Geometric Tolerance Bonus Datum question
Michael_M
I am now questioning my own sanity and thought I would verify that what I know is true.
We have two holes in-line. One hole (datum -C-) has a tolerance of .3750 +.0008/.0000. The other hole is .5000 +.0010/-.000. The true position between these two holes is ?.000m Cm.
What this means to me is the true position is only the bonus size based on the size of the holes.
For example, the .500 is running .5008 and the .375 is .3755. This means the true position is .0013. Is this correct?
I have added a quick view of the details as an image. Ignore the numbers attached to the print, those are referencing the CMM program, not a bubble print.
Sean Kelley
What you are referring to is the hole size not the position of it which is in reference to Datum C whatever that is and at maximum material conditions. Cannot tell Datum C as it is not shown on your small piece of the print.
Sean Kelley
Yes now I see it is Datum C is the bottom hole on the print. In that case the true position is one hole to the other and you are correct on combining the 2 in for the true position of 0.0013.
J Reporting GDT (Geometric Dimensioning and Tolerancing) Bonus Tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
G Geometric Tolerance - Swedish Drawing which states that all tolerances are to NS 1430 Manufacturing and Related Processes 2
P Help Interpreting "Variable Tolerance Limit" - MMC Modifiers - Geometric Tolerance Statistical Analysis Tools, Techniques and SPC 18
optomist1 Profile of a Surface - Applying Profile of a Surface Geometric Control Symbols Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Recording True Positioning (Geometric Tolerances) on an FAI Report Records and Data - Quality, Legal and Other Evidence 15
D Statistical Tolerances in GD&T (Geometric Dimensioning & Tolerancing)? Various Other Specifications, Standards, and related Requirements 31
M GD&T (Geometric Dimensioning & Tolerancing) vs. "Standard" Blueprints Manufacturing and Related Processes 11
B Can Minitab 15 Chart Geometric Distributions with Very Low Defect Rates? Using Minitab Software 2
J Where to find new GD&T (geometric dimensioning and tolerancing) standards? Various Other Specifications, Standards, and related Requirements 2
N Geometric Product Specification (GPS) Other ISO and International Standards and European Regulations 3
S Folded Normal Distribution - Geometric features from our machine shop Statistical Analysis Tools, Techniques and SPC 15
H Geometric Tolerances - International and/or European Geometric Tolerancing Book, Video, Blog and Web Site Reviews and Recommendations 2
R Suggest a source? Cheap Online GD&T (Geometric Dimensioning and Tolerancing) Training Training - Internal, External, Online and Distance Learning 1
J I need a copy of ASME Y14.5m - 1994 - Geometric Dimensioning and Tolerancing Various Other Specifications, Standards, and related Requirements 3
L Geometric Tolerancing and SPC - Calculating position upper and lower control limits Statistical Analysis Tools, Techniques and SPC 36
D Tolerance symbol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Proud Liberal Small radius with tight tolerance on a torus General Measurement Device and Calibration Topics 4
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T How to justify this High %Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
S Tolerance limits for micro balance General Measurement Device and Calibration Topics 1
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
D Tolerance when verifying an analytical balance General Measurement Device and Calibration Topics 3
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M GD&T tolerance or band? Using a symbol like parallelism // Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Gage R&R without tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
