Go - No Go (Attribute) Gage R&R (Repeatibility and Reproducibility)
Richard
Our customer ask us to do the gage R&R for a checking fixture (Go/Nogo gage). This gage was calibrated already by customer. It is used for our product length of dimension 1330+/-5mm in our in process 100% final inspection.
Obviously we have to use different formular for the variable measurements. I have no idea about go/nogo. How to do it? Which formulars should we use? Please advise.
regards
Rick Goodson
Richard,
There is a section in the Automotive Industry Action Group (AIAG) Measurement System Analysis (MSA) manual that describes the shiort and the long method for performing attribute gage studies. In essence the short study involves 2 appraisers, 20 parts, and replication. If you don't have access to a MSA manual you can purchase one through the Automotive Industry Action Group (AIAG)
Hope this helps.
Rick
Richard
I have the MSA manual 3rd edition and start from page 125 attribute measurement system study. But I got lost as try to understand where those data derive from, such as reference, ref. value in table 12. Also confused by those cross-tab, Kappa. What is acceptance criteria for attrinute gage R&R?
Could you explain more detail?
Thanks.
Cristi?nC
Attribute R&R
Richard:
If you are dealing with a measurement (lenght), why consider it as an "attribute"??
MSAs for Variables are more helpful for understanding how good or bad is our measurement process. It may help you to have an idea for the next steps in productive process improvements...
Attributes can only help us to simply detect no-go parts...
But...
Assuming that usage of go no-go gage and 100% inspection is demanded by your customer, I hope this simple concepts help you to perform an attribute study:
- Choose at least 25 or 30 "perfect" and "defective" parts and ask each of the operators to inspect them randomly, at least three times each part. Remember: randomly, and in a way that resemble their routine work.
- Write down their decisions in a check sheet and after that, obtain the following:
- Repe: Hability of the appraiser to "repeat" his/her decisions (agree with him/herself). Calculated as (# agreements / # parts inspected) and commonly referred in percentage. 90% is usually considered as "acceptable", but this is a "rule of thumb".
-Repro: Hability of all the appraisers as a whole to "repeat" their decisions among them. Calculated as (# agreements among all appraisers / # parts inspected). (90% again is acceptable)
Since you already know the exact condition of each part, then you can determine:
- Concordance: (# parts that agree with the standard / # parts inspected). 90% again.
- False Alarms: (# parts classified as "defective" when in fact is perfect / # of perfect parts). 5% is acceptable (AIAG)
- Wrong Classficaction (# parts classified as "perfect" when in fact is defective / # of defective parts). 2% is acceptable (AIAG).
- Mixed: (# of parts that were classified inconsistently along the inspections / # parts inspected)
You can use Excel.
Forget about Kappa, is useful for ordinal categories (extremely bad, bad, good, extremely good).
Hope this helps!
Bob_M
CristiánC,
I am not sure where you got those basic formulas, but they sound very reasonable and easy to perform for a basic go-no go gage R&R type of test.
Thanks for the post.
Bob_M
Richard
I spent whole day on it and realized chi square
knowledge which is key to the crosstabulation table.
Also I found some mistakes which have
been corrected on AIAG website for miss rate numbers on
page 132. Anyhow I got it .
Your comments give me the essence of that chapter.
Thanks for your help.
Cristi?nC
Source Repe & Repro calculations...
Bob_M:
Minitab 13.3.
Based on AIAG book, they simplified the math...
They don't use the repe and repro words, but, as you also conclude, the formulas refer clearly to this sources of variation...
Regards
Al Dyer
Richard, may I ask the reason for 100% inspection on a gage supplied to you by the customer?
Has it failed capability studies, repeatability, reliability, bias, stability, etc?
Of course even a gage supplied by by customers has to go through some type of verification to ensure proper use during the manufacturing process.
With a fixture, take 100 actual production parts and run them through the attribute gage and use a P-Chart with a 4-5 part sample size. After that you know if the gage is stable? or do you?
Instead of a part use some standard, a calibrated piece of stock say (master) or some other calibrated and defined standard.
Just realize that all studies on calibration and verification will ultimately be your concern in the eyes of a customer, I.E. cover your:ca:
Al...
Richard
This fixture is for pipe length 100% inspection. The length is not a Critical dimension according to drawing and also we are not asked to do any process control chart. We are doing the R&R study just for the PPAP submission. R&R study is not suggested for attribute data but it is asked by out customer.
Could you explain a little more about the reason of using P-chart? Do you mean we need do the P-chart control in our process control after we pass the R&R? What the customer concern will be? Please advise. Thanks.
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Attribute Gage R&R study according to "Charbonneau" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Gage Blocks: Attribute or Variable Gage? General Measurement Device and Calibration Topics 3
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
D attribute gage RR in a unique way Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
V Minitab - Attribute Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Example of how to perform a Visual Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K MINITAB 16 - Attribute gage study (Analytic method) and Gage R&R Study (Expanded) Using Minitab Software 2
J Minimum number of parts to do an attribute gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Survey about Attribute Gage and Sight Checking R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
kedarg6500 Gage R&R for Attribute Data - Pump Noise Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA Gage R&R and Attribute Forms Attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Correct Sample Size for Attribute Gage R&R (Good / Bad parts) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
D "GM Method" Gage R&R for Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Destructive Attribute Gage R&R without LSL/USL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Practicality of Metal Stamping Attribute GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Attribute Gage MSA - What is the width of the gray area of ​​doubt? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J GR&R (Gage R&R) Sample Setup for Attribute Inspection Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Hami812 Attribute Data Gage R&R - Managing Data Sets - Minitab Using Minitab Software 2
J Gage R&R Study by Attribute (ACCEPT-REJECT-INVESTIGATE) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Attribute GR&R (Gage R&R) using a CMM (Coordinate Measuring Machine)? General Measurement Device and Calibration Topics 3
L Tools in Gage R&R - Acceptability of an Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
B Visual Inspection (Attribute Data) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
J Attribute GRR (Gage R&R) - How to get Kappa Software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Attribute Gage Studies - What gages are required to have Measurement Systems Analysis IATF 16949 - Automotive Quality Systems Standard 4
M Procedure for Attribute R&R Gage Study?? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Destructive Attribute Gage Studies - inserted/pressed in parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
H Known non-conforming samples in attribute GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Attribute GR&R (Gage R&R) Studies for Metal Stampers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Attribute Gage R&R on Torque Wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Percent defective in Attribute GR&R (Gage R&R) General Measurement Device and Calibration Topics 3
S Attribute Gage R&R - Automated Test Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Attribute Gage R&R analysis - Automated test system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C How to Determine Attribute Gage Uncertainty Measurement Uncertainty (MU) 1
R Attribute GR&R (Gage R&R) for Continuous Processes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Gage R&R on Attribute Data Using Minitab 14 - Data from Automated Test Systems Quality Tools, Improvement and Analysis 2
H Attribute Data Gage R&R - Queries of data from a system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
K Gage R&R on a special go/no-go attribute gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Attribute Gage Study using MiniTab Using Minitab Software 2
T Wind Turbine Blade Attribute Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Customer is requesting Variable Data for Attribute Gages in Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
J Audit Finding for this section - Min and Max for measurements - Attribute Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
M Excel .xls Template for Attribute Gage R&R with ORDINAL Data needed Excel .xls Spreadsheet Templates and Tools 10
T Gage R&R Yearly Frequency Acceptance - Attribute gages - ISO/TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
