GR&R for a Stopwatch used to check a built-in Machine Timer
sinned
Registered Visitor
All,
We are using a stopwatch to check if the build-in machine timer is able to correctly stop the mixing machine at a specific time span setting (tol.=+/-10sec; the mixing time is not a critical parameter affecting the quality of the product). The stopwatch itself has been calibrated for accuracy.
Shall we need to do GR&R ?
Ninja
Looking for Reality
FWIW, I wouldn't.
{and I'd likely smack the guy who told me I had to...}
Using a calibrated stopwatch to gage +/- 10 seconds on a non-critical item...why bother doing the extra paperwork? As long as you don't fall asleep watching the thing, it seems pretty easy.
I'm not even sure I would have bothered calibrating the stopwatch if time is not critical.
HTH
agreed. a gage R&R on the stopwatch is not warranted
as an aside, the largest component of measurement variation with a stopwatch is the reaction time of the user. :cool:
sinned
Registered Visitor
Thank to all.
In fact, we care only the accuracy of the timer. I told the calibration dept guy that if they can directly calibrate the accuracy of the build-in machine timer, then the whole thing of using stopwatch to check can be eliminated. Now our MSA expert ask us to do GR&R for everything on the control plan, including the stopwatch and tachometer. Or, otherwise, remove the control from the control plan...
What can we do? We really done it...
Marc
Fully vaccinated are you?
It shouldn't be hard to revise the FMEA and from that revise the control plan. But, keep a history of revisions and rational for doing so. If you had meeting(s) to discuss the changes, keep meeting minutes to support your reasons for the changes.
Look at this as continuous improvement and cost reduction.
Q Internal calibration (stopwatch) IATF 16949 - Automotive Quality Systems Standard 3
J Gas Sterilization of a Force gauge, to be used in orthopedic surgery..?? Other Medical Device and Orthopedic Related Topics 14
J Applicable Great Britain regulations for a custom-built test rig or evaluation kit used for research purposes only. Design and Development of Products and Processes 0
H European requirements for rechargeable Lithium-ion batteries going to be used in Electronic Pipette CE Marking (Conformité Européene) / CB Scheme 0
R How to keep old versions of work instructions from being used at point of use? ISO 13485:2016 - Medical Device Quality Management Systems 20
F Can this device without tolerances be used as a predicate for our 510(k)? US Food and Drug Administration (FDA) 4
B Spreadsheet - Used for complaint investigation - Validation required or not ISO 13485:2016 - Medical Device Quality Management Systems 9
M Is complete testing required as per ISO 10993 for materials used in orthopedic implants or is literature review route possible Other Medical Device Related Standards 3
P Can credentials (ID/PW) used to login be the same as when applying Electronic Signature (Part 11) US Food and Drug Administration (FDA) 2
D Recommendations for equipment used to validate cold storage units General Measurement Device and Calibration Topics 3
E Compressed air quality in ME equipment (used in OR) IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
C Items used for Design Verification Design and Development of Products and Processes 7
R Validation of Software used in Verification Testing ISO 13485:2016 - Medical Device Quality Management Systems 2
G FDA clearance for a device that can't be used clinically (at present) Other US Medical Device Regulations 5
A UDI-PI for IVDs used in house EU Medical Device Regulations 5
L A certificate of conformance used to support a calibration General Measurement Device and Calibration Topics 6
D Tracking software versions used with instruments ISO 13485:2016 - Medical Device Quality Management Systems 0
M How to answer ISO9001:2015 audit finding of old revisions of documents being used? Document Control Systems, Procedures, Forms and Templates 8
M Methods used to label the package EU Medical Device Regulations 4
P Cleaning Agents to be Used on Metals & Plastics Qualification and Validation (including 21 CFR Part 11) 1
A Applicability of Photobiological Safety Evaluation for LED used in medical devices Reliability Analysis - Predictions, Testing and Standards 2
R Tools used for measuring (New to metrology) General Measurement Device and Calibration Topics 9
L Requirements for Cables used for Low-Voltage DC Mains (12-36VDC) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
N Voltage Doubler fail - can gas tubes be used? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
N Maximum mains voltage used when applying 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
W How long do you keep information about equipment no longer used? Document Control Systems, Procedures, Forms and Templates 2
Q PPT used as Design Review ISO 13485:2016 - Medical Device Quality Management Systems 3
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
R Nanomaterials used as coating on class I MD - rule 19 EU Medical Device Regulations 4
E SIP/SOP requirements for USB port used for charging IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
John Broomfield Informational Terms used in quality management [Deleted] Misc. Quality Assurance and Business Systems Related Topics 6
G Devices from IQ, OQ or PQ process to be used for verification, validation and summative? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
Q LOT or Serial Number Symbol not used when the information is contained in the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
R Foam mattresses used in hospitals - compliance with MDR requirements? EU Medical Device Regulations 6
DuncanGibbons Looking for example aerospace part CAD files to be used for a case study Career and Occupation Discussions 2
I Custom software services to be used by medical software ISO 13485:2016 - Medical Device Quality Management Systems 1
A Single use non-sterile syringe used in the oral cavity - Laboratory test advice US Food and Drug Administration (FDA) 7
R PMCF - centers/countries used CE Marking (Conformité Européene) / CB Scheme 0
