Good Auditors - What is the benefit I get from NC & OFI
berseak
I never seen the good auditor.
When I recive NC or OFI from CB. I think beside meets requirement. What is benifit I get form NC & OFI.
If you have experence pls show & Share.
Thank you.
samsung
Re: Good Auditors - What is benefit I get from NC & OFI
Thank you.
There's an excellent response from Jennifer which was though posted in response to an OHSAS related query but fits well for any kind of audit.
Here's the link.
You may also wish to go through a paper produced by John Broomfield. It's very good and you can find it here.
Thank you.
What part of the world are you in? It seems that auditing is being done differently in different parts of the world, and perhaps someone who's in your country or region could help.
Markaich
I must admit I get slightly stressed with the 'I get no value from my CB auditor, only NCRs and OFIs'
Firstly, a CB auditor is not there to improve an organisation's management system, that's the organisation's job...take a look at Cl 8.5.1 of ISO 9001. In fact, a number of discussion I either follow or contribute to condem the auditor for acting as consultant, rightly so...that's not what we pay them for.
The value that a CB auditor can add is to point out weaknesses in the organisation's management system. By raising NCRs, the auditor is highlighting an instance where his interpretation does not match the organisation's...this is an opportunity to rethink the system and potentially improve it. If there is no NC then the organisation can present objective evidence to support its claim...if they can't present objective evidence, then it is very likely that a NC exists and needs to be dealth with.
Another way an auditor can add value is to bring his experience to bear and point out ways in which a task may be done differently and more effectively or efficiently...they can also point out areas where there is a risk that a NC will occur.
Using 'audit results' and 'corrective and preventive actions' is the responsibility of the organisation to improve their management systems, not the auditor's; the auditor can provide the input to the improvement process; this is the value they add...
oh, and the certificate at the end of course.
Just a point of view,
tomvehoski
<snip>
<snip>
Aren't your two statements in direct conflict? Pointing out ways to do something different/better IS consulting.
NCs and OFIs from a CB audit might give you some points to target for improvement, or they might cause you more grief and send you off in directions you should not go. It all depends on the quality/expertise of the auditor, and that is difficult to judge.
I am no longer a fan of the third party certification scheme. At best I think of CB auditors as weak consultants. Sure they might give me some good ideas (even though they are really not allowed to), but they also might waste my time with non-expert advice. They also come at a very high hourly rate.
Ninja
Looking for Reality
You make a valid point, but I don't think the two statements are in direct conflict. I pay to be told where I am not in compliance...not how to do my job better. It is not consulting on how to do better, it is a third party measurement of where I'm not good enough.
I truly dislike being audited. The company pays a person to come in and find weaknesses in systems that I built, then tell my colleagues (who are involved in CARs) and my management where the weak points are. I dislike audits because I want to believe that my systems have no weaknesses and the auditor makes me face the truth...there are weaknesses.
But the auditor adds the value of pointing out where my systems can be better (by pointing out where they are weak). They do this not by comparing my system to one they might come up with, but to a set and published (objective) standard. I truly dislike being audited, but my systems (and thus I) benefit from it.
When I get audited, the auditor often knows bupkiss (sp?) about my system or the goal of it in terms of customer technical application. He may give unsolicited advice on how to technically do it better but has no authority to force a technical change or to ding me for recognizing he doesn't know what he's talking about. He does have the right to point out where I do not follow the standard, and to force that change to follow the standard.
If I didn't care about certification, I wouldn't pay to be certified and I certainly wouldn't pay to have someone come in and tell me where I'm weak. Since I do care to certified, I get over my dislike of the audit and focus on the opportunities to improve. If a suggestion from an auditor makes no improvement in the system, I simply document why it is not implemented. If my system is truly in conflict with the standard, and I want to stay certified, I change the system to be in compliance (typically record keeping).
Auditors add value in a way that I do not prefer...that is not at all saying that they don't add value. If the auditor insists on changes that do not reflect coming into compliance with the standard, you can appeal, or make the case for a new auditor. Focusing on how the business can be improved through this ego-reducing process helps to keep it tolerable. Focusing on how I feel after the audit only leads to frustration and heartburn
Keep your eyes on the prize...not the person you pay to find your faults. Finding fault can have value if it is used judiciously. (Note that the prize is sustained profit...not a certificate hanging on the wall)
:2cents:
Antonio Vieira
Involved - Posts
In fact, this is a problem that we can find here!
The level of knoledge of QMS auditors is being reduced every year.
Why?
Simply because CB's are trying to cut costs and choosing cheaper auditors (with few experience).
That's why organizations are not earning any value added in having CB's audits every year!!!
I believe that, here and now, there are more companies cuting ISO 9001 registration than companies entering on this field.
qusys
Why?
On the other hand, I think that for some standards ( for example ISO TS, TL9000 and also others such Energy one), the request for certification could increase in the next years.
Clearly this is strictly linked with the improvement of the industrial sectior, expecially automobile and communications.:bigwave:
Why?
This may be a specific country/market related issue, so to make such sweeping generalizations is a little dangerous, given that readers come from all around the world. It doesn't represent the entire picture, as I'm sure you may be aware.
Stijloor
The level of knowledge of QMS auditors is being reduced every year.
Why?
I believe that, here and now, there are more companies cutting ISO 9001 registration than companies entering on this field.
António,
Are speaking about what's going on in your country Portugal?
Any sources you can cite?
Thanks!
Stijloor.
M Do AS9100 Registrar Auditors have nonconformity quotas? General Auditing Discussions 18
B Internal Auditor Competency - Product Auditors Internal Auditing 9
M Question for Auditors - "Off the Record" Conversation? General Auditing Discussions 14
I What direction do you provide your internal auditors on OFIs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
M Choosing Auditors - ISO 9001 / ISO 27001 (UK) IEC 27001 - Information Security Management Systems (ISMS) 2
E Choosing an ISO 9001 registrar with auditors familiar with our industry Registrars and Notified Bodies 10
ScottK Question for Auditors on 7.1.4 in the ISO9001:2015 revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S MDR (Medical Device Regulations 2017/745) training recommendation for Auditors EU Medical Device Regulations 1
S How can we demonstrate to MDSAP auditors that we have the requisite training ISO 13485:2016 - Medical Device Quality Management Systems 9
M CB and Internal auditors most common nonconformities against AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
C Selecting potential internal auditors Internal Auditing 3
K Tips for dealing with third party auditors General Auditing Discussions 11
J ISO 9001 Competency - Forklift License and Internal Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
O How will you handle Clause 6.1 - Risks and Opportunities for AS9100 Rev. D Auditors? Risk Management Principles and Generic Guidelines 22
T Can a Lead Auditor Train other Auditors? Internal Auditing 4
A Professional Headhunters for External Auditors Career and Occupation Discussions 7
Sidney Vianna Auditors and CB's further investigating certified QMS' with ethical breaches? Registrars and Notified Bodies 8
W DCMA and AS9100C - Dedicating a week and 5 auditors to perform a AS9100C audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Crimpshrine13 ISO/TS 16949 CBs & Auditors not following up on the schedules IATF 16949 - Automotive Quality Systems Standard 43
H Any ISO 9001 consultants/auditors in Oahu, Hawaii ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Subject Matter Expert Training for Auditors Internal Auditing 13
S Is it a Finding if all Internal Auditors are from the Quality Department? Internal Auditing 18
R Are ISO 9001 Lead Auditors in demand? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B ISO/TS16949 Internal Auditing - How many auditors? Internal Auditing 4
D Number of Internal Auditors Best Practice Quality Manager and Management Related Issues 18
A Training Supplier Auditors ISO 13485:2016 - Medical Device Quality Management Systems 5
T Would my AS 9110 certificate lapse due to non availability of auditors ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
T Kids in the office from an auditors standpoint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Qualification System of Internal Auditors is not Effective General Auditing Discussions 5
S Internal Auditors shall not audit their own work? Internal Auditing 21
R Female auditors earn 18% less than male auditors - IRCA Salary Survey 2014 Career and Occupation Discussions 0
J Wanting to Train our Internal Auditors Ourselves Internal Auditing 7
S Recertification Frequency for TS 16949 Lead Auditors General Auditing Discussions 4
Sidney Vianna As a profession we, auditors, are not doing enough - Simon Feary speech Registrars and Notified Bodies 36
Ninja Blind Gopher Auditors Comment - Who is responsible? Registrars and Notified Bodies 23
R Auditors Auditing Against ISO 9001:2015 Draft ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
R Auditors can NOT audit their own work audit finding Internal Auditing 17
Q Qualified Internal Auditors for AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
B API approved Auditors in India Oil and Gas Industry Standards and Regulations 3
M How to measure effectiveness and efficiency of the established QMS as Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
R Should internal auditors be compulsorily certified as internal auditors ? Internal Auditing 11
W Is formal training required for Internal Auditors? Internal Auditing 7
K Auditors are trying to drive this business General Auditing Discussions 36
K Auditor Objects to List of Internal Auditors General Auditing Discussions 6
Mikishots AS91X0 Third Party Auditor Cycling and Changing Auditors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D What Factors to consider to determine the Number of Auditors Internal Auditing 3
E Who Audits the Auditors in a Company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P Which training system or LMS (Learning Management System) to train Auditors? Training - Internal, External, Online and Distance Learning 8
A ISO 19011:2012 - Emphasis on Risk Analysis, Competence of Auditors and Vocabulary Internal Auditing 2
D AS 9104/1 has New Requirements for 3rd Party Auditors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
