GR&R on Automated Inspection Cell
John Predmore
#11
The classical GR&R studies the variability of the measuring device separate from the variability from the human operator. With an automated test station, the influence of the human operator (the textbook definition of “reproducibility”) is meaningless if the operator does nothing but press the cycle start button.
However, the GR&R approach can still provide valuable information, for example, what portion of variability is due to the instrument (electronics may have drift or non-linearities, even with no moving parts) versus the part loading cycle (which often involves mechanical motion, and a single part is not positioned in precisely the same position with repeated loading). You can call the part loading cycle “reproducibility” even though untouched by human hands. Many times, the automatic test station in setup mode can retest the part 3 times without unclamping the part. Running repeat measurements without unclamping does not randomize the measurement order, so if there are bias effects over time such as changes in ambient temperature, your analysis might conclude spurious effects. Repeating the automatic test in a different order would be one way to detect confounding of bias-over-time.
If you wanted to study whether the automated station gives the same result on 3 separate days (or 3 different hours, if you suspect ambient temperature is a factor) you could run the same set of parts in pre-determined random order at different times, and call that “reproducibility”. What you hypothesize is each part will test the same way. If not, the difference will be highlighted once you examine the results graphically.
#12
GR&R on changed Tool
I have to re-PPAP a tool that had been dimensionally changed. Would I have to do Gage R&R on the new sample pieces made from the new tool?
Ninja
Looking for Reality
#13
Re: GR&R on changed Tool
Sorry to answer a question with a question...but...
GRR is to test your test system, not your tool.
Does the GRR you already did reasonably cover parts from the new tool size?
If your parts used to be 11mm +/- 1, and now its 11.2 +/- 1...I likely wouldn't re-GRR.
If your parts used to be 11mm, and now they are 25mm...I likely would.
Next question: Did your customer give guidance? If not, I would comment in the re-PPAP why the old GRR is still valid.
#14
parts went from 32-32.3 up to 32.5-32.8
we recently got a new vision system that was not included in our first PPAP. I was going to include it into this one. I'm still kinda new to this so I wasn't sure if I had to go back and re-do the old stuff as well.
Ninja
Looking for Reality
#15
You gave two different answers...fair enough...I asked two questions ;)
If it were only this, I would review the initial GRR and the vision measurement system capability (likely calibrated up to 150mm or more) and call it a day...old GRR still valid...off you go.
But now you've put in a new piece of equipment.
Do your GRR over...no question in my mind.
It will give you data to support (prove in) your new equipment, and handle your PPAP requirements as well.
If it is the same brand and model, I would likely do a 2x3x5 GRR...more of a validation than a full out "are we ok?" test.
If it is a different style, brand or model, I would do a 3x3x10...
But at the end of the day, what your customer requires will rule the day.
HTH
optomist1
A Sea of Statistics
#16
Amen, when and doubt and available, continuous data is best. One can do much more with continuous data v. attribute. Generally continuous data provides a degree of "early warning"....proactive v. reactive
Crimpshrine13 MSA for a part Automated and part Manual Inspection Machine IATF 16949 - Automotive Quality Systems Standard 7
C Gage R&R on In-Process Automated Inspection Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
S How to calibrate AOI (Automated Optical Inspection) for IOPQ Qualification and Validation (including 21 CFR Part 11) 3
Q Validating the AOI process (Automated Optical Inspection) Reliability Analysis - Predictions, Testing and Standards 9
B Automated Vision Inspection System MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Automated In-Line Inspection MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Outside the box, or off the reservation? Applications for automated inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
P Measurement Resolution of In-Process Automated Inspection System - Stamping House Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
H Attribute Gage R&R for Repair Station Operators - AOI (Automated Optical Inspection) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
gramps What do you think about automated QA testing For software app industry? Misc. Quality Assurance and Business Systems Related Topics 5
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
J Sub-supplier change from manual to automated process - same specs - Report to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P Images of Product for Automated Process - How long to keep? US Food and Drug Administration (FDA) 2
M Applicability of Means of Protection, working voltage in an Automated External Defibrillator IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
T Tests IEC 60601-1 - Grounding Resistance, Leakage Current and Dielectric Rigidity in an automated way IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S What are you looking for in an automated quality management system? Quality Assurance and Compliance Software Tools and Solutions 8
F Automated Platform (IVD) Classification/Registration (New to RA) EU Medical Device Regulations 3
M Is Automated Internal Auditing Possible? Internal Auditing 13
A Automated Measurement Machine MSA - Small Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Automated and Manual Measurement System Comparison (Correlation) Quality Tools, Improvement and Analysis 3
B How to do an MSA on an Automated Torque / Angle System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Automated calibration of Digital Multimeter without communication port Calibration and Metrology Software and Hardware 2
S Bench Marking Automated Data Collection Benchmarking 4
C How to perform Gauge R & R on Automated Test & Measurement Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
P Looking for recommendations for an automated vision measuring system Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Automated Revision Updates - Notifications of new revisions for ISO's to subscribers Document Control Systems, Procedures, Forms and Templates 2
T Tools Six Sigma for my Automated Machine Six Sigma 8
Q 21 CFR 820.30 - Automated with Computer Software - Applicable? US Food and Drug Administration (FDA) 5
P GR&R on automated test system which produces hundreds of results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Multiple Variation Gage R&R for Automated Testers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Classes for Hydraulic Calibration - Dead Weight Tester or Automated Controller General Measurement Device and Calibration Topics 1
Q Automated Test Software and System Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Automated Calculators like EXCEL sheets for different processes Quality Assurance and Compliance Software Tools and Solutions 2
L Dry Lube Application (Ever lube 620) - Manual Application vs. Automated Spray Process Manufacturing and Related Processes 1
E MSA (Measurement System Analysis) Study on an Automated Process Quality Tools, Improvement and Analysis 4
Hami812 Gage R&R on Automated Tool that supports Pass/Fail and some Parametric Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Automated Production Line Quandary... FMEA and Control Plans 1
R Use of Automated Liquid Handling Robot for a PCR based Assay CE Marking (Conformité Européene) / CB Scheme 2
D Automated Vision Systems - Cost, Value and Payback of Implementation Statistical Analysis Tools, Techniques and SPC 2
I Gage R&R for Automated Measurement Equipment Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A Classification of Automated Gait Training Device for Rehabilitation EU Medical Device Regulations 5
R GAMP (Good Automated Manufacturing Practice) simplified please. Quality Manager and Management Related Issues 3
G Is Agilent?s automated network analyzer verification ISO/IEC-17025 compliant? ISO 17025 related Discussions 4
T Gage Repeatability for an Automated Leak Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
sagai Automated System's Signature on Electronic Record - PART11 Qualification and Validation (including 21 CFR Part 11) 4
C Multiple Fixture Automated Vision System GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M GR&R (Gage R&R) for Automated Electrical Testing Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Automated paint process control on conveyerized lines - Million dollar question Capability, Accuracy and Stability - Processes, Machines, etc. 14
