Generic Value Stream Map - Example of how Lean can be applied in a Call Center
G
giles cory
I work in a Six Sigma shop and have recently started to study Lean on my own time. I want to convince my boss to get me some formal training or, at least, pay for some text books.
If I can show him an example of how Lean can be applied in a call center it would help greatly. I have limited knowledge, but tried to construct the current vsm and possible future. However, it's not good enough for presentation.
Does anyone out there have a typical example?
Marc
Fully vaccinated are you?
I know this is an older thread, but does anyone have anything that would add to the information database here? My Thanks in advance!
DanteCaspian
First steps are often the most difficult. It is often the initiative and dedication of one or a few that can persuade the change.
"Formal" education at this stage, in your case, may not be necessary. Education is.
Get yourself a few of the top books by authors James Womak, Dennis Pascal and Norman Bodek.
For all processes and understanding of VSM is required. Pick up, Creating Continuous Flow by Mike Rother & Rick Harris, and Learning to See
by Mike Rother and John Shook.
Now, "knowing lean" is never sufficient. There must be a skilled leader, or team of leaders to create the motivation and vetting of culture change that equates to continuous improvement. If you have the drive and can gain the confidence of people in time, get started! ;)
At some point you will have to read The Toyota way, to get a sense of the genesis, the psychology and true intentions of Lean, but it can be more of a difficult read for those just embarking on the journey.
Lastly, but as impotent, network. Find those in your area or anywhere that can share ideas and help.
Some Six Sigma places have a hard time wrapping their head around this stuff; but with the right examples done, you will gain momentum and credibility.
P
pthareja
I endorse DanteCaspian fully, especially backing the cultural part. If one has the will, one would find a way. Knowing VSM will render the process a scientific flavour, a fire for accelration to identification of wastes and redundancies, but never the culture to react to that.
When you say Tayota way's reading is tedious, yes it supports the anticultural rigidness to wastes. If there were a cultural alignment, then every Toyota way was just obvious?
So for Lean, keep learning, the Life cycle way -ever renewing with culture, concepts and Change!
Priyavrat Thareja
Duke Okes
I doubt that lean will be very useful in a call center, but six sigma definitely would be.
DanteCaspian
Six Sigma is very useful, yes, but I have not found an industry where Lean has not been able to boost performance, eliminate unnecessary wastes, increase value and profit.
I have personal lead it in: retail (mom & pop size to large), warehouse, customer service, manufacturing, process engineering, engineering, parts and component design, photography post process, supply chain management (particularly purchasing), scheduling, quality assurance fields, task management, home building and more. Tailored to each environment It always shows measurable gain and improve shareholder and employee work environments.
Six Sigma and Lean are combined in many businesses and by consultants because of this.
P
pthareja
I M Possible? that's the right attitude
Why not try Lean in a call center scenario?
Well identify the wastes? Waiting .. call on hold, Multiplexing equipment faults, routing refused..line down, or simply process wastes.
Is clubbing of requisite info club-able ( Viz. Is flight on schedule?)
I am not from Telephony or info services/ PR so can't contribute much.
But there are several experts around.
Priyavrat thareja
H
Harold P
While working as a Consultant I conducted a couple of projects in Call Centers where the focus was to introduce elements of Lean. I will be up front that this was not a pure lean implementation as the companies we were working with had thier own desired outcomes. I am not with this company any longer so I cannot provide the Value Stream Map file.
Their goals were to improve Service Level, improve CSR consistency (they had many different centers throughout the US and wanted to appear as one company) and improve sales dollars generated by CSR's.
Standard work and instruction played a huge role in helping us improve CSR Consistency as well as improving Sales $. The first thing we did was standardize company expectations as to what should occur during a call. While some of the specifics were dependent upon which department the CSR was in (i.e. - Tech Support, Customer Service, activations, etc) the main pieces such as proper greeting, call etiquette, listening skills, ability to ask clarification questions, etc were standard. We worked with Supervisors and Senior CSRs to identify everything from how we should answer a call ("Thank you for calling Company X. My name is Bob, how may I assist you?") to what defined good listening skills (using customer name, avoided having customer repeat information, etc). Once a standard call was established we rolled out the new expectations. This was done repeatedly through center meetings, team meetings and one-on-one trainings. Once it was rolled out and all CSRs were trained we began a formal, standard call monitoring system looking for coaching opportunities.
Training included helpful sales techniques and we used actual call examples to show how successful these tips were. This helped with buy in and through discussion we began sharing and documenting "best practice" sales methods. This is the part the helped impact the sales dollars.
Service Level also began to improve while we were doing this. Calls were handled faster as CSRS were better prepared so customers were getting better service and the company was able to handle more calls with the same staffing while making more revenue / call.
In addition to focusing heavily on Standard Work we introduced 5S techniques as well. We standardized what resources each CSR should have at their desk and where other support materials (sample phones, sales ads, etc) were to be kept.
Hope these ideas help.
citeam
I disagree. I have successfully worked with teams in call centres (complaints) in several locations & Lean overpowered Sigma by quite a stretch. Sigma simply proved or disproved the hypothesis in numerical terms.
The real winner was the identification of the waste within the process due to previous 'prolonged resolution' of the complaints (CS VSM to FS VSM).
The results led to the removal of AHT which resulted in the CUSTOMER being satisfied significantly at FPOC.
Ajit Basrur GIVE (Generic Initiative for Value and Efficiency) Launched by the FDA (US) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
Hershal The Value of Professional Certifications - Generic question Professional Certifications and Degrees 31
T Assessing risk where harm is indirect - Generic devices / accessories / intermediates ISO 14971 - Medical Device Risk Management 8
I How to determine "generic/me too" device? Japan Medical Device Regulations 0
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
V Generic ISO 50001 checklist Various Other Specifications, Standards, and related Requirements 7
N Generic Rework/Reprocessing Procedure Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
M Is IEC 60601 compliance possible when only generic power-supply is specified? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S Family / Generic type of FMEA & Control Plan and Symbols FMEA and Control Plans 3
Marc The Risks of Generic Drugs Coffee Break and Water Cooler Discussions 24
R Connection to a generic separate power supply IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
Marc Are you looking for ISO 31000 - Risk Management Principles and Generic Guidelines? ISO 14971 - Medical Device Risk Management 1
C Appropriate ways to address Competency? Generic vs Specific ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Marc Urine Spills Staining Image of Wockhardt?s Generic Drugs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Ajit Basrur FDA - Guidance for Industry - Generic Drug User Fee Amendments of 2012 - Q & A US Food and Drug Administration (FDA) 0
M Engineering Change Management Generic Procedure Manufacturing and Related Processes 3
D FDA MDDS - Listing Obligations for a Generic Data Interface US Food and Drug Administration (FDA) 3
R Do generic forms bought over the counter need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Should the FSMS have a Documented Generic Procedure for Verification and Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
T Generic Guides for Procedure Writing Document Control Systems, Procedures, Forms and Templates 20
S Draft Guidance on Generic Drug User Fee Amendments (GDUFA) 2012 Other US Medical Device Regulations 0
C Control Plan Template (Generic) Document Control Systems, Procedures, Forms and Templates 0
AnaMariaVR2 Generic Drug User Fee Act (GDUFA) US Food and Drug Administration (FDA) 0
I Question on Declaration of Conformity for device subcategory or generic device groups EU Medical Device Regulations 2
P Generic Contract Manufacturing of Generic Prescription Medications Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
A Generic or Specific Gauge R&R on Standard Equipment (ie.: Micrometer) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Hershal Couple of generic TickIT and ISO 27000 questions IEC 27001 - Information Security Management Systems (ISMS) 9
Q Numbering or Naming (Identification) of Generic Company Specifications? Document Control Systems, Procedures, Forms and Templates 3
S Complaint Process flow: Need a generic definition which would flag an "MDR" Customer Complaints 7
optomist1 Generic question regarding Two Way ANOVA Results Statistical Analysis Tools, Techniques and SPC 8
D Seeking Help: Nondisclosure vs. generic QMS documents Misc. Quality Assurance and Business Systems Related Topics 10
M Generic "Compliant Procedure" and "Non-conformance" forms needed Document Control Systems, Procedures, Forms and Templates 1
K Generic Product Development Documents that need Analysis in a Complaint Investigation Problem Solving, Root Cause Fault and Failure Analysis 2
D Process Documentation is extremely generic IATF 16949 - Automotive Quality Systems Standard 4
O Process Audit Checklist - Generic vs. Process Specific Process Audits and Layered Process Audits 17
K Generic worksheet for calculating Supplier Chargeback and Cost of Poor Quality (COPQ) Supplier Quality Assurance and other Supplier Issues 2
Ajit Basrur Facts and Myths about Generic Drugs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
P Device Subcategory and Generic Device Group differences EU Medical Device Regulations 2
R Audit N/C - Quality Policy too generic? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
N Clinical trials - Generic "parent" procedure vs. study-specific "child" versions Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
G Any rule to set Generic Process Target % (per cent) Manufacturing and Related Processes 2
P Generic Label Die Cutting Process flow Manufacturing and Related Processes 5
C Production Audit Checklist - Generic General Auditing Discussions 14
K Generic Term for Inspection Types FMEA and Control Plans 15
B Generic list of ISO9001 processes for an organisation (manufacturing set up) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
H FDA Site generic Supplier Related forms help needed ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Does anyone have a generic Product Specification template? Document Control Systems, Procedures, Forms and Templates 7
G Is there a standard or generic set of PPAP documentation available? APQP and PPAP 4
