GR&R for an Automatic Optical Inspection Machine (AOI)
K
Karl2109
Hello Everybody,
I'm new to this forum so I ask for forgiveness in advance for asking a question which may already have been answered and I just did not see it !
My question(s) is in regard to performing a GR&R for an optical inspection machine during an on-site evaluation at a customer site. The customer evaluates different AOI systems from different vendors simultaniously.
(1) Am I correct in saying that there cannot be a GR&R for a fully automatic (in-line) optical inspection machine and that there can be just a GR result ?
(2) I read in some of the previous feeds that Cp/Cpk must not be used for the evaluation of an AOI system. Is that true and if so why ?
(3) If I use the simplied formular to determin the GR (stability test) - what determines if the factor 5.15 or 6.00 should be used ?
(4) And here comes the big one - what determines the spec limits/tolerance in those applicable formulas/GR&R calculators ? I think it should be the tolerance (spec limit) of the AOI system (x/y + optical resolution) while some of my colleagues believe it should be the spec-limit of the sample/part the AOI system is inspecting (e.g. tolerance to an area covered with a fluid).
Any feedback would be sincerely appreciated.
Thanks and regards, Karl
caversluis
Hej Karl,
For some time ago I did a six-sigma project on a AOI machine. We use orbotech machines in electronics manufacturing. The machines are used for detectings shorts etc. If you do that, a regular GR&R can not be used as you work with attribute data. Thefore I performed a Attribute gage R&R where the machines is treated as an operator and the results are compared to the findings of an expert.
In fact you will have to do this for every single things you look for on the board. In my setup a used 15 boards with 88 opportunities for defects (ofd). Every ofd was inspected twice both machine and expert. The result was analyzed in minitab.
Hope this helps,
Cornelis
K
Karl2109
You are right on the money Cornelis - Our equipment and the Orbotech equipment address the same market segment (2D/3D PCB inspection).
What differenciates a regular GR&R from the 'Attribute GR&R' you have mentioned ?
Any thoughts concerning my other (original) questions -- particuarly concerning Cpk data and why this may not be the way to go for an AOI machine ?
Thanks, Karl
caversluis
Well let us say you produce shafts. You will then be able to measure the diameter on the shaft. The measurements will be "real" like 60,345. Due to this, you can calculate mean and deviation. As you will have tolerances, you can calulate Cp and Cpk values.
Now you are not producing shafts but PCB's. This complicates things a bit since you can not measure f.ex. shorts. You can see whether you have a short or not. So your "measurement" will be good / bad. This is called attribute data. The problem is that when you have attribute data, you can not calculate mean and deviation and therefore you can not calculate Cp /Cpk.
The same goes for GR&R. The statistics behinds this rely on "real" data. When you do not have "real" data, you have to use another method.
For attribute data, you can use Attribute Gage R&R. This was in fact invented for operator inpsection. You would have a number og boards inspected by an expert and then you would have several operators inspect the same boards. When the operators find the same mistakes, they are good operators.
This method can be uses for your AOI machine. Just consider it an operator! Wou will find a pretty good explanation on Attribute Gage R&R here
europe.isixsigma.com/library/content/c070516b.asp
I also can recommend the book "six sigma memory jogger" which can be bought from amazon. It explains the most important six sigma tools - it includes an explanation of GR&R and attribute GR&R.
With kind regards,
Cornelis
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
M Automatic Data Gathering Requirements and Privacy Implications Medical Information Technology, Medical Software and Health Informatics 0
WEAVER Can automatic machine testers be subject to GR&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
G GR&R in A.T.E. (Automatic Test Equipment) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
P MSA on an in-line automatic X-ray thickness measuring gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Design Standards for Automatic Fare Collection System Various Other Specifications, Standards, and related Requirements 2
O IEC 61010-1 Ed 2: "Automatic Disconnection of the supply" CE Marking (Conformité Européene) / CB Scheme 3
D Back to Back MSA - Two "identical" automatic measuring systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P Change the way you think about SPC - Automatic Data Collection Statistical Analysis Tools, Techniques and SPC 8
N Does OHSAS 18001 require organization to have AED (Automatic External Defibrillator) Occupational Health & Safety Management Standards 4
I ADR (Automatic Data Recorder) Calibration Requirements Calibration and Metrology Software and Hardware 2
J The appropriate Attribute MSA for Automatic Visual Inspection Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
E MSA for criteria Automatic Video Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Smartphone based software with automatic "rating" from remote servers Medical Information Technology, Medical Software and Health Informatics 4
F CMM Scanning Feature Delays - Brown and Sharpe automatic CMM using PC-DMIS CAD 4.3 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L MSA in Automatic Equipment - PCB Assembly - Help! Quality Tools, Improvement and Analysis 6
W Is a Non-Automatic Weighing Instrument a Medical Device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
optomist1 GD&T Flatness Automatic Indirect Control Rule #1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
B Conducting a study on Hexagon Nuts "turned" on a multi-spindle automatic lathe Statistical Analysis Tools, Techniques and SPC 9
B Attribute MSA for Visual Inspection via Camera Automatic Inspection Tool Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P Gage R&R with ATE (Automatic Test Equipment) - Newbie here... Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
B Attribute MSA of Automatic Inspection Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
K Gage R&R's on automatic gages with robots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
B What local standards are needed for ISO 9001 - Automatic doors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Gage R&R analysis for a fully automatic machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S How to carry out Gage R&R for automatic machines? Automated Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 22
K MSA for Steam Autoclave Automatic Controller and Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Z Supplier of Automatic Gaging Systems need to be on our Approved Supplier List? IATF 16949 - Automotive Quality Systems Standard 6
Q Over sampling - Product on an automatic line with a predetermined lot size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Reproducibility error between instruments for automatic measuring equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D Attribute Gage R&R study - Automatic machine that tests for a particular feature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
I ATE (Automatic Test Equipment) "Gage" process for electronic modules? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
G GR&R on automatic equipment such as a CMM - Do you still have to use 3 operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
T Need supplier for automatic thread inspection go / no go machine Supplier Quality Assurance and other Supplier Issues 3
D MSA for Attribute data - Automatic Hy-pot test machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
B Gage R&R for Automatic Test Systems - No operator influence on readings Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
C Need 3 appraisers for GR&R (Gage R&R) of Automatic Test Measurements? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Determining MSA Bias in Automatic Test Equipment for Electronics Modules Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
A Gage R&R with ATE (Automatic Test Equipment) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
J How & how often to perform verification of Test Software of Automatic Test Equipment? General Measurement Device and Calibration Topics 3
Z Control Charts and sample size for automatic measurement Statistical Analysis Tools, Techniques and SPC 1
Jerry Eldred Gauge R&R studies for Automatic Gages and Test Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
optomist1 Best Optical Comparators General Measurement Device and Calibration Topics 9
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
S Optical coherence tomography (OCT) device - Do we need to apply IDE? Other US Medical Device Regulations 0
G How to compute or estimate a micrometer or caliper flatness using optical flat General Measurement Device and Calibration Topics 2
Q NADCAP NDT (specifically RT) - Calibration of eye loupe reticle & optical comparator AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J TOPCON PP-70 Optical Comparator - User Manual Needed General Measurement Device and Calibration Topics 0
