GR&R for Hardness Tester and Arc Spark Spectrometer
sinned
Registered Visitor
Dear all,
Can anyone share experience on doing GR&R for hardness tester and arc spark spectrometer ?
We have done them using the destructive GR&R method but the results are always poor.
If you have set up the study correctly and your results are poor that can be because your measurement system is actually not very repeatable given the tolerances you are dealing with.
Can you give details regarding the study design and the results?
sinned
Registered Visitor
We tried measure Pb, Ag, and Cu % content with the arc spark spectrometer using the same set of sample ingot from our process. The ANOVA method for destructive GR&R were used with 10 samples and 3 operators. (I doubt if this kind of measurement has the component of operator error indeed, because there is no fixture required in the measurement.) Nevertheless, the outcome %P/T is around 26 with spec. range 0.2%.
I think it could still be considered acceptable and my colleague is sending the results to customer for comment. I believe the uniformity of the sample content is important because the same spot can not be measurement repeatedly.
At the same time, Ppk has been done with result >1.66. I think it can also be supporting to the less-than-best GR&R results.
Btw, if the spec. range for Pb, Ag, and Cu are different, should I just do GR&R on the one with the smallest range ?
Ninja
Looking for Reality
Arc Spark Spectometry has historically been considered a qualitative test. While newer equipment may be touted as more quantitative, it is still a pretty rough test when faced with a spec range of 0.2%.
It may simply be that the equipment is not capable of passing GRR at that level of need.
Can anyone share experience on doing GR&R for hardness tester...?
What type of hardness tester (e.g., Rockwell, Brinell, Knoop, etc.)?
These will definitely be non-replicable studies. In most cases, there is too much within part variation in hardness, especially with the micro-hardness tests. I recommend using hardness test blocks as parts. Randomly assign the operators and repeat measurements to a grid location on each block and run the study.
% Tolerance is straight forward, but if you need % Study variation, I recommend having one person run a capability study of hardness on actual parts, then using this variation to calculate % Process Variation, which is a better metric than % Study Variation.
JeantheBigone
I haven't done Gage R&R for Arc Spark spectroscopy, but I've measured hundreds of compositions using one. This is an extremely sensitive measurement that checks a tiny portion of material.
If you're using castings and are sparking the surface, that would be my starting point. Castings have huge elemental segregation, and successive measurements on the same sample will reflect this. Heck, I've used that fact on cast stainless steels to show the elevated C and Cr content on the surface.
If that is the case, then I'd recommend using a wrought material for your gage R&R sample.
I know very little about arc spark testing, so I don't know if the following is feasible.
Can you sub-divide the ingot into 10 pieces and perform the test? It is possible that there is significant within ingot variation in the metal content, and portions of the ingot in close proximity would presumably have less variation than portions further apart. Also, does the test itself change the product in any way that would prohibit tests in near proximity? If so, how much distance is required between test areas?
Also, as with the hardness test response previously given, are there standard test blocks that could be used instead of ingots?
JeantheBigone
If it is a casting, then portions of the ingot taken in close proximity may or may not have smaller variation than samples taken further apart. I would avoid using a casting as a sample for Gage R&R because of the inherent variability.
Brammer offers setup samples that are standardized and guaranteed to have a uniform and specified composition:
Brammer Standard Home Page
as does NIST (type in aluminum)
Standard Reference Materials | NIST
And yes, standard hardness blocks are available. Whoever does the calibration of the hardness tester should be able to offer them.
IF the capability study was performed correctly (using samples that span the full range variability of the process; different raw material lots, different processing events, etc.) then you R&R is certainly sufficient for measuring conformance to specification. Remind your customer that the observed variation in a capability study INCLUDES both part variation AND measurement variation. Measurement variance adds and subtracts from the true value; there is no true value out beyond the observed variation that was 'hidden' by measurement error...if there is undetected true results it will be because of an improper study design, not measurement error.
if you have a Ppk > 1.66 and you are reporting a '26%' measurement error, I'd say that most of the variation is measurement error, which is OK (and proves the weakness of the traditional R&R method...)
JeantheBigone
Again, I've never done Gage R&R for an Arc Spark Spectrometer, but my Spectro was one of the key instruments in my lab. 26 % measurement error sounds huge.
Are the operators performing calibrations using standard references prior to each measurement, or when the instrument is turned on? Or is this done at specified intervals?
Is the instrument left on continuously?
How often is the soot removed from the chamber?
Are the first three "burns" discarded?
What is the sample surface preparation?
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
K Wilson Hardness Tester Model 525 Accuracy/Repeatability issues help General Measurement Device and Calibration Topics 4
Johnnymo62 What oil do I use for our Starrett 3814 Hardness Tester? General Measurement Device and Calibration Topics 1
W MSA on a Hardness Tester to satisfy a Customer who is requiring Hardness Cpk Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
Geoff Cotton Measurement Uncertainty (MU) of HR-150A Rockwell Hardness Tester Measurement Uncertainty (MU) 1
Ron Rompen Recommended Rockwell 30T Scale Hardness Tester to verify Incoming Product General Measurement Device and Calibration Topics 1
Ron Rompen Affri MetalTest Portable Hardness Tester Review General Measurement Device and Calibration Topics 1
J Any Difference Between Bench Top and Portable Hardness Tester? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
Q Calibration of Hardness Tester ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
A Difficulties in performing MSA on Rockwell Hardness Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
A Calibration of Rockwell Hardness Tester IATF 16949 - Automotive Quality Systems Standard 10
P Micro Hardness Tester Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K Certifying Existing Hardness Tester Indenters / Penetrators General Measurement Device and Calibration Topics 9
J How to calibrate Hardness Rockwell, Brinnell & Vickers Tester machine General Measurement Device and Calibration Topics 5
D Rockwell hardness tester - Required Enviromental Conditions General Measurement Device and Calibration Topics 3
B Additional Calibration needed for C-Frame Rockwell Hardness Tester? General Measurement Device and Calibration Topics 2
B ISO 6508 and portable hardness measurement instruments General Measurement Device and Calibration Topics 0
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
M Proper terms for describing Hardness General Measurement Device and Calibration Topics 5
J Hardness inspection Audit Finding Employee error Nonconformance and Corrective Action 6
S Portable Magnetic Hardness Testers - Aerospace Manufacturing and Related Processes 4
P Very cheap Hardness Blocks unfortunately without Traceability General Measurement Device and Calibration Topics 11
C Hardness Testing - Low Cpk's using Minitab Misc. Quality Assurance and Business Systems Related Topics 10
O Hardness Testing and Certifying Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
kedarg6500 How much test force to be applied for Vickers hardness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L Hardness Testing - Rockwell 15T Scale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
kedarg6500 CA111-SAE Copper Washer Hardness Measurement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M MSA - What method should we use for the stability of hardness? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S ASTM Standard for Hardness Spec for 6063 T6 Aluminum Extrusions Various Other Specifications, Standards, and related Requirements 1
Q Definition Rockwell Hardness definitions - BW 96 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
V What should I require of a Heat Treat PPAP? Surface Hardness per SAE J664 APQP and PPAP 1
J Hardness Testing E error requirement, Why? Various Other Specifications, Standards, and related Requirements 4
J Requirements for Hardness of Metrology Instrument Parts General Measurement Device and Calibration Topics 3
G Hoffman Scratch Hardness Test - General Parameters for Pass/Fail (Paint Coatings) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
W Cpk for Hardness - PPAP rejected due to no Cpk value being given for a hardness FMEA and Control Plans 10
C MSA for Hardness Machine and Tensile/Compressive Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Rockwell Hardness Testing Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
J Hardness Inspection Test - Rockwell in Lieu of Brinell General Measurement Device and Calibration Topics 6
somashekar Information sharing: Week 22, 2010 (HARDNESS, THREADS, BEARINGS) The Reading Room 3
Ron Rompen HV Hardness Testing Conversions - CRA 1070, tempered 440-520 HV10 Various Other Specifications, Standards, and related Requirements 2
J Sources of Potential Measurement Variation for Brinell Hardness Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A Cause and Effect Analysis - Hardness of Rubber (i.e., durometer) Quality Tools, Improvement and Analysis 11
B Certifying our house for Hardness and Conductivity Testing General Measurement Device and Calibration Topics 8
I Are there any Procedures or Standard relating to Retesting of Hardness of bolts? Quality Manager and Management Related Issues 5
C Specification (hardness) for stainless steel SUS 310 3/4 Hard Manufacturing and Related Processes 3
K Rockwell Hardness Testers ? Brand Recommendation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Expiration Date for Standardized Rockwell Hardness Blocks Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
ScottK Portable Hardness Testing and Testers for Incoming Bar Stock Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
kedarg6500 Potential Failure Mode - Mix Charge for Hardness - Casting Process FMEA and Control Plans 1
