Getting Stuck Choosing a Sampling Plan
Amonhotep
In a hospital pharmacy in the Netherlands we produce certain drugs in small lots consisting of about 20 units (bottles). For the analysis of the content of the active substance we are exploring possibilities to use statistical methods for the sampling and analysis. The problem is that the analysis is costly and when the sample size is too large we do not have any units left for the patients.
What I read in text books is that we can implement a single sampling plan by attributes, but the problem with it is that those attributes plans only say something about rejecting or accepting the lot and nothing about the quality of the produced drugs. The main reason for the analytical test of the lots is to get insights whether or not the drugs we produce have a good quality (the content has to lay between the limits of 90-110% of the theoretical content) and that we want to monitor this. I also read about sampling by variances, but the problem with this is that the data requires a normal distribution. Data from past records showed no normal distribution, so sampling by variances is not allowed I think.
Do you know any other sampling strategies to use for my particular situation where we can do some statistical quality control with small samples from small lots?
Thank you in advance,
Harmen
btw, I'm not sure this is the right sub-forum, because my question is about both sampling and SPC.
Steve Prevette
Deming Disciple
Yes, does sound like SPC would help, with some amount of sampling.
A few questions:
The sampling is destructive. The entire bottle is lost?
Are the 20 bottles filled from one (batch) supply that is made up, or is the making up of liquid (is it liquid or pills?) for the 20 bottles completely independent from bottle to bottle? If the 20 bottles come from one batch, seems like just a sample of the batch would be sufficient, I would think.
A good plan would be once you decide what proportion (if it is less than 100%) of the batches are to be sampled, set up a random number generator (even a dice roll would work) to see if the batch is to be sampled. Then plot the results in the order produced on control charts. If we are dealing with pills, a way to randomly pick a pill or two from the batch could be developed.
Amonhotep
Thanks for your quick reply, I've also been thinkin of what you suggest, but I encounter a few problems:
We make different types of drugs in this small quantities. Most of the drugs are liquids, but also some capsules and suppositories are among them.
To produce the drugs, we make one batch for example of 2L of a liquid and we fill this out in 20 bottles of 100 mL, or for capsules we make 10 grams of powder and fill it in 20 500mg capsules.
This does not mean all the individual dosage forms contain the same content of active substance because for suppositories and suspensions for example the active substance (which does not dissolve) can sink to the bottom during the filling process. This way the bottles which are filled at the end can contain more active substance than the first bottles.
The sampling is destructive, the sample is partially or completely used for the analysis and opened containers where a certain amount of drug is taken from is not allowed to reach the patient.
Steve Prevette
Deming Disciple
Okay. Personally, I would split this into two problems:
- Inconsistencies within the products from the batch due to imperfect blending
- What is the strength of the batch
If you solve the first problem, that helps simplify the sampling.
But, if you aren't going to deal with the blending as a separate issue, I'd go with one bottle out of every 21 liquid bottles (random) and one pill out of every bottle at least as a start. If the SPC shows things are well in control at better than the tolerances, then you could relax the sampling. If there are a lot of problems, I'd try to identify if you are dealing with the overall batch is okay but not homogeneous, versus the overall batch is bad. That would require multiple samples within each batch for a while to see which is the issue. But you would need to switch to some form of troubleshooting / causal analysis routine to fix the problem
If you need a technical basis, there is always Z1.4 / MILSTD 105 sampling plans. True, these are for go-no go, but they would be conservative for measurement sampling.
I agree that a continuous data SPC chart (I, MR with BOTH control limits and spec limits) would be helpful. the control limits will tell you if anything changes and the spec limits help tell you how capable you are and if there is a change that might signal bad product. (I have used this approach fairly successfully for the type of situation you describe)
I might also suggest using a first piece and last piece sample plan (Not random) for those processes that have non homogenous filling...
Amonhotep
Thank you both very much for your advice, I think I will apply a continuous data SPC chart with individual X. I will use random sampling for the processes where it is reasonable to assume the product in all containers is homogeneous. For the processes where I can not assume the process is homogeneous I think I will apply a first and last piece sampling plan.
For the most products these methods will work out. The only products the methods are not applicable to are the ones we produce only a few times a year. I think for those products we can not gather enough data points to make a control chart. Do you have suggestions to solve that problem or is the best way to monitor those products on a non-statistical basis.
Steve Prevette
Deming Disciple
My experience has been it is reasonable to have a control chart with 7 to 12 points on it. Also, keep a running control chart over the years for each product. Even if infrequently made, you can accumulate enough data in the long run to see if things are changing with stops and restarts.
There are proponents of something called "short run SPC" where you estimate the "control limits" from the specifications, but I am not in favor of that method.
Another thing that can be done "across products" is to plot the deltas between the specification and the value measured, even if different products. See "hoteling" in Wikipedia. But this method can be very complex and may end up tripping alarms related to problems with the specifications.
M Are we getting scammed by our Notified Body? They are asking to review all changes to determine if they are Significant CE Marking (Conformité Européene) / CB Scheme 4
PQ Systems Getting the Most out of Master Gages Using GAGEpack Software 5
O How can fraud be avoided while getting an ISO certificate? ISO 17025 related Discussions 3
PQ Systems Getting Started with GAGEpack Using GAGEpack Software 0
R Getting harder to track the status of each one of the contracts Contract Review Process 0
Q Is it worth already getting UKCA? UK Medical Device Regulations 2
N Validating Software before getting approved as Class 2 device US Food and Drug Administration (FDA) 5
M Getting started in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 31
C Difficulties getting RoHS/REACH for cheap parts RoHS, REACH, ELV, IMDS and Restricted Substances 1
NDesouza Getting Rid of Part Marking Errors Benchmarking 40
J Getting training either from ASQ or from SAI Global - ISO 9001 Lead Auditor training Training - Internal, External, Online and Distance Learning 1
blackholequasar Internal Auditing Inspiration - Getting volunteers to perform internal audits. Internal Auditing 22
L Getting Notice of Revision and Accessing Public Draft Copies of ISO Standards Service Industry Specific Topics 2
M (How To) Getting Data From Vision Machine To Reporting Software Misc. Quality Assurance and Business Systems Related Topics 0
Miner Getting logged off repeatedly Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 13
L Please help me with the process of getting ISO 9001 certified Quality Management System (QMS) Manuals 15
Z I need help with getting a CFS in China Manufacturing and Related Processes 2
M Getting into biotech QA from aerospace - Is it practical? Career and Occupation Discussions 2
S Business development and support - Getting business general liability insurance Career and Occupation Discussions 5
S ISO 17025 - Help in Getting accreditation- Where to start from ISO 17025 related Discussions 12
N Getting Married - How Will It Affect My Taxes? Coffee Break and Water Cooler Discussions 14
P Getting ready for Boeing's AC7130 requirement for suppliers using a CMM AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Ninja Getting eaten by Big Business - My company was bought by a huge multinational Coffee Break and Water Cooler Discussions 54
J Is getting a UDI Consultant a good idea? Other Medical Device Regulations World-Wide 4
F Getting the audit procedure in my head (learning it) Quality Manager and Management Related Issues 3
Ajit Basrur Congratulations Steve Prevette on getting a Silver Star Covegratulations 11
Ronen E Congratulations Somashekar for getting the Silver Star Covegratulations 9
L PPAP Approval Woes - Getting signed PSW's back from Customers Supplier Quality Assurance and other Supplier Issues 15
Marc 50 Is the New 65: Older Americans Are Getting Booted from Their Jobs Career and Occupation Discussions 30
Rameshwar25 Getting values of k1, k2 and k3 for n=30, r=3 and k=3 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Implementing ISO 9001 - Getting whole team buy-in? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
AnaMariaVR2 Getting Importers? Pulse About Food Safety Plans Food Safety - ISO 22000, HACCP (21 CFR 120) 3
M Getting your foot in the door? Entry level QA Career and Occupation Discussions 4
K Tips 'n Tricks for getting a Job in the early 21st Century Career and Occupation Discussions 1
Z Getting Charged for AS9104/1 Additional Audit Time General Auditing Discussions 6
Z Getting around GLP (Good Laboratory Practices) with FDA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Getting Actionable Data from Returns Manufacturing and Related Processes 1
M Learning ISO 13485 - Getting a better understanding of the requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
J ISO13485 File-Index getting too large Document Control Systems, Procedures, Forms and Templates 2
M Putting Quality Management Together - Getting People to see Quality as a System Quality Manager and Management Related Issues 12
Randy Getting Red X 's in a box instead of pictures - I need some information.... After Work and Weekend Discussion Topics 10
P Options for getting TV/Cable stations programming over the Internet After Work and Weekend Discussion Topics 6
G Getting Notifications of New Issues of Standards like AS9102 Quality Manager and Management Related Issues 3
S Getting Zero for GR&R Reproducibility? Using Minitab Software 5
M Trigonometric Calculation (V-Anvil Micrometer). I'm not getting it. General Measurement Device and Calibration Topics 6
D Getting into Quality Consulting Career and Occupation Discussions 7
D Promoting Company Wide Quality Drive - Getting Employee Buy In Quality Manager and Management Related Issues 15
G Internal Audit Planning - We are not getting the best out of our Internal Audits ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Getting to the ASQ Exams at MD&M Chicago, 19 Sep 11 Professional Certifications and Degrees 5
