The standards are available on www.gmsupplypower.com if you are a GM supplier. If you are a TIER 2 to GM, the TIER 1 (=your customer) should be able to get you copies. The standards are copyrighted documents. You might older versions of the standards using Google search with word like, general procedure GM continuous improvement)
A quick search found this document, (not GM, but AAM, which is a company which was part of GM several years ago).
This refers to the engineering and material specs not the quality procedures
Some of the GM procedures are available at http://www.gmsupplypower.com/ even if you are not registered
Go to the Quality library
Any idea where we could get the latest version? I am unable to acquire this document from the GM site. Yes, I am a non-supplier. I am sure there are many like me (trainers, consultants, auditors, etc.) who would like to have access to this and other (hard-to-get) customer (very-specific) documents.
