal=compliance-now system...with the degree of difference being dependent on auditor judgment calls..."now, that [only!] signifies need to comply[ or over-come] the deficiency in the system/process ; where is the drive to inculcate the continuous improvement...make it quality-culture irrespective of the regulatory-audit...
4. "....Assuming, though, that the audit process is sufficient rigorous, I don't see why adding a continual-improvement expectation to an existing requirement for GMP compliance would be complicated or disruptive...."i am sorry:bonk:if my first query has lead to that impression; nevertheless, could you further your thoughts with examples/areas/procedures to make "continuous improvement" a critical cornerstone of GMPs.
anyway thanks for your thoughts.
MIREGMGR
Is your interpretation that "continuous improvement" should retain the same priority once the quality system has achieved a level of performance that results in a very high level of assurance that all delivered products are safe and effective as defined by relevant standards and as evidenced by post-market user information?
My perception is that in the 13485/MDD medical device world, there is a general perception of a threshold of high performance at which the above goal has been reached. Improvements beyond that threshold are of course welcome, but not essential and do not justify changes and costs that could create a risk of diminishment, rather than improvement, of product quality. Thus "continual improvement" is a non-linear goal.
Certainly in the FDA GMP world, in the absence of 13485/MDD, the concept of a threshold of acceptable performance ("not good enough to deliver safety and effectiveness" or the converse) is well established.
In my experience, it's not common in the medical device world to perceive continual improvement without reference to the state of the products relative to defined requirements and the costs and risks associated with further changes, as desirable.
To specifically address one of your comments: my perception is that an organization operating per FDA GMPs can relatively simply add continual improvement to its QMS by adding ISO 13485/MDD compliance and certification to its regulatory focus.
M Europe GMP medical devices - Combination products - Ancillary medicinal substance CE Marking (Conformité Européene) / CB Scheme 4
E Qualification for non gmp service providers Supplier Quality Assurance and other Supplier Issues 1
A Interpretation of GMP Requirements for class 1 medical device manufacturer (device GMP exempt, only General controls applicable) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
O ISO 13485 vs. GMP - Comparison matrix wanted EU Medical Device Regulations 4
E Preparing for the ASQ CPGP (GMP professional exam), how to revise and remember the vast syllabus? ASQ - American Society for Quality 2
E Non-GMP examples in Pharmaceutical industry Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
K ANVISA B-GMP Auditing requirements for Contract Manufacturers Other Medical Device Regulations World-Wide 1
N Can a (class I) medical device be manufactured in a GMP certified site with no ISO13485? EU Medical Device Regulations 18
Q Need clarification on requirements.... Class i, gmp & 510(k) exempt Medical Device and FDA Regulations and Standards News 12
E South Korea, MFDS - GMP inspections Other Medical Device Regulations World-Wide 4
E MDSAP Audit - Our QMS conforms to ISO 13485:2016 and FDA GMP Canada Medical Device Regulations 9
A Any recommendation for ASQ's CPGP (Pharmaceutical GMP Professional) Certification exam questions? ASQ - American Society for Quality 2
W Interesting Discussion Class I, GMP Exempt and IEC62304 IEC 62304 - Medical Device Software Life Cycle Processes 2
J Brazil GMP license work with multiple BRH? Other Medical Device Regulations World-Wide 3
I GMP 21 CFR Part 11 Electronic Records Compliance Project Help Qualification and Validation (including 21 CFR Part 11) 9
W EU GMP Annex XI - What is an "appropriate QMS"? Other Medical Device Related Standards 2
S Compliance to Brazil GMP requirements Other Medical Device Regulations World-Wide 12
A Brazil - New RDC 183 - CBPF (GMP) question Other Medical Device Regulations World-Wide 6
L ISO 13485 and European GMP ISO 13485:2016 - Medical Device Quality Management Systems 3
I Moving into Clinical Trials and need to find GMP Suppliers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Who can make a Correction of Entry on GMP Records Other Medical Device and Orthopedic Related Topics 1
S Traceability and the initiation of GMP Activities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
A How do we implement a Process Approach ISO 13485:2016 - Existing GMP QMS Other ISO and International Standards and European Regulations 2
J KGMP (Korean GMP requirements) vs. ISO 13485 Other Medical Device Regulations World-Wide 5
R Network/Computer Data Migration Sampling GMP Software Quality Assurance 1
S Could the term "GMP" be used in a Medical Device world? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
D I need an example GMP Manual Document Control Systems, Procedures, Forms and Templates 2
V Which SOPs are required by GMP? US Food and Drug Administration (FDA) 2
somashekar GMP (Good Manufacturing Practices) essential information URL Manufacturing and Related Processes 1
S Any suggestions for ASQ CPGP (Certified Pharmaceutical GMP Professional) exam prep? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
J GMP vs Service-Repair Practices - Service Centers Service Industry Specific Topics 2
jkuil Calibration before and after relocation of GMP manufacturing equipment Calibration Frequency (Interval) 7
I GMP?s for Medical Devices in Panama Other Medical Device Regulations World-Wide 1
E Korean GMP Guideline updated to Second Revision - April 2014 Other Medical Device Regulations World-Wide 1
O Implementation of GMP - Technical files for ANVISA Registration Other Medical Device Regulations World-Wide 3
D How to handle a blood stained GMP document ? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
0 GMP Guideline for Recycled Plastic Flakes used in Food Applications Quality Manager and Management Related Issues 4
Q FDA and Medical Device Exemptions from GMP Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Good Manufacturing Practices (GMP) for the Aerospace Industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Wooden Pallets in GMP Manufacturing Space Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
AnaMariaVR2 Documentation and Records: Harmonized GMP Requirements Document Control Systems, Procedures, Forms and Templates 1
AnaMariaVR2 FDA GMP Inspectors Cite 70% of Dietary Supplement Firms Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
C I am looking for a GMP / HACCP Checklist Quality Manager and Management Related Issues 2
M Revision of Brazilian GMP Regulation - RDC 16/13 (RDC 59 and Portaria 686) Other Medical Device Regulations World-Wide 7
AnaMariaVR2 ANVISA Considers Accepting Foreign GMP Certifications US Food and Drug Administration (FDA) 0
B ANVISA B-GMP Inspection Schedule Other Medical Device Regulations World-Wide 4
somashekar Who can provide a WHO GMP certificate in India acceptable to the CDSCO Other Medical Device Regulations World-Wide 6
S GMP Comparative Information for Canada, US and Europe Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
P Non Conformance Reporting in GMP in the Control of Materials Nonconformance and Corrective Action 1
A GMP (good manufacturing practices) presentation materials 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
