Generic Product Development Documents that need Analysis in a Complaint Investigation
K
krishna007
Dear Fellow Covers
being thankful for your informative and insightful discussion, i would like to ask you on your comments/suggestions and insights and as well checklists (if available) on the following topic:
Overview:
- whether is it possible to generically define (like a checklist) to say that a particular set of R&D documents could always be analysed during a root cause analysis/failure investigation
Situation:
- Let us say a particular product complaint/failure is because of root cause like a manufacturing defect/process change where validation was inadequate/design flaw etc
- offcos you execute a 5-why analysis, cause-effect diagram in a complaint/failure investigation team,
- still you do analyse the relevant product development documents like the FMEA, specification documents (both component & system) etc
Questions:
- as i have already cited in the overview, can we define a checklist that contains list of documents that would be analysed in a failure investigation
- spec docs - system/component/process
- FMEAs - Process & Design & System
- (design & process) validation reports/protcols
- test plans/procedures/instructions used in manufacturing
- incoming inspection checklists to check material/product from suppliers
- usability plans/reports
- User manuals
- Service manuals
etc..
Working in the medical device industry, i believe any defined process and also a supportive checklist would do a great job in doing a full-fledged investigation and also to track change control.
Please also advice with your critics as well, whether any such thought would be encouraged.
Eager to see your discussion and guidance.
thank you
krishna
Stijloor
Re: Generic Product Development Documents that need Analysis in a Complaint Investiga
Dear Fellow Covers
Overview:
Situation:
Questions:
- User manuals
- Service manuals
etc..
thank you
krishna
Any comments?
Thank you very much.
Stijloor.
yodon
COULD you do it? I suppose. But I believe you would be adding no-value-added activities to the process. Your investigator should know / have available all the resources necessary - so I can see where maybe an index might be helpful, especially if there are a lot of documents. But to have to go through each document on the checklist just because your process said you have to seems like wasted effort.
Take a specific (hypothetical) example. Suppose you have a device that illuminates an LED when you turn it on. You get a bunch of complaints that the LED is not on when the device is turned on. You do a root cause analysis and find that you got a batch of LEDs that malfunction after being illuminated 3 times. What good would a required review of the service manual or functional requirements do in this case?
The investigator needs to take sufficient time to thoroughly investigate and identify the root cause(s). I think having any pre-defined activities just increases the potential for adding unnecessary burden.
Q Does anyone have a generic Product Specification template? Document Control Systems, Procedures, Forms and Templates 7
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
V Generic ISO 50001 checklist Various Other Specifications, Standards, and related Requirements 6
N Generic Rework/Reprocessing Procedure Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
M Is IEC 60601 compliance possible when only generic power-supply is specified? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S Family / Generic type of FMEA & Control Plan and Symbols FMEA and Control Plans 3
Marc The Risks of Generic Drugs Coffee Break and Water Cooler Discussions 24
R Connection to a generic separate power supply IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
Marc Are you looking for ISO 31000 - Risk Management Principles and Generic Guidelines? ISO 14971 - Medical Device Risk Management 1
C Appropriate ways to address Competency? Generic vs Specific ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Marc Urine Spills Staining Image of Wockhardt?s Generic Drugs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Ajit Basrur FDA - Guidance for Industry - Generic Drug User Fee Amendments of 2012 - Q & A US Food and Drug Administration (FDA) 0
M Engineering Change Management Generic Procedure Manufacturing and Related Processes 3
D FDA MDDS - Listing Obligations for a Generic Data Interface US Food and Drug Administration (FDA) 3
R Do generic forms bought over the counter need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Should the FSMS have a Documented Generic Procedure for Verification and Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
T Generic Guides for Procedure Writing Document Control Systems, Procedures, Forms and Templates 20
S Draft Guidance on Generic Drug User Fee Amendments (GDUFA) 2012 Other US Medical Device Regulations 0
C Control Plan Template (Generic) Document Control Systems, Procedures, Forms and Templates 0
AnaMariaVR2 Generic Drug User Fee Act (GDUFA) US Food and Drug Administration (FDA) 0
I Question on Declaration of Conformity for device subcategory or generic device groups EU Medical Device Regulations 2
P Generic Contract Manufacturing of Generic Prescription Medications Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
A Generic or Specific Gauge R&R on Standard Equipment (ie.: Micrometer) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Hershal Couple of generic TickIT and ISO 27000 questions IEC 27001 - Information Security Management Systems (ISMS) 9
Q Numbering or Naming (Identification) of Generic Company Specifications? Document Control Systems, Procedures, Forms and Templates 3
S Complaint Process flow: Need a generic definition which would flag an "MDR" Customer Complaints 7
optomist1 Generic question regarding Two Way ANOVA Results Statistical Analysis Tools, Techniques and SPC 8
D Seeking Help: Nondisclosure vs. generic QMS documents Misc. Quality Assurance and Business Systems Related Topics 10
M Generic "Compliant Procedure" and "Non-conformance" forms needed Document Control Systems, Procedures, Forms and Templates 1
D Process Documentation is extremely generic IATF 16949 - Automotive Quality Systems Standard 4
O Process Audit Checklist - Generic vs. Process Specific Process Audits and Layered Process Audits 17
K Generic worksheet for calculating Supplier Chargeback and Cost of Poor Quality (COPQ) Supplier Quality Assurance and other Supplier Issues 2
Ajit Basrur Facts and Myths about Generic Drugs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
P Device Subcategory and Generic Device Group differences EU Medical Device Regulations 2
R Audit N/C - Quality Policy too generic? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
N Clinical trials - Generic "parent" procedure vs. study-specific "child" versions Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
G Any rule to set Generic Process Target % (per cent) Manufacturing and Related Processes 2
P Generic Label Die Cutting Process flow Manufacturing and Related Processes 5
C Production Audit Checklist - Generic General Auditing Discussions 14
Ajit Basrur GIVE (Generic Initiative for Value and Efficiency) Launched by the FDA (US) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
K Generic Term for Inspection Types FMEA and Control Plans 15
B Generic list of ISO9001 processes for an organisation (manufacturing set up) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
H FDA Site generic Supplier Related forms help needed ISO 13485:2016 - Medical Device Quality Management Systems 2
G Is there a standard or generic set of PPAP documentation available? APQP and PPAP 4
G Generic Value Stream Map - Example of how Lean can be applied in a Call Center Lean in Manufacturing and Service Industries 8
D Generic Statement for Measurement Uncertainty for a Quality Manual Quality Management System (QMS) Manuals 6
A Frustration - New to the Medical Device field, I come from generic pharmaceuticals ISO 13485:2016 - Medical Device Quality Management Systems 14
M How good are the generic Quality tools? Quality Tools, Improvement and Analysis 9
