Go - No Go (Attribute) Gage R&R (Repeatibility and Reproducibility)
Scott Robinson
#11
To go or not to go
Hi Richard,
Have just gone through the same thing as you trying to figure out gauge r&r for attribute data. Read the MSA manual and wished I hadn't. Attached is a simple to use form I made up to satisfy our customers. I couldn't view Tim's (I don't like giving credit card details over the net to pay the 25 bucks).
Hope it is of some use.
:smokin:
Richard
#13
Hi Scott,
I made a form by myself using the hypothesis test analyses- cross-tab method which is the first method on Chapter III MSA manual. And got the same result as the some professional software did. I can¡¯t download the attaches for the same reason as yours (I feel Internet just like a knife. Use to help people or kill).
Thanks.
V
vargadomonkos
#14
MSA manual
I'm pretty interested in G R&R studies, because noone seems to know it in my company. And I won this problem to be solved. Could anyone send the AIAG MSA manual for me, cause I haven't got it.
V
vargadomonkos
#17
Calculations for Attribute GRR
could any of you give me a hand in calculation of UCL and LCL in case of attribute agreement analysis. For example how can one calculate or at least approximate the inverse of Beta-distribution or so. I am not interested in excel or statistical software solutions, only in the mathematical method.
THX
Tybee - 2011
#18
Gaugr R&R
Can someone tell me what is considered a god R&R study? I ave a study with a % R&R of 20.6
#19
It depends on what the GRR is a % of. If GRR is 20% of the tolerance range, the gauge is marginally acceptable for product acceptance. If GRR is 20% of the process variation, the gauge is marginally acceptable for process control (e.g., SPC). If GRR is 20% contribution, the gauge is probably not acceptable.
The standard guidelines for acceptability of a gauge are:
  • </= 10% is ideal for GRR as a percent of tolerance if used for product acceptance and/or percent PV if used for process control, capability studies, DOEs etc.
  • Between 10% and 30% is marginal depending on importance of part characteristic, cost of gauging, etc.
  • > 30% is not acceptable
Guidelines for GRR as % contribution are:
  • </= 1% is ideal
  • Between 1% and 10% is marginal
  • > 10% is not acceptable
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Attribute Gage R&R study according to "Charbonneau" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Gage Blocks: Attribute or Variable Gage? General Measurement Device and Calibration Topics 3
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
D attribute gage RR in a unique way Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
V Minitab - Attribute Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Example of how to perform a Visual Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K MINITAB 16 - Attribute gage study (Analytic method) and Gage R&R Study (Expanded) Using Minitab Software 2
J Minimum number of parts to do an attribute gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Survey about Attribute Gage and Sight Checking R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
kedarg6500 Gage R&R for Attribute Data - Pump Noise Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA Gage R&R and Attribute Forms Attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Correct Sample Size for Attribute Gage R&R (Good / Bad parts) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
D "GM Method" Gage R&R for Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Destructive Attribute Gage R&R without LSL/USL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Practicality of Metal Stamping Attribute GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Attribute Gage MSA - What is the width of the gray area of ​​doubt? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J GR&R (Gage R&R) Sample Setup for Attribute Inspection Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Hami812 Attribute Data Gage R&R - Managing Data Sets - Minitab Using Minitab Software 2
J Gage R&R Study by Attribute (ACCEPT-REJECT-INVESTIGATE) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Attribute GR&R (Gage R&R) using a CMM (Coordinate Measuring Machine)? General Measurement Device and Calibration Topics 3
L Tools in Gage R&R - Acceptability of an Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
B Visual Inspection (Attribute Data) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
J Attribute GRR (Gage R&R) - How to get Kappa Software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Attribute Gage Studies - What gages are required to have Measurement Systems Analysis IATF 16949 - Automotive Quality Systems Standard 4
M Procedure for Attribute R&R Gage Study?? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Destructive Attribute Gage Studies - inserted/pressed in parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
H Known non-conforming samples in attribute GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Attribute GR&R (Gage R&R) Studies for Metal Stampers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Attribute Gage R&R on Torque Wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Percent defective in Attribute GR&R (Gage R&R) General Measurement Device and Calibration Topics 3
S Attribute Gage R&R - Automated Test Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Attribute Gage R&R analysis - Automated test system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C How to Determine Attribute Gage Uncertainty Measurement Uncertainty (MU) 1
R Attribute GR&R (Gage R&R) for Continuous Processes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Gage R&R on Attribute Data Using Minitab 14 - Data from Automated Test Systems Quality Tools, Improvement and Analysis 2
H Attribute Data Gage R&R - Queries of data from a system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
K Gage R&R on a special go/no-go attribute gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Attribute Gage Study using MiniTab Using Minitab Software 2
T Wind Turbine Blade Attribute Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Customer is requesting Variable Data for Attribute Gages in Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
J Audit Finding for this section - Min and Max for measurements - Attribute Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
M Excel .xls Template for Attribute Gage R&R with ORDINAL Data needed Excel .xls Spreadsheet Templates and Tools 10
T Gage R&R Yearly Frequency Acceptance - Attribute gages - ISO/TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
