GR&R of a gauge to check a new feature of a new product
Carmine
I'd like to show this issue related to a GR%R of a gauge for a new product.
Let's start like this. MSA AIAG says that I have to take sample of parts that represent the actual or expected range of process variation not the range that represents tolerance of the part.
If my gauge is going to measure a particular feature of a part. I have some different case:
1)This feature is already created by a similar manufacturing line in my plant ( a line that produces a similar product with the same feature), in this case I have historical data where I can take the process variation and, then , I can conduct a GR&R analysis on my gage taking the sample that represents the range of the process variation.
2) I have a very new product with a new feature (I have no Historic data). I get a new manufacturing/assembly line in my plant. So I have a new manufacturing/assembly line that produces a new feature, but not historical data are available because everything is new. The only informations I have are the tolerance range that this feature has on the drawings.
In this case I don't have the process variation, I have the tolerance of the feature.
In addition to this, I can create this features off-line with a special tool. I can create the parts (and the features) needed to conduct a gauge study to verify how capable my gauge is to check the new feature made on the line.
In this case, without historical data and an actual/expected range of process variation, I can take only a sample whose features are within the tolerance range.
Can I have a good and real GR&R by taking a sample of parts that represents the tolerance range?
And If Taking this sample (that represents the tolerance range) at first time is right. Can I repeat the same GR&R Analysis later when I have more data and an actual process variation?
Thanks in advance.
Carmine
Thanks in advance.
Carmine
GR&R using percent of tolerance is OK if the gage is used for inspection purposes. For process control you should be using percent of variation. If you don't have a handle on process variation yet, using percent of tolerance is fine for starters. As you suggest, you might want to do another study when the actual process variation is established and controlled.
You might not need to do a study at all if the characteristic in question and the measurement system are reasonably similar to other characteristics and systems that have already been done.
K Designing a gauge to check the Axis of Snorkel of Axles Design and Development of Products and Processes 5
P Drift Gauge Design to Check 5.235 +.004/-.000 Diameter Design and Development of Products and Processes 1
R What do "GO" and "NO GO" of a thread plug gauge check? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Special gauge design to check the bending of cast parts before machining General Measurement Device and Calibration Topics 2
S Plug Gauge design to check 115.92?0.127 mm bore Calibration and Metrology Software and Hardware 26
Howard Atkins Values and results to check Validation of Gauge (Gage) R&R program Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
B Go / No Go Ring gauge specification - Need to check lamination OD General Measurement Device and Calibration Topics 7
A Thread Gauge Wear Check General Measurement Device and Calibration Topics 2
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
F Gauge R&R & Calibration Intervals Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
S Gauge R and R - Product - Conveyor belt with threads that goes on Sprocket Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Radius Gauge R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
S Pressure Gauge Calibration Uncertainty Calibration and Metrology Software and Hardware 5
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
Ron Rompen Gauge Design Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Gauge CAD certification to Part CAD vs. Gauge certification to Part CAD General Measurement Device and Calibration Topics 1
shimonv Feeler Gauge as a Medical Device Accessory EU Medical Device Regulations 3
C Proper Thickness Gauge for Foam/Felt and Soft Materials General Measurement Device and Calibration Topics 5
J What kind of Tool and Gauge in IATF 16949 Clause 8.5.1.6? IATF 16949 - Automotive Quality Systems Standard 1
alonFAI Gauge R&R for a Peel Tester (tensile tester) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
V Why Gauge R&R 10% is acceptable for variable instruments ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
C How to perform Gauge R & R on Automated Test & Measurement Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
V Inactive Gauge Retention Time - PPAP Section 6 Requirements APQP and PPAP 1
Q Pin Gauge Setup - Measuring the OD of a Catheter Manufacturing and Related Processes 1
kedarg6500 Availability of 5/8" 17.75 TPI Thread Ring Gauge & Die Nut Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
