Getting A Supplier to use SPC (Statistical Process Control)
H
Hillsrem
We have a Chinese supplier that does not use statistical tools in their manufacturing process. If the number of defects in a production run is more than they expect, they will investigate and make some adjustments, all after the fact.
For better or worse, we are sole sourced with this supplier. We are basically stuck with them, (actually, dependant on them), so our influence on how they operate is limited.
I want to encourage them to start using DOE, control charts, and other tools to find and control important variables. To get them started, my thinking is to select a few parts that we have had quality issues with, work with one of our engineers to identify the important characteristics of those parts and get the supplier to use Pre-Control on those characteristics.
I like the idea of using pre-control because it can be implemented fairly quickly and easily as a first step into process control. Then, depending on how successful pre-control goes, work other tools into the process.
It feels a bit like the blind leading the blind, as I have not been the quality manager here for very long and am in the process of learning the quality tools that many take for granted, so I am interested in others thoughts about this approach.
Thanks,
bobdoering
Stop X-bar/R Madness!!
What kind of parts? What kind of processes? What kind of rejections? Handy info for us to help you....
H
Hillsrem
There are several different types of parts involved. All related to household type electrical switches, cords, plug strips.
There are small injection molded parts for housings, buttons, switches, levers, and covers. Most are made of nylon. Defects primarily include out of spec dimensions, and brittle parts. (I am pleased to add that we are making progress in the injection molding area. We got them to bring in the resin supplier’s technical rep to review their injection molding operation and some very good recommendations came out of that exercise. For example, the importance of shot size relative to machine injection capacity, resin drying time, using desiccating dryers.)
There are small stamped metal parts, primarily terminals of various shapes. We have not had many defects on these parts.
There are also some metal parts that are welded together. Defects include parts being welded out of position, poor welds, and weld spatter.
There are plastic parts that are ultrasonically welded together. Defects include poor welds and excess flash.
RandT
Do they seem responsive to your issues or not? When a problem is identified, how good are they at corrective actions? What happens to all the suspect material at your facility in the meantime?
If their corrective actions include containment and sorting activities, you could suggest that the use of SPC could prevent that from happening and help avoid all that extra work. To be effective, the SPC needs to be seen as something that helps them rather than something they do just because you demand it. Otherwise, they will just go through the motions.
Joe Ren
I agree with Rand.:agree:
Moreover, for continiously poor quality, first of all, we should review supplier's quality control system whether or not quality system is meet with requirement and suitable, and their OQC's capability is enough for quality control, what about their IPQC, how about their engineering technical ability and quality engineering ablility. If all of these are accept, we can consider to prevent high failure rate in production process and help supplier to set up SPC control process.
I am in China I know Chinese company quality culture. It is very necessary that you talk with their quality management person, and ask them to strictly implement SPC process, and let them know right implement is crically important for their quality control and improve process quality. Otherwise, you read SPC data that they provide always is fine and under control, but your parts quality is still poor. Anyway, Don't worry about, most of Chinese companies are good at company culture.
alekgrabinski
I think Hillsrem needs to break down the problem into smaller, more manageable steps. Going from next-to-nothing to SPC is a big jump. I would start with assessing the quality culture within the supplier. Do they have a quality person in the company? Do they have an executive champion? What types of quality tools do they already use? (5S, Kaizen, internal audits, data review, CLCA, etc.) How do they know what constitutes a defect level "more than they expect"? If they don't have a culture that actively pulls for quality, it's going to be a wasted effort.
I wish I could share Joe Ren's optimism, but my experience with domestic Chinese manufacturers isn't nearly as good. With some suppliers, I've been able to track defect levels as a function of when we (the customer) were in the factory -- we're there on the line, good results; we go home, quality does too. The conversation for quality can frequently be overwhelmed by the conversation for output, and this is particularly true with suppliers unaccustomed to Western quality standards.
Hillsrem, here's my opinion: Forget the SPC, and go upstream, like you're planning. Run DOE's. Develop control plans. Do process maps and FMEA's and FTA's. Bring in the resin supplier and the machine center manufacturer and the metrology maker for training and data sharing. Create an environment where it's exciting and interesting for your supplier to discover how their process works. Once you've done that, you'll have internal quality champions who will carry the Q flag. And you'll have a process that, were it to be characterized using SPC, would be demonstrated to be in control, all the time.
B Getting the proper information from the supplier - Returning Nonconforming Material Nonconformance and Corrective Action 4
C Supplier Qualification Issues - Getting Samples from Suppliers Supplier Quality Assurance and other Supplier Issues 5
D Sub Supplier Requirements - Getting my suppliers registered to ISO9001:2000 Supplier Quality Assurance and other Supplier Issues 6
M Request to Supplier for Corrective Action - Trouble with getting a response Supplier Quality Assurance and other Supplier Issues 10
R Getting harder to track the status of each one of the contracts Contract Review Process 0
Q Is it worth already getting UKCA? UK Medical Device Regulations 2
N Validating Software before getting approved as Class 2 device US Food and Drug Administration (FDA) 5
M Getting started in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 31
C Difficulties getting RoHS/REACH for cheap parts RoHS, REACH, ELV, IMDS and Restricted Substances 1
NDesouza Getting Rid of Part Marking Errors Benchmarking 40
J Getting training either from ASQ or from SAI Global - ISO 9001 Lead Auditor training Training - Internal, External, Online and Distance Learning 1
blackholequasar Internal Auditing Inspiration - Getting volunteers to perform internal audits. Internal Auditing 22
L Getting Notice of Revision and Accessing Public Draft Copies of ISO Standards Service Industry Specific Topics 2
M (How To) Getting Data From Vision Machine To Reporting Software Misc. Quality Assurance and Business Systems Related Topics 0
Miner Getting logged off repeatedly Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 13
L Please help me with the process of getting ISO 9001 certified Quality Management System (QMS) Manuals 15
Z I need help with getting a CFS in China Manufacturing and Related Processes 2
M Getting into biotech QA from aerospace - Is it practical? Career and Occupation Discussions 2
S Business development and support - Getting business general liability insurance Career and Occupation Discussions 5
S ISO 17025 - Help in Getting accreditation- Where to start from ISO 17025 related Discussions 12
N Getting Married - How Will It Affect My Taxes? Coffee Break and Water Cooler Discussions 14
P Getting ready for Boeing's AC7130 requirement for suppliers using a CMM AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Ninja Getting eaten by Big Business - My company was bought by a huge multinational Coffee Break and Water Cooler Discussions 54
J Is getting a UDI Consultant a good idea? Other Medical Device Regulations World-Wide 4
F Getting the audit procedure in my head (learning it) Quality Manager and Management Related Issues 3
Ajit Basrur Congratulations Steve Prevette on getting a Silver Star Covegratulations 11
Ronen E Congratulations Somashekar for getting the Silver Star Covegratulations 9
L PPAP Approval Woes - Getting signed PSW's back from Customers Supplier Quality Assurance and other Supplier Issues 15
Marc 50 Is the New 65: Older Americans Are Getting Booted from Their Jobs Career and Occupation Discussions 30
Rameshwar25 Getting values of k1, k2 and k3 for n=30, r=3 and k=3 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Implementing ISO 9001 - Getting whole team buy-in? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
AnaMariaVR2 Getting Importers? Pulse About Food Safety Plans Food Safety - ISO 22000, HACCP (21 CFR 120) 3
M Getting your foot in the door? Entry level QA Career and Occupation Discussions 4
K Tips 'n Tricks for getting a Job in the early 21st Century Career and Occupation Discussions 1
Z Getting Charged for AS9104/1 Additional Audit Time General Auditing Discussions 6
Z Getting around GLP (Good Laboratory Practices) with FDA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Getting Actionable Data from Returns Manufacturing and Related Processes 1
M Learning ISO 13485 - Getting a better understanding of the requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
J ISO13485 File-Index getting too large Document Control Systems, Procedures, Forms and Templates 2
M Putting Quality Management Together - Getting People to see Quality as a System Quality Manager and Management Related Issues 12
Randy Getting Red X 's in a box instead of pictures - I need some information.... After Work and Weekend Discussion Topics 10
A Getting Stuck Choosing a Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Options for getting TV/Cable stations programming over the Internet After Work and Weekend Discussion Topics 6
G Getting Notifications of New Issues of Standards like AS9102 Quality Manager and Management Related Issues 3
S Getting Zero for GR&R Reproducibility? Using Minitab Software 5
M Trigonometric Calculation (V-Anvil Micrometer). I'm not getting it. General Measurement Device and Calibration Topics 6
D Getting into Quality Consulting Career and Occupation Discussions 7
D Promoting Company Wide Quality Drive - Getting Employee Buy In Quality Manager and Management Related Issues 15
G Internal Audit Planning - We are not getting the best out of our Internal Audits ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
