Generic control plan - Check Part to Print
Bill Ryan - 2007
#11
Atetsade
I can't envision any time a Control Plan would be "larger" (by weight or volume) than a PFMEA. If your Control Plan is "growing exponentially", I would need to understand your Control Plan methodology. If something is not addressed in the PFMEA, it should not be "showing up" in the Control Plan.
As I read your post, it sounded to me as if you might be letting the Control Plan "drive" your PFMEA. This, if fact, is absolutely backwards.
Do all your nuts go through the same process flow (drilling, tapping, forming, thread rolling, knurling, boring, recessing, finishing, burnishing)? If so, a "generic" Control Plan might be a relatively simple excersize. You could certainly do operation specific CPs but if most of your nuts all follow the same flow, one CP should suffice. The "oddball" parts would then need their own Flow Diagram, PFMEA, and CP. The operation "doesn't care" whether a feature is a KPC, what size the threads might be, or what the material is made out of. It only "spits out product" as it was set up to do. The Failure Causes very well could (should?) be generic and that is how to approach a "generic" CP (and PFMEA). Once you have the "generic baseline", if your customer(s) require part specific documents, simply changing the header information and a couple of dimensional callouts on the CP (if you list dimensions - which goes away from the generic) should make life pretty easy.
Gotta run pretty quickly. I'd be more than happy to continue with this if you can give a little more detail of your operations.
Bill
CINDY
#12
All of our operators refere to our control plans. It is build into our system. Our control plans feed to the FMEA. If a characteristic is not on the CP how can it be on the FMEA?
Cindy
Bill Ryan - 2007
#13
Cindy
I'll turn it back to you. If a Failure Mode (or Cause) is not addressed in the PFMEA, why would it be in the Control Plan?
To have the Control Plan "drive" the PFMEA is merely filling out paper and not truly embracing PFMEA. Sorry, I'm fairly passionate about PFMEA and to "do it backwards" just doesn't make much sense to me.
Bill
CINDY
#14
Bill,
We are monitoring the part characteristics in the control plan. Those characteristics, not all, but most are where the potential failures are from within our process for that part. We may also add to the FMEA, but the majority of the time, the control plan feeds the FMEA.
We thought that depending on each part characteristic, our control plan should have the limits build in. But I should also state that most of the time we build our own characteristics to monitor. We generally do not have special characteristics specified by the customer.
I never thought we were doing this backwards, please explain further.
Cindy
Bill Ryan - 2007
#15
I'm going to start down a path here. Please don't be surprised if I wander or get "lost".
The Control Plan is actually the third "step" in the "PPAP series of documents".
Step 1 is listing the processing steps (Process Flow Diagram (PFD)). This includes all steps the part goes through from receiving to shipping (including inspection, transfers, storage).
Step 2 is listing these processing steps in the far left column of the PFMEA. The Potential Failure Mode column lists part characteristics as defined on a part drawing, part model, or whatever means your customer conveys fit/function characteristics to you (each Potential Failure Mode needs a Detection method). The Potential Cause column lists those processing parameters/issues which can lead to the Failure Mode occurring at that operation/step. If you have a Prevention Control for a Potential Cause, it will be listed in that column on the PFMEA.
Step 3 is taking all the defined Potential Failure Modes (from the) PFMEA and listing them in the "Charateristic - Product" column of the Control Plan (once again at the appropriate operation/step). The "Characteristic - Process" column of the Control Plan lists all the Prevention Controls from that column of the PFMEA. The rest of the Control Plan, basically, details how you are "controlling" each product and process characteristic.
A well done PFMEA will virtually write your Control Plan for you.
If your Control Plans do not address the Process Characteristics then I submit to you that you have only a "product inspection sheet" and not a Control Plan. If that is the case, it helps explain to me how your Control Plan is "driving" your PFMEA.
I hope that helps explain my take a little.
Bill
S Family / Generic type of FMEA & Control Plan and Symbols FMEA and Control Plans 3
C Control Plan Template (Generic) Document Control Systems, Procedures, Forms and Templates 0
C Confidentiality - Minimum / Generic Information on Control Plan FMEA and Control Plans 1
S Control Plans - A few control plans that are generic enough to represent the facility FMEA and Control Plans 1
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
V Generic ISO 50001 checklist Various Other Specifications, Standards, and related Requirements 6
N Generic Rework/Reprocessing Procedure Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
M Is IEC 60601 compliance possible when only generic power-supply is specified? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Marc The Risks of Generic Drugs Coffee Break and Water Cooler Discussions 24
R Connection to a generic separate power supply IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
Marc Are you looking for ISO 31000 - Risk Management Principles and Generic Guidelines? ISO 14971 - Medical Device Risk Management 1
C Appropriate ways to address Competency? Generic vs Specific ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Marc Urine Spills Staining Image of Wockhardt?s Generic Drugs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Ajit Basrur FDA - Guidance for Industry - Generic Drug User Fee Amendments of 2012 - Q & A US Food and Drug Administration (FDA) 0
M Engineering Change Management Generic Procedure Manufacturing and Related Processes 3
D FDA MDDS - Listing Obligations for a Generic Data Interface US Food and Drug Administration (FDA) 3
R Do generic forms bought over the counter need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Should the FSMS have a Documented Generic Procedure for Verification and Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
T Generic Guides for Procedure Writing Document Control Systems, Procedures, Forms and Templates 20
S Draft Guidance on Generic Drug User Fee Amendments (GDUFA) 2012 Other US Medical Device Regulations 0
AnaMariaVR2 Generic Drug User Fee Act (GDUFA) US Food and Drug Administration (FDA) 0
I Question on Declaration of Conformity for device subcategory or generic device groups EU Medical Device Regulations 2
P Generic Contract Manufacturing of Generic Prescription Medications Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
A Generic or Specific Gauge R&R on Standard Equipment (ie.: Micrometer) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Hershal Couple of generic TickIT and ISO 27000 questions IEC 27001 - Information Security Management Systems (ISMS) 9
Q Numbering or Naming (Identification) of Generic Company Specifications? Document Control Systems, Procedures, Forms and Templates 3
S Complaint Process flow: Need a generic definition which would flag an "MDR" Customer Complaints 7
optomist1 Generic question regarding Two Way ANOVA Results Statistical Analysis Tools, Techniques and SPC 8
D Seeking Help: Nondisclosure vs. generic QMS documents Misc. Quality Assurance and Business Systems Related Topics 10
M Generic "Compliant Procedure" and "Non-conformance" forms needed Document Control Systems, Procedures, Forms and Templates 1
K Generic Product Development Documents that need Analysis in a Complaint Investigation Problem Solving, Root Cause Fault and Failure Analysis 2
D Process Documentation is extremely generic IATF 16949 - Automotive Quality Systems Standard 4
O Process Audit Checklist - Generic vs. Process Specific Process Audits and Layered Process Audits 17
K Generic worksheet for calculating Supplier Chargeback and Cost of Poor Quality (COPQ) Supplier Quality Assurance and other Supplier Issues 2
Ajit Basrur Facts and Myths about Generic Drugs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
P Device Subcategory and Generic Device Group differences EU Medical Device Regulations 2
R Audit N/C - Quality Policy too generic? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
N Clinical trials - Generic "parent" procedure vs. study-specific "child" versions Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
G Any rule to set Generic Process Target % (per cent) Manufacturing and Related Processes 2
P Generic Label Die Cutting Process flow Manufacturing and Related Processes 5
C Production Audit Checklist - Generic General Auditing Discussions 14
Ajit Basrur GIVE (Generic Initiative for Value and Efficiency) Launched by the FDA (US) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
K Generic Term for Inspection Types FMEA and Control Plans 15
B Generic list of ISO9001 processes for an organisation (manufacturing set up) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
H FDA Site generic Supplier Related forms help needed ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Does anyone have a generic Product Specification template? Document Control Systems, Procedures, Forms and Templates 7
G Is there a standard or generic set of PPAP documentation available? APQP and PPAP 4
G Generic Value Stream Map - Example of how Lean can be applied in a Call Center Lean in Manufacturing and Service Industries 8
