GR&R Acceptance Criteria
Hello all,
We've been challenged on our acceptance criteria for GR&R and a group of internal SMEs designed the following criteria:
•% Tolerance - <10% (above 10 to 30 is marginal, above 30 is unacceptable)
•% contribution - <10% acceptable, above 10 unacceptable (or nDC ≥5)
We have to meet both in order to have a successful GR&R.
They say %Contribution is the statistical equivalent for nDC, and they've included that requirement in order to know if the equipment (a MicroVu) is able to distinguish process variation.
Even though our aim is to discern between good and bad parts they keep asking for the system to also capture process variation, I think that's our main problem.
I'm trying to find information on the relationship between %Contribution and nDC and if %Contribution is truly an acceptance criteria tied to a GR&R which aims to discern between good and bad parts (%Tol).
Ninja
Looking for Reality
No comment on your direct question...others here can handle that better than I...
I wonder, however, what your tolerance is? and what your normal process variation is?
I've used the MicroVu extensively...and to miss NDC>5 on a machine that can discern 50 millionths never came up in my work...
So I wonder if your samples used for GRR cover the spec range? Or is your spec range THAT tight that 50millionths is on the edge?
These ‘requirements’ aren’t horrible, but they are ‘blind’. Your SMEs should be able to answer your questions in simple terms, but since they have perpetuated the myth of the 10% of the tolerance I would say that they arent’ Experts at all - they are have simply memorized a limited section of a Guage R&R standard. If they were experts they would know that %tolearnce is a bogus mathematical calculation that is just fake math. Also the 10% limit is an arbitrary line - there is no reason for drawing the limit at 10% or 30%. The 10% of tolerance is a fairly conservative limit such that if you meet it your gauge system is probably pretty decent for acceptance testing. The difficulty is that it will unenessarily reject systems that are fine. My real issue with it is that it is mathematically incorrect and represents a lack of critical engineering thinking. People just accept it because that’s the way it is.
As for the 10% of product variation for SPC - that is total crap. IF the calculation is mathematically correct the %variation will be a real number but of they don’t use the correct formaula it will be just more fake numbers. It is essential to understand the actual contribution of measurement error to the product variation to properly monitor your processes through ‘SPC’. But there isn’t really a limit on that contribution - it will simply drive what rules and what sampling frequency you employ.
I suggest reading Miner’s blogs and my paper on MSA in the resources section of this forum. Then read the references cited by Donald Wheeler...then you can be a subject matter expert...
H Medical Device Label Acceptance Criteria Manufacturing and Related Processes 4
D What are the acceptance criteria/requirements for Stability Study? General Measurement Device and Calibration Topics 7
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
lanley liao Purchase Acceptance Criteria - Tensile testing Oil and Gas Industry Standards and Regulations 2
R Procedure, Frequency and Acceptance Criteria for Replicate, Recalibration, Before-After and Intermediate Checks ISO 17025 related Discussions 8
S Acceptance criteria for gauges General Measurement Device and Calibration Topics 8
M Characterization Testing - NO acceptance criteria, no minimum performance requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J AIAG PPAP: 2.2.11.3 Acceptance Criteria for Initial Study (page 9, 4th edition) APQP and PPAP 1
C FDA on changing acceptance criteria re: analytical method validation US Food and Drug Administration (FDA) 1
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
P Medical Device Validation Protocols and Reports - Acceptance Criteria Other Medical Device and Orthopedic Related Topics 3
C Software Unit Acceptance Criteria (5.5.4) IEC 62304 - Medical Device Software Life Cycle Processes 3
J Acceptance Criteria in 8.1.1 e) of IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
O Acceptance criteria bacterial endotoxins immunosera for human use Manufacturing and Related Processes 3
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
V Acceptance Criteria Gage R&R - Simple vs Complex Techniques Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A 5.5.3 - Software Unit Acceptance Criteria (Risk Control Measures) IEC 62304 - Medical Device Software Life Cycle Processes 3
M Establishment of Acceptance Criteria for a Weigh Balance General Measurement Device and Calibration Topics 3
X How to define Calibration Acceptance Criteria General Measurement Device and Calibration Topics 3
P Gage R (no reproducibility) - Acceptance Criteria Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
V Validation Test and Acceptance Criteria for Compressed Air Qualification and Validation (including 21 CFR Part 11) 3
I Dual Acceptance Criteria: Cpk and Individual Values Statistical Analysis Tools, Techniques and SPC 3
L Acceptance Criteria for External Calibrated Standards IATF 16949 - Automotive Quality Systems Standard 1
A Risk Acceptance Criteria in ISO 14971 ISO 14971 - Medical Device Risk Management 19
G Acceptance Criteria when Verifying a Gauge General Measurement Device and Calibration Topics 2
D Renault Painting Defect Acceptance Criteria Manufacturing and Related Processes 4
B Surface Roughness Tester Acceptance Criteria Calibration Frequency (Interval) 4
H Package Integrity Testing Acceptance Criteria ISO 13485:2016 - Medical Device Quality Management Systems 3
D 21 CFR 820.80 In-Process Acceptance Criteria requirements for IVDs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Acceptance Criteria for Scratches on Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 3
JoCam Nadcap AC7120 (Audit Criteria for Circuit Card Assemblies) - Acceptance Criteria AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Acceptance Criteria - ISO 9001:2008 Clause 8.2.4 - Questionable Audit Finding? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
Q How to meet Clause 7.1.2 Acceptance Criteria in ISO TS 16949 IATF 16949 - Automotive Quality Systems Standard 7
J IPC-A-610 E Thermal Plane Acceptance Criteria for D-Pak Component Other ISO and International Standards and European Regulations 2
S Acceptance Criteria at Design Verification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Labels - ASTM D3330/D3330M Acceptance Criteria for Adhesion 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
optomist1 Tensile Test Crimped Electrical Terminal Acceptance Criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
V The approach/criteria of setting Acceptance Limits Method Validation Parameters Statistical Analysis Tools, Techniques and SPC 1
6 Acceptance Criteria For pH Meters and other Laboratory Equipment Measurement Uncertainty (MU) 16
V How to define Risk Acceptance Criteria? ISO 13485:2016 - Medical Device Quality Management Systems 3
Rameshwar25 Acceptance Criteria for Attribute MSA Study Effectiveness Summary Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D What are API Equipment Cleaning Requirements and Acceptance Criteria? US Food and Drug Administration (FDA) 3
V How are the Acceptance Criteria for Content Uniformity & Dissolution Superior? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
Q Sampling Plan Acceptance Criteria - ISO TS 16949 Clause 7.1.2 IATF 16949 - Automotive Quality Systems Standard 8
1 Acceptance criteria and related standard for 1 micron Lever Type dial Indicator General Measurement Device and Calibration Topics 5
M Acceptance Criteria for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Acceptance Criteria for Calibration by an External Calibration Laboratory General Measurement Device and Calibration Topics 9
S Stability calculation with formula in excel sheet & acceptance criteria Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
